Hello everyone.
I’m trying to read a solution from a problem to another.
In the previous problem, I’ve used:
timeseries_v1 = TimeSeries(‘velocity’)
timeseries_p1 = TimeSeries(‘pressure’)while t<t_end:
Compute Fluid problem
print(‘\n\nSolving Fluid Problem’)
solve(F1 == 0, vp1, bcs=bcs_rigid, J=J, solver_parameters = par, form_compiler_parameters = {“quadrature_degree”: 3})Extract solutions:
(v1, p1) = vp1.split(True)
Save solution to file (XDMF/HDF5)
#output_file.write(v1, “solution”)
#output_file.write(p1, “solution”)timeseries_v1.store(v1.vector(), t)
timeseries_p1.store(p1.vector(), t)#Fluid next stepvn.assign(v1)
This save the files pressure.h5 and velocity.h5
An then, I tried to read using:
vr, pr = Function(W.sub(0).collapse()), Function(W.sub(1).collapse())
input_file = HDF5File(mesh.mpi_comm(), “velocity.h5”, “r”)
input_file.read(vr, “v1”)
input_file.read(vr, “p1”)
The problem is, a got the following error:
input_file.read(vr, “velocity”)
RuntimeError:*** -------------------------------------------------------------------------
*** Error: Unable to read function from file.
*** Reason: Group with name “velocity” does not exist.
*** Where: This error was encountered inside HDF5File.cpp.
*** Process: 0
*** DOLFIN version: 2018.1.0
*** Git changeset: 948dc42cc4e06ed9227d0201ad50f94ac94cbf9f
I’ve tried change “velocity” for “v1” but the error is the same!
Any help?
Thanks
