Problem projecting with scaled meshes
I am trying to calculate electric field and charge density from poisson equation using a projection function. The code gives NaN for meshes with scale =1E-6 (this is the actual scale of the problem), but works for scale =1. I am able to solve poission equation for both meshes, but projection does not seem to work.
from dolfinx import mesh
import ufo
import numpy,gmsh
from dolfinx.io import gmshio, XDMFFile
from dolfinx import fem
from dolfinx.fem import functionspace
import pyvista
scale =1E-6
L = 600.0*scale #Length
W = 200.0*scale #Width
H=50*scale  # Thickness
model_rank = 0
mesh_comm = MPI.COMM_WORLD
gdim=3
def simpleproject(e,V,bc=[]):
    """Simple Projection function"""
    dx = ufl.dx(V.mesh)
    # Define variational problem for projection
    v = ufl.TrialFunction(V)
    w = ufl.TestFunction(V)
    sol=fem.Function(V)
    a = ufl.dot(v, w) * dx
    L = ufl.dot(ufl.grad(e), w) * dx
    problem = LinearProblem(a,L,bc,petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
    sol=problem.solve()
    return sol
gmsh.model.add("Structure")
box=gmsh.model.occ.addBox(0,0,0,L,W,H,1)
gmsh.model.occ.synchronize()
gmsh.model.addPhysicalGroup(gdim,[3],tag=1)
boundaries = gmsh.model.getBoundary([(gdim,3)], oriented=False)
boundary_ids = [b[1] for b in boundaries]
gmsh.model.addPhysicalGroup(gdim-1,boundary_ids,tag=20)
domain,_ ,_  = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
gmsh.finalize()
tdim=domain.topology.dim
fdim=tdim-1
p=1
V = functionspace(domain, ("Lagrange", p))
V2= functionspace(domain, ("Lagrange", p,(tdim,)))
uD = fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
Efield=simpleproject(-uD,V2)
Ez=Efield.sub(gdim-1).collapse()
from dolfinx import plot
u_topology, u_cell_types, u_geometry = plot.vtk_mesh(V)
u_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
u_grid.point_data["u"] = Ez.x.array.realu_grid.set_active_scalars("u")
u_plotter = pyvista.Plotter()
u_plotter.add_mesh(u_grid, show_edges=True)
u_plotter.view_xy()
if not pyvista.OFF_SCREEN:
    u_plotter.show()
I would not advice you to scale the mesh to such a small order of magnitude as you introduce floating point error in your code.
For instance, for any integral, you need to compute the determinant of the Jacobian of a single cell.
This is equivalent to the volume of a cell. If each side of your Domain is 1e-6, and say you have 1 element in each direction, then the volume of a hexahedron is 1e-18, which is below double precision. The volume of a tetrahedron is of course even smaller.
Please rather rescale your equation, if you aim to work in micrometers.
For further questions, please also put some effort into your minimal reproducible example. Currently, you have not given a code that is runnable and it has tons of unused imports.
I cannot even reproduce your nan example after trying to fix your code:
scale = 1e-6
L = 600.0 * scale  # Length
W = 200.0 * scale  # Width
H = 50 * scale  # Thickness
model_rank = 0
gdim = 3
def simpleproject(e, V, bc=[]):
    dx = ufl.dx(V.mesh)
    sol = fem.Function(V)
        a, L, bc, petsc_options={"ksp_type": "preonly", "pc_type": "lu"}
    sol = problem.solve()
    return sol
box = gmsh.model.occ.addBox(0, 0, 0, L, W, H, 1)
gmsh.model.addPhysicalGroup(gdim, [3], tag=1)
boundaries = gmsh.model.getBoundary([(gdim, box)], oriented=False)
gmsh.model.addPhysicalGroup(gdim - 1, boundary_ids, tag=20)
domain, _, _ = gmshio.model_to_mesh(gmsh.model, mesh_comm, model_rank, gdim=gdim)
gmsh.finalize()
tdim = domain.topology.dim
fdim = tdim - 1
p = 1
V2 = functionspace(domain, ("Lagrange", p, (gdim,)))
uD.interpolate(lambda x: 1 + x[0] ** 2 + 2 * x[1] ** 2)
Efield = simpleproject(-uD, V2)
print(Efield.x.array)
Sorry for the typos in the code…
import numpy,gmsh
import pyvista
scale =1E-6
model_rank = 0
gdim=3
    dx = ufl.dx(V.mesh)
    sol=fem.Function(V)
    sol=problem.solve()
    return sol
gmsh.model.addPhysicalGroup(gdim,[1],tag=1)
boundaries = gmsh.model.getBoundary([(gdim,1)], oriented=False)
gmsh.finalize()
fdim=tdim-1
p=1
u_plotter.view_xy()
    u_plotter.show()
Scaling the equation did the trick. The problem was indeed the jacobian blowing up.
Thanks a lot!.
