Geo
January 30, 2024, 3:33pm
1
I was wondering when I assemble a matrix, say in the Poisson tutorial in the step
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
can I print in the screen A and L or transform them to np matrix or array without resorting to the source code?
dokken
January 30, 2024, 3:48pm
2
For small matrices you can first assemble the matrix with A=dolfinx.fem.petsc.assemble_matrix(dolfinx.fem.form(a))
and call print(A[:,:]).
For larger matrices one should use the scipy csr matrix. There are plenty of posts with this on the forum.
The vector is easy to print, simply assemble it
b = dolfinx.fem.petsc.assemble_vector(dolfinx.fem.form(L))
print(b.vector.array)
or use
b = dolfinx.fem.assemble_vector(dolfinx.fem.form(L))
print(b.array)
See for instance: Solving PDEs with different scalar (float) types — DOLFINx 0.7.3 documentation
Geo
January 30, 2024, 4:09pm
3
Thanks, worked perfectly. I will copy-paste a complete code below in case someone needs it in the future.
import dolfinx.fem.petsc
import scipy
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 10, 10, dolfinx.mesh.CellType.quadrilateral)
V = dolfinx.fem.FunctionSpace(domain, ("CG", 1))
uD = dolfinx.fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
tdim = domain.topology.dim
fdim = tdim - 1
domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
boundary_facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
boundary_dofs = dolfinx.fem.locate_dofs_topological(V, domain.topology.dim-1, boundary_facets)
print(boundary_dofs)
dof_coordinates = V.tabulate_dof_coordinates()[boundary_dofs]
bc = dolfinx.fem.dirichletbc(uD, boundary_dofs)
u = ufl.TrialFunction(V)
f = dolfinx.fem.Constant(domain, ScalarType(-6))
L = f * v * ufl.dx
problem = dolfinx.fem.petsc.LinearProblem(a, L, bcs=[bc])
uh = problem.solve()
# Assemble the sparce matrix
A=dolfinx.fem.assemble_matrix(dolfinx.fem.form(a))
As = scipy.sparse.csr_matrix((A.data, A.indices, A.indptr))
print(As)
# Convert the scipy sparse matrix to a dense numpy array
A_dense = As.toarray()
# Convert the numpy array to a numpy matrix
A_matrix = np.matrix(A_dense)
print(A_matrix)
print(b.array)
