I saw the Poisson equation of two domains with boundaries in Multiphenics and wanted to write relevant code using mixedfunction in Fenics. After applying the Lagrange multiplier at the boundary, the following problems occurred. Why is that?
mesh = UnitSquareMesh(20,20)
mesh_dom = MeshFunction("size_t",mesh,mesh.topology().dim(),0)
marker = MeshFunction("size_t",mesh,mesh.topology().dim()-1,0)
for f in facets(mesh):
marker[f] = 0.5 - DOLFIN_EPS < f.midpoint().y() < 0.5 + DOLFIN_EPS
class zone1(SubDomain):
return between(x[1],(0.5,1.))
zone1().mark(mesh_dom,1)
submesh1 = MeshView.create(marker,1)
submesh2 = MeshView.create(mesh_dom,0)
submesh3 = MeshView.create(mesh_dom,1)
# plot(submesh3)
# plot(submesh2)
# plot(submesh1)
# plt.show()
u = FunctionSpace(submesh2,"CG",1)
v = FunctionSpace(submesh3,"CG",1)
l = FunctionSpace(submesh1,"CG",1)
W = MixedFunctionSpace(u,v,l)
dU = Measure("dx",domain=W.sub_space(0).mesh())
dV = Measure("dx",domain=W.sub_space(1).mesh())
dL = Measure("dS",domain=W.sub_space(2).mesh())
(u1,v1,l1) = TrialFunctions(W)
(du,dv,dl) = TestFunctions(W)
w = Function(W)
def boundary(x):
return x[1] < DOLFIN_EPS
bc = DirichletBC(u, Constant(0.0), boundary)
#定义变分问题
a1 = inner(grad(u1),grad(du))*dU + l1("-")*du("-")*dL
a2 = inner(grad(v1),grad(dv))*dV - l1("+")*dv("+")*dL
a3 = u1("-")*dl("-")*dL - v1("+")*dl("+")*dL
a = a1+a2+a3
L = du*dU + dv*dV+Constant(0.)*dl*dL
Eu = a
solve(a2 == L,w,bc)
plot(w.sub(0))
The specific error forms are as follows
File "/mnt/d/pythonProject1/mixed_poisson.py", line 72, in <module>
solve(a2 == L,w,bc)
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py", line 233, in solve
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py", line 258, in _solve_varproblem
problem = MixedLinearVariationalProblem(eq_lhs_forms, eq_rhs_forms, u._functions, bcs,
File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/problem.py", line 94, in __init__
assert (len(a) == len(u) * len(u))
AssertionError
I found that the error might lie in the writing of the variational form. However, this variational form is almost the same as that in the original source code, which is really strange.
a = [[inner(grad(u1), grad(v1))*dx(1), 0 , l("-")*v1("-")*dS ],
[0 , inner(grad(u2), grad(v2))*dx(2), - l("+")*v2("+")*dS ],
[m("-")*u1("-")*dS , - m("+")*u2("+")*dS , 0 ]]
f = [v1*dx(1) , v2*dx(2) , 0 ]
