I’m working towards a simulation with different equations defined in different subdomains of my problem and as a first step I found this demo that I wanted to try and get running first since it seems to be solving different Poisson equations in different subdomains. That being said, some of the functions used in this demo seem to no longer exist. I tried and adapted them to newer functions myself in the following way:
#Create mesh and define function space
mesh = UnitSquareMesh(30, 30)
marker = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
for c in cells(mesh):
marker[c] = c.midpoint().y() < 0.5
#marker[c] = c.midpoint().x() < 0.5
submesh1 = SubMesh(mesh, marker, 1)
submesh2 = SubMesh(mesh, marker, 0)
# Define Dirichlet boundary
def boundarySub1(x):
return x[1] < DOLFIN_EPS
#return x[0] < DOLFIN_EPS
def boundarySub2(x):
return x[1] > 1.0 - DOLFIN_EPS
#return x[0] > 1.0 - DOLFIN_EPS
#element2D = FiniteElement("Lagrange", triangle, 1)
W1 = FunctionSpace(submesh1, "Lagrange", 1)
W2 = FunctionSpace(submesh2, "Lagrange", 1)
# Define the mixed function space
V = FunctionSpace(mesh, W1.ufl_element()*W2.ufl_element())
# Define boundary conditions
u0 = Constant(0.0)
# Subdomain 1
bc1 = DirichletBC(V.sub(0), u0, boundarySub1)
bc1_ = DirichletBC(W1, u0, boundarySub1)
# Subdomain 2
bc2 = DirichletBC(V.sub(1), u0, boundarySub2)
bc2_ = DirichletBC(W2, u0, boundarySub2)
bcs = [bc1,bc2]
# Use directly TrialFunction and TestFunction on the product space
# Subdomain 1
u1 = TrialFunction(W1)
v1 = TestFunction(W1)
# Subdomain 2
u2 = TrialFunction(W2)
v2 = TestFunction(W2)
# Mixed
(u1_m,u2_m) = TrialFunctions(V)
(v1_m,v2_m) = TestFunctions(V)
f = Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)", degree=2)
# Weak form - 1
a1 = inner(grad(u1), grad(v1))*dx
L1 = f*v1*dx
u1 = Function(W1)
solve(a1 == L1, u1, bc1_)
# Weak form - 2
a2 = inner(grad(u2), grad(v2))*dx
L2 = f*v2*dx
u2 = Function(W2)
solve(a2 == L2, u2, bc2_)
# Mixed weak form
a = inner(grad(u1_m), grad(v1_m))*dx + inner(grad(u2_m), grad(v2_m))*dx
L = f*v1_m*dx + f*v2_m*dx
# Solve the problem
sol = Function(V)
solve(a == L, sol, bcs, solver_parameters={"linear_solver":"direct"})
sol1 = sol.sub(0)
sol2 = sol.sub(1)
assert len(u1.vector()) == len(sol1.vector())
for i in range(len(u1.vector())):
assert abs(sol1.vector()[i] - u1.vector()[i]) < 1e-10
assert len(u2.vector()) == len(sol2.vector())
for i in range(len(u2.vector())):
assert abs(sol2.vector()[i] - u2.vector()[i]) < 1e-10
## Export result
encoding = XDMFFile.Encoding.HDF5 if has_hdf5() else XDMFFile.Encoding.ASCII
out_u1 = XDMFFile(MPI.comm_world, "block-assembly-2D2D-subdomain1-ref.xdmf")
out_u2 = XDMFFile(MPI.comm_world, "block-assembly-2D2D-subdomain2-ref.xdmf")
out_sub1 = XDMFFile(MPI.comm_world, "block-assembly-2D2D-subdomain1.xdmf")
out_sub2 = XDMFFile(MPI.comm_world, "block-assembly-2D2D-subdomain2.xdmf")
if MPI.size(MPI.comm_world) > 1 and encoding == XDMFFile.Encoding.ASCII:
print("XDMF file output not supported in parallel without HDF5")
out_u1.write(u1, encoding)
out_u2.write(u2, encoding)
out_sub1.write(sol1, encoding)
out_sub2.write(sol2, encoding)
Where I replaced the ‘MeshView’ functions on lines 11 and 12 with ‘SubMesh’ functions, and fixed the definition of the mixed function space V. These changes fixed the errors of old functions not existing, however running the code at that point produced the following error:
*** Error: Unable to define linear variational problem a(u, v) = L(v) for all v.
*** Reason: Expecting the boundary conditions to to live on (a subspace of) the trial space.
*** Where: This error was encountered inside LinearVariationalProblem.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 77c758717da1cb8017bf95109363bb1a91a4f8e5
To fix this, I added
And used these as the boundary conditions for solving the two functions independently and this at least stopped the above error, however I am now getting an assertion error suggesting that the length of the u1 and sol1 vectors are not the same. This leads me to believe that I either set up the submeshes incorrectly, or this boundary condition workaround was not the right way to fix the error I encountered, any ideas what my problem here is?
