Problem with conda install?
Just installed FEniCS (2019) via conda on a new machine (MacOS), but my expressions cannot be jit compiled:
petscsys.h:163:6: error: “PETSc was configured with one MPICH mpi.h version but now appears to be compiling using a different MPICH mpi.h version”
Same procedure worked fine on my other computer. Any idea? Thanks!
Found the MWE! And the fix!! This code worked fine on previous conda install:
import dolfin
module = dolfin.compile_cpp_code('''\
#include <dolfin/function/Function.h>
PYBIND11_MODULE(SIGNATURE, m){}''')
But now it fails.
However, after installing with
conda create -n fenics -c conda-forge fenics mpich=3.3
it works fine. So maybe this should be prescribed somewhere?
