Problem Installing CONDA
Hello everyone, I’ve been trying to download fenics using conda on my linux computer. When I create a new virtual env, and paste the code: “conda install -c conda-forge fenics-dolfinx mpich pyvista” it just keeps loading forever and shuts my terminal, not installing anything.
Anyone knows how to fix this?
Do you mean conda environment? What commands did you run to create this environment and activate it before you ran
Hello; I created a conda virtual environment with
conda create -n myenv
Then I activated it using:
Conda activate myenv,
and then I run the code trying to install fenics but being unsuccessful
Hi Greg,
Do you get an error, or what does your terminal tell you? Have you checked if you have enough memory to install the packages (they are quite big). Also, in case solving the packages takes a long time, it is advised to install libmamba ( Getting started — conda-libmamba-solver) to speed that up.
Otherwise the reply @nav gave, should work.
