Hello all,
I am trying to define my load as a time dependent expression as:
This load has constant magnitude = gt
gt = Expression('A*sin(omega*t)', A = 1.0,
omega = 1.0, t = 0.0, degree = 2)
class IC(UserExpression):
def eval(self, value, x):
value[0] = 0.0
value[1] = 0.0
if x[2] == z1 and 0.051505 <= x[1] <= 0.098495 and gt <= x[0] <= 1.1*gt:
value[2] == -rho*gamma
else :
value[2] == 0.0
def value_shape(self):
return (3,)
tr = IC(element = V.ufl_element())
when I am calling tr which is traction on the boundary I am getting this error:
ufl.log.UFLException: UFL conditions cannot be evaluated as bool in a Python context.
So I can see the error is in this line inside the UserExpression :
any hint would be much appreciated. Thanks.
dokken
April 13, 2020, 5:42am
2
There are several issues with your code. The first one is that you have not defined an initializer.
You Need:
def __init__(self, **kwargs):
super().__init__(**kwargs)
Or else
Has no effect. Secondly,
This should be assigned (using one equal sign) not two. Two equal signs evaluate this as a boolean.
Thirdly,
agerami:
Cannot be evaluated (Which is your error message). I would instead use the initializer to define a lambda function that defined gt.
Thanks Jorgen, because It’s my first time that I am dealing with this concepts, Could you please give a reference or some example that walk me through the process to understand the structure of user-defined expression.
P.S. I’ve read Dolfin tutorial but I could’nt understand how should I modify that for my time-dependent expression.
dokken
April 13, 2020, 10:37pm
4
I was thinking something like this:
mesh = UnitCubeMesh(20,20,2)
V = VectorFunctionSpace(mesh, "CG", 1)
def __init__(self, t, A, omega, z1, rho, gamma, **kwargs):
self.t = t
self.A = A
self.omega = omega
value[0] = 0.0
value[1] = 0.0
gt = self.A*np.sin(self.omega*self.t)
if x[2] == z1 and 0.1 <= x[1] <= 0.3 and gt <= x[0] <= 1.1*gt:
value[2] = -rho*gamma
else :
value[2] = 0.0
return (3,)
A = 1
omega = 1
t = 0
z1 = 0.5
rho = 0.1
gamma = 0.2
tr = IC(t, A, omega, z1, rho, gamma, element = V.ufl_element())
print(assemble(inner(tr, tr)*dx(domain=mesh)))
File("u.pvd") << project(tr, V)
tr.t = 2
Note that I have had to use random parameters as you havent supplied me with values, and to show that it is time dependent, consider the output:
5.99999999999999e-07
2.183333333333337e-06
LGerard
November 17, 2023, 6:51pm
5
Hello @dokken
I am trying to make a function in parts. The first would be a gaussian distribution at a certain height H of the mesh and the other would be constant after that height H. However, I have not been successful.
mesh = RectangleMesh(Point(0.0, 0.0), Point(100.0, 50.0), 10, 10)
mu_phi = 0.5
L = 100
H = 25
x0_phi = 0.5 * L
class porosity(UserExpression):
def __init__(self, phi_0, phi_air, H, **kwargs):
self.phi_0 = phi_0
self.phi_air = phi_air
self.H = H
if x[1] <= H + DOLFIN_EPS:
value[0] = self.phi_0
value[0] = self.phi_air
return ()
mu_phi = 0.5
L = 100
H = 25
x0_phi = 0.5 * L
phi_0 = Expression('exp(-mu_phi*pow(x[0] - x0_phi, 2.0))', degree=1, mu_phi=mu_phi, x0_phi=x0_phi)
phi_air = Expression('1.0', degree=1)
phi = porosity(phi_0, phi_air, H, degree=1)
File("u.pvd") << project(phi, V)
Any suggestions?
LGerard
November 17, 2023, 7:10pm
6
@dokken
I made another code and this one seems to work but I don’t know if it does what I require.
mu_phi = 0.5
L = 100
H = 25
x0_phi = 0.5 * L
def __init__(self, mu_phi, x0_phi, H, **kwargs):
self.mu_phi = mu_phi
self.x0_phi = x0_phi
self.H = H
phi0 = self.np.exp(-self.mu_phi * pow(x[0] - self.x0_phi, 2.0))
value[0] = phi0
value[0] = 1.0
return ()
mu_phi = 0.5
L = 100
H = 25
x0_phi = 0.5 * L
phi = Expression('exp(-mu_phi*pow(x[0] - x0_phi, 2.0))', degree=1, mu_phi=mu_phi, x0_phi=x0_phi, H=H)
dokken
November 17, 2023, 9:17pm
7
Mixing expression and UserExpression is not adviced, choose one or the other.
LGerard
November 17, 2023, 11:53pm
8
Okay,
I did it this way, but in the corner there seems to be problems.
This is the code
mu_phi = 0.5
L = 100
H = 25
x0_phi = 0.5 * L
self.H = H
phi0 = np.exp(-self.mu_phi * pow(x[0] - self.x0_phi, 2.0))
if x[1] <= self.H + DOLFIN_EPS:
value[0] = phi0
value[0] = 1.0
return ()
mu_phi = 0.5
L = 100
H = 25
x0_phi = 0.5 * L
phi = porosity(mu_phi=mu_phi, x0_phi=x0_phi, H=H, element = V.ufl_element())
