How to define u for t=0 by an UserExpression?
The minimum working code example is based on the ft03_heat.py tutorial, which describes a time dependent poisson equation and is governed by the following equations:
u′=Δu+f in the unit square
u=u_D on the boundary (Dirichlet boundary conditions)
u=u_0 at t = 0
I implemented u for t=0 by the following UserExpression instead of using an Expression like
u_D = Expression(‘1 + x[0]x[0] + alphax[1]x[1] + betat’, degree=2, alpha=alpha, beta=beta, t=0),
like it’s used in the tutorial:
# define u for t=0
class MyExpression_t0(UserExpression):
    def eval(self, value, x):
        x = SpatialCoordinate(mesh)
        tol = 1E-14
        # u on left boundary
        if x[0] < tol:
            u = Constant(2.5)
        # u on left domain
        elif x[0] > 0 and x[0] <= 0.1:
            u = Constant(0.5)
        # u for the rest of the domain and boundaries
            u = 0
        return u
u_n = MyExpression_t0()
Unfortunately, I get the following error message:
WARNING: user expression has not supplied value_shape method or an element. Assuming scalar element.
UFL conditions cannot be evaluated as bool in a Python context.
  File "ft03_heat_u0.py", line 38, in <module>
    u_n = interpolate(u_D, V)
  File "/usr/local/lib/python3.6/dist-packages/dolfin/fem/interpolation.py", line 71, in interpolate
    Pv.interpolate(v._cpp_object)
  File "/usr/local/lib/python3.6/dist-packages/dolfin/function/function.py", line 365, in interpolate
    self._cpp_object.interpolate(u)
  File "/usr/local/lib/python3.6/dist-packages/dolfin/function/expression.py", line 53, in wrapped_eval
    self.user_expression.eval(values, x)
  File "ft03_heat_u0.py", line 20, in eval
    if x[0] < tol:
  File "/usr/local/lib/python3.6/dist-packages/ufl/conditional.py", line 46, in __bool__
    error("UFL conditions cannot be evaluated as bool in a Python context.")
  File "/usr/local/lib/python3.6/dist-packages/ufl/log.py", line 172, in error
ufl.log.UFLException: UFL conditions cannot be evaluated as bool in a Python context.
How am I able to fix this? Of course, the use of an UserExpression isn´t mandatory. It was just what I came up with.
Here is the full MWCE:
T = 2.0            # final time
num_steps = 10     # number of time steps
alpha = 3          # parameter alpha
beta = 1.2         # parameter beta
nx = ny = 8
mesh = UnitSquareMesh(nx, ny)
# define u for t=0
        tol = 1E-14
        if x[0] < tol:
            u = Constant(2.5)
        # u on left domain
            u = Constant(0.5)
            u = 0
        return u
u_D = MyExpression_t0()
def boundary(x, on_boundary):
    return on_boundary
# Define initial value
f = Constant(beta - 2 - 2*alpha)
F = u*v*dx + dt*dot(grad(u), grad(v))*dx - (u_n + dt*f)*v*dx
a, L = lhs(F), rhs(F)
# Time-stepping
t = 0
for n in range(num_steps):
    # Update current time
    # Compute solution
    solve(a == L, u, bc)
    # Update previous solution
    u_n.assign(u)
# Hold plot
interactive()
The problem here is the line x = SpatialCoordinate(mesh) inside of the eval method. You want to use the x argument that is passed to eval.
Of course, thanks a lot @kamensky!
Unfortunately, u for t=0, that I described by UserExpression, isn’t used by the program.
I tried two cases( a) u=2.5 and u=0.5; b) u=500 and u=100), like seen underneath
# define u for t=0
        tol = 1E-14
        if x[0] < tol:
            u = Constant(2.5)
            #u = Constant(500)
        # u on left domain
            u = Constant(0.5)
            #u = Constant(100)
            u = 0
        return u
and I always get the same solution, which shouldn´t be the case in my opinion.
I suspect, it has something to do with the warning, that is displayed, when running the program:
In my opinion u for t=0 is a tensor of second degree, not a scalar. How do I implement this or is there another problem, I´m not aware of?
Here is my updated MWCE:
nx = ny = 8
vtkfile = File("ft03_heat_u0/solution.pvd")
# define u for t=0
        tol = 1E-14
        if x[0] < tol:
            u = Constant(2.5)
            #u = Constant(500)
        # u on left domain
            u = Constant(0.5)
            #u = Constant(100)
            u = 0
        return u
    return on_boundary
# Time-stepping
t = 0
    # Compute solution
    vtkfile << (u, t)
    u_n.assign(u)
Thanks a lot!
The problem is that the evaluation of the UserExpression should be written to the value array, not returned by the eval method. For a scalar-valued expression, you would just set value[0] = u. (When assigning to a NumPy array, u will be cast to a float, so there is also no need to wrap numerical values as Constants, although it is not harmful in this case.) To get rid of the warning, you can implement the value_shape method of UserExpression, i.e.,
    def value_shape(self):
        return ()
for a scalar-valued expression (although that is assumed by default, as stated in the warning message).
Thanks again for your great support @kamensky!
I’ve got one final question:
I want to save u for t=0 to the .pvd file for further postprocessing in ParaView.
Unfortunately…
u = MyExpression_t0()
t = 0
vtkfile << (u, t)
…results in the following error message:
  File "ft03_heat_u0_Forum_Check.py", line 43, in <module>
    vtkfile << (u, t)
  File "/usr/local/lib/python3.6/dist-packages/dolfin/io/__init__.py", line 19, in __lshift__
    self.write(u[0], u[1])
RuntimeError: Unable to cast Python instance to C++ type (compile in debug mode for details)
Can you explain me how to fix this issue?
Thanks again!
Updated MWCE:
nx = ny = 8
# define u for t=0
        tol = 1E-14
        if x[0] < tol:
            u = Constant(500)
            value[0] = u
        # u on left domain
            u = Constant(100)
            value[0] = u
            u = 0
            value[0] = u
        return value[0]
        return ()
# save u for t=0 to vtkfile
t = 0
vtkfile << (u, t)
# Define boundary conditions
    return on_boundary
# Time-stepping
    # Compute solution
    vtkfile << (u, t)
    u_n.assign(u)
If you just want to visualize the initial condition, you could instead write the finite element function u_n to vtkfile after interpolating u_D.
