Problem on storing and reading sub-solution (as the norm difference between the initial and read solution is not near 0)
Hi everyone,
I have a problem in post-processing my solution (maybe trivial) that I cannot solve.
So, I want to save and load a FEM “sub-solution” extracting from a spliting like u below
w = Function(W) // where W is a mixed space (velocity and pressure for Stokes)
solve(a == L, w, bc, solver_parameters={'linear_solver':'mumps'});
(u, p) = w.split()
I don’t have any compilation error (in my weak formulation and the saving/reading) but when I try to use the “erronorm” function on the difference u^{compute}-u^{read}, I don’t have a null L_2-norm:
 # save and read "u" from the w splitting
  V1 = VectorFunctionSpace(mesh, "CG", 2)
 # Save solution
output_file = HDF5File(mesh.mpi_comm(), "/home/ConvergenceMaillage/maillage/u.h5", "w")
output_file.write(u11, "solution")
output_file.close()
# Load solution
 U = Function(V1)
 input_file = HDF5File(mesh.mpi_comm(),  "/home/ConvergenceMaillage/maillage/u.h5", "r")
 input_file.read(U, "solution")
 input_file.close()
E =errornorm(U,u11, norm_type='L2', degree_rise=4)
This should be at most equal to an epsilon because they are the same solution but I get somehting like 1.687.
Note that I have ||u^{compute}-u^{compute}||_{L_2}=0 (same for u^{read}).
Do I need to interpolate on a special space (as I am on a mixed-space W and only want the solution of W.sub(0)=V=velocity component) ? Is this problem coming from my method to save and read the solution ?
Thank you in advance for your answer.
Adel
You should use write_checkpoint and read_checkpoint: Loading xdmf data back in
Dokken,
Thank you really much for your answer.
Dokken,
I’m really sorry to bother you with a well documented issue (cf. all the other thread) but I dont understant why this is not working in my case.
I did like you said : using checkpoint (.read and .write).
Can you please correct me if you see any error on the post-processing :
from dolfin.cpp.mesh import *
from mshr import*
import sys
import dolfin as do
from numpy import linalg as la
from dolfin import Mesh, XDMFFile, File, MeshValueCollection, cpp, Measure,\
DirichletBC, FunctionSpace, Constant, TrialFunction, \
TestFunction, dot, grad, dx, Function, solve
mesh = Mesh()
with XDMFFile(sys.argv[1]) as infile:
infile.read(mesh)
File("Dolfin_circle_mesh.pvd").write(mesh)
with XDMFFile(sys.argv[2]) as infile:
File("Dolfin_circle_facets.pvd").write(mf)
V = VectorElement("CG", mesh.ufl_cell(), 2)
Q = FiniteElement("CG", mesh.ufl_cell(), 1)
TH = V * Q
W = FunctionSpace(mesh, TH)
(u, p) = TrialFunctions(W)
(v, q) = TestFunctions(W)
tol = 1E-14
boundaries = MeshFunction("size_t", mesh,
mesh.topology().dim()-1)
ds_G = Measure("ds", domain=mesh, subdomain_data=mf,
subdomain_id=100001)
ds_D = Measure("ds", domain=mesh, subdomain_data=mf,
subdomain_id=100003)
ds_B = Measure("ds", domain=mesh, subdomain_data=mf,
subdomain_id=100002)
ds_H = Measure("ds", domain=mesh, subdomain_data=mf,
subdomain_id=100004)
ds_O = Measure("ds", domain=mesh, subdomain_data=mf,
subdomain_id=100000)
n1 = FacetNormal(mesh)
f1 = Constant((0, 0))
mu1 = 0.001
mu = Constant(mu1)
rho = Constant(1000)
bc_os1 = DirichletBC(W.sub(0), (0.0,0.0), mf, 100000)
bc_noflow1 = DirichletBC(W.sub(0).sub(1), 0.0, mf, 100004)
bc_2noflow1 = DirichletBC(W.sub(0).sub(1), 0.0, mf, 100002)
bcp_outflow1 = DirichletBC(W.sub(1), 0.0, mf, 100003)
bc11 = [bc_2noflow1,bc_noflow1, bc_os1,bcp_outflow1]
a11 = mu1*inner(grad(u),grad(v))*dx(mesh)\
- div(v)*p*dx(mesh) - q*div(u)*dx(mesh)
L11 = -dot(1*v,n1)*ds_G
w11 = Function(W)
solve(a11 == L11, w11, bc11, solver_parameters=
(u11, p11) = w11.split()
with XDMFFile(MPI.comm_world, "/home/amoreno3/ConvergenceMaillage/maillage/vitesseDokken7.xdmf") as outfile:
 outfile.write_checkpoint(u11, "u11", 0, append=False)
f1 = Function(V1)
with XDMFFile(MPI.comm_world, "/home/amoreno3/ConvergenceMaillage/maillage/vitesseDokken7.xdmf") as infile:
infile.read_checkpoint(f1, "u11")
E =errornorm(f1,u11, norm_type='L2', degree_rise=4)
print(E)
print(len(u11))
print(len(f1))
For further issues, please make a minimal working code example (an example I can run on my computer and reproduce the issue). Please make sure to remove all unecessary imports. You are import several things multiple times in your code, (from dolfin import *, from fenics import *, from dolfin import Mesh …) all does the same thing. You also import dolfin as do.
Please use the example below as a guideline on minimal working code examples:
mesh = UnitSquareMesh(10,10)
TH = V * Q
w = Function(W)
# Create functionspaces for each of the elements
V1 = FunctionSpace(mesh, V)
Q1 = FunctionSpace(mesh, Q)
f = FunctionAssigner(W, [V1,Q1])
# Create a non-zero velocity profile
u_vel = project(Expression(("x[0]", "x[1]"),degree=2), V1)
# Assign velocity profile to w
print(w.vector().norm("l2"))
f.assign(w, [u_vel, Function(Q1)])
u, p = w.split()
# Save checkpoint of u
with XDMFFile(MPI.comm_world, "vitesseDokken7.xdmf") as outfile:
    outfile.write_checkpoint(u, "u", 0, append=False)
# Load checkpoint of u
f1 = Function(V1)
# Removing this loading will make the test fail
with XDMFFile(MPI.comm_world, "vitesseDokken7.xdmf") as infile:
    infile.read_checkpoint(f1, "u")
# Compare loaded function with original function
E =errornorm(f1,u, norm_type='L2', degree_rise=4)
u_org = w.split(deepcopy=True)[0].vector().get_local()
assert(np.allclose(u_org, f1.vector().get_local()))
Thanks for the demo. That’s work now.
Have a good day
