Problem facing in using NonlinearVariationalSolver for Hybridized mixed finite element method
Hello Everyone. Hope you all are good.
The weak formulation of my problem is to seek (q_{h},u_{h},\lambda_{h}) \in V_{h}\times W_{h} \times M_{h} such that
\int_{\Omega} (1+u_{h}^{2})q_{h}v_{h} dx - \sum_{T}\int_{T} u_{h}div(v_{h})dx + \sum_{e\in \mathcal{E}_{i,h}} \int_{e} \lambda_{h}[[v_{h}]]ds = \int_{\partial{\Omega}} g[[v_{h}]]ds \forall v_{h}\in V_{h}
\sum_{T}\int_{T}w_{h}div{q_{h}}dx = \int_{\Omega} fw_{h}dx \forall w_{h}\in W_{h}
\sum_{e \in \mathcal{E}_{i,h}} \int_{e} m_{h}[[q_{h}]] ds = 0 \forall m_{h}\in M_{h}
where
V_{h}=\left\{v \in L^{2}(\Omega)^{2} \mbox{such that} v|_{T} \in P^{k}(T)\times P^{k}(T)+xP^{k}(T) \forall T\in \mathcal{T}_{h}\right\}.
Here V_{h} is not a subspace of H(div,\Omega).
W_{h} = \left\{ w \in L^{2}(\Omega) \mbox{such that} w|_{T} \in P^{k}(T) \forall T \in \mathcal{T}_{h}\right\},
M_{h}=\left\{w\in L^{2}(\mathcal{E}_{i,h}) \mbox{such that} w|_{e}\in P^{k}(e) \forall e\in \mathcal{E}_{i,h}\right\} ,
\mathcal{E}_{i,h} be the collection of edges of \mathcal{T}_{h} that are in the interior of the domain \Omega.
mesh = UnitSquareMesh(8,8)
V = FunctionSpace ( mesh, "BDM", 1)
W = FunctionSpace ( mesh, "DG", 1)
M = FunctionSpace ( mesh, "DG", 1 , restriction = 'facet')
Ve = FiniteElement ( "BDM",  triangle, 1 )
We = FiniteElement ( "DG",  triangle,  1 )
Me = FiniteElement ( "DG", triangle, 1)
VWMe = MixedElement ( Ve, We, Me )
VWMs = FunctionSpace ( mesh, VWMe )
(q, u, e) = TrialFunctions(VWMs)
(qt, ut, et) = TestFunctions(VWMs)
f = Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)", degree=2)
F = inner((1 + u**2)*q, qt)*dx - u*div(qt)*dx + e*jump(qt,n)*dS + ut*div(q)*dx - f*ut*dx + et*jump(q,n)*dS
u_D = Constant(0.0)
bc = DirichletBC ( VWMs.sub(1), u_D, DomainBoundary())
file_u1 = File('hybridmixed/q.pvd')
file_u2 = File('hybridmixed/u.pvd')
file_u3 = File('hybridmixed/e.pvd')
que = Function(VWMs)
snes_solver_parameters = {"nonlinear_solver": "snes",
                          "snes_solver": {"linear_solver": "lu",
                                          "maximum_iterations": 20,
                                          "report": True,
                                          "error_on_nonconvergence": False}}
problem = NonlinearVariationalProblem(F , que, bc)
solver  = NonlinearVariationalSolver(problem)
solver.parameters.update(snes_solver_parameters)
info(solver.parameters, True)
(q, u, e) = que.split()
file_u1 << q
file_u2 << u
file_u3 << e
This is the error what I got.
UFLException                              Traceback (most recent call last)
<ipython-input-92-d658d2e193cb> in <module>
      7                                           "error_on_nonconvergence": False}}
      8 #solve(F == 0, u , bc)
----> 9 problem = NonlinearVariationalProblem(F , que, bc)
     10 solver  = NonlinearVariationalSolver(problem)
     11 solver.parameters.update(snes_solver_parameters)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/problem.py in __init__(self, F, u, bcs, J, form_compiler_parameters)
    155
    156         # Wrap forms
--> 157         F = Form(F, form_compiler_parameters=form_compiler_parameters)
    158         if J is not None:
    159             J = Form(J, form_compiler_parameters=form_compiler_parameters)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/form.py in __init__(self, form, **kwargs)
     42
     43         ufc_form = ffc_jit(form, form_compiler_parameters=form_compiler_parameters,
---> 44                            mpi_comm=mesh.mpi_comm())
     45         ufc_form = cpp.fem.make_ufc_form(ufc_form[0])
     46
/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py in mpi_jit(*args, **kwargs)
     48         # Just call JIT compiler when running in serial
     49         if MPI.size(mpi_comm) == 1:
---> 50             return local_jit(*args, **kwargs)
     51
     52         # Default status (0 == ok, 1 == fail)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/jit/jit.py in ffc_jit(ufl_form, form_compiler_parameters)
     98     p.update(dict(parameters["form_compiler"]))
     99     p.update(form_compiler_parameters or {})
--> 100     return ffc.jit(ufl_form, parameters=p)
    101
    102
/usr/lib/python3/dist-packages/ffc/jitcompiler.py in jit(ufl_object, parameters, indirect)
    215
    216     # Inspect cache and generate+build if necessary
--> 217     module = jit_build(ufl_object, module_name, parameters)
    218
    219     # Raise exception on failure to build or import module
/usr/lib/python3/dist-packages/ffc/jitcompiler.py in jit_build(ufl_object, module_name, parameters)
    131                                     name=module_name,
    132                                     params=params,
--> 133                                     generate=jit_generate)
    134     return module
    135
/usr/lib/python3/dist-packages/dijitso/jit.py in jit(jitable, name, params, generate, send, receive, wait)
    163         elif generate:
    164             # 1) Generate source code
--> 165             header, source, dependencies = generate(jitable, name, signature, params["generator"])
    166             # Ensure we got unicode from generate
    167             header = as_unicode(header)
/usr/lib/python3/dist-packages/ffc/jitcompiler.py in jit_generate(ufl_object, module_name, signature, parameters)
     64
     65     code_h, code_c, dependent_ufl_objects = compile_object(ufl_object,
---> 66             prefix=module_name, parameters=parameters, jit=True)
     67
     68     # Jit compile dependent objects separately,
/usr/lib/python3/dist-packages/ffc/compiler.py in compile_form(forms, object_names, prefix, parameters, jit)
    141     """This function generates UFC code for a given UFL form or list of UFL forms."""
    142     return compile_ufl_objects(forms, "form", object_names,
--> 143                                prefix, parameters, jit)
    144
    145
/usr/lib/python3/dist-packages/ffc/compiler.py in compile_ufl_objects(ufl_objects, kind, object_names, prefix, parameters, jit)
    183     # Stage 1: analysis
    184     cpu_time = time()
--> 185     analysis = analyze_ufl_objects(ufl_objects, kind, parameters)
    186     _print_timing(1, time() - cpu_time)
    187
/usr/lib/python3/dist-packages/ffc/analysis.py in analyze_ufl_objects(ufl_objects, kind, parameters)
     88         # Analyze forms
     89         form_datas = tuple(_analyze_form(form, parameters)
---> 90                            for form in forms)
     91
     92         # Extract unique elements accross all forms
/usr/lib/python3/dist-packages/ffc/analysis.py in <genexpr>(.0)
     88         # Analyze forms
     91
/usr/lib/python3/dist-packages/ffc/analysis.py in _analyze_form(form, parameters)
    172                                       do_apply_geometry_lowering=True,
    173                                       preserve_geometry_types=(Jacobian,),
--> 174                                       do_apply_restrictions=True)
    175     elif r == "tsfc":
    176         try:
/usr/lib/python3/dist-packages/ufl/algorithms/compute_form_data.py in compute_form_data(form, do_apply_function_pullbacks, do_apply_integral_scaling, do_apply_geometry_lowering, preserve_geometry_types, do_apply_default_restrictions, do_apply_restrictions, do_estimate_degrees, do_append_everywhere_integrals, complex_mode)
    319     # Propagate restrictions to terminals
    320     if do_apply_restrictions:
--> 321         form = apply_restrictions(form)
    322
    323     # If in real mode, remove any complex nodes introduced during form processing.
/usr/lib/python3/dist-packages/ufl/algorithms/apply_restrictions.py in apply_restrictions(expression)
    163     rules = RestrictionPropagator()
    164     return map_integrand_dags(rules, expression,
--> 165                               only_integral_type=integral_types)
    166
    167
/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py in map_integrand_dags(function, form, only_integral_type, compress)
     45 def map_integrand_dags(function, form, only_integral_type=None, compress=True):
     46     return map_integrands(lambda expr: map_expr_dag(function, expr, compress),
---> 47                           form, only_integral_type)
/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py in map_integrands(function, form, only_integral_type)
     26     if isinstance(form, Form):
     27         mapped_integrals = [map_integrands(function, itg, only_integral_type)
---> 28                             for itg in form.integrals()]
     29         nonzero_integrals = [itg for itg in mapped_integrals
     30                              if not isinstance(itg.integrand(), Zero)]
/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py in <listcomp>(.0)
     33         itg = form
     34         if (only_integral_type is None) or (itg.integral_type() in only_integral_type):
---> 35             return itg.reconstruct(function(itg.integrand()))
     36         else:
     37             return itg
/usr/lib/python3/dist-packages/ufl/algorithms/map_integrands.py in <lambda>(expr)
     44
---> 46     return map_integrands(lambda expr: map_expr_dag(function, expr, compress),
/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py in map_expr_dag(function, expression, compress)
     24     Return the result of the final function call.
     25     """
---> 26     result, = map_expr_dags(function, [expression], compress=compress)
     27     return result
     28
/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py in map_expr_dags(function, expressions, compress)
     71             # Cache miss: Get transformed operands, then apply transformation
     72             if cutoff_types[v._ufl_typecode_]:
---> 73                 r = handlers[v._ufl_typecode_](v)
     74             else:
     75                 r = handlers[v._ufl_typecode_](v, *[vcache[u] for u in v.ufl_operands])
/usr/lib/python3/dist-packages/ufl/algorithms/apply_restrictions.py in reference_value(self, o)
     86         f, = o.ufl_operands
     87         assert f._ufl_is_terminal_
---> 88         g = self(f)
     89         if isinstance(g, Restricted):
     90             side = g.side()
/usr/lib/python3/dist-packages/ufl/corealg/multifunction.py in __call__(self, o, *args)
     87     def __call__(self, o, *args):
     88         "Delegate to handler function based on typecode of first argument."
---> 89         return self._handlers[o._ufl_typecode_](o, *args)
     90
     91     def undefined(self, o, *args):
/usr/lib/python3/dist-packages/ufl/algorithms/apply_restrictions.py in _require_restriction(self, o)
     45         "Restrict a discontinuous quantity to current side, require a side to be set."
     46         if self.current_restriction is None:
---> 47             error("Discontinuous type %s must be restricted." % o._ufl_class_.__name__)
     48         return o(self.current_restriction)
     49
/usr/lib/python3/dist-packages/ufl/log.py in error(self, *message)
    156         "Write error message and raise an exception."
    157         self._log.error(*message)
--> 158         raise self._exception_type(self._format_raw(*message))
    159
    160     def begin(self, *message):
UFLException: Discontinuous type Argument must be restricted.
Kindly help me to resolve it.
There are lots of things which look funny in your variational formulation, such as non conforming sizes, and nonlinear terms.
But to address your immediate problem, you need to choose a side of the element for e and et. If they’re single valued, you can just choose either. E.g. e("+").
