Problem with coupled boundary conditions
Hello everyone,
I am working on incorporating a time-varying boundary condition into my PDE problem using FEniCSx. The weak form of my problem is as follows:
the weak form of the my problem is as follows:
\int_{domain} w(s) \left( \mu \mathbf{\ddot{r}(s)} - \mu \mathbf{g} \right) \, ds + \int_{domain} EA \left( \frac{\|\mathbf{r}'(s)\|_2 - 1}{\|\mathbf{r}'(s)\|_2} \mathbf{r}'(s) \right) \frac{d w(s)}{d s} \, ds - w(s) \mathbf{T}(s) \Big|_0^L = 0
The boundary conditions are dirlchet at s = 0 and at s = L is differential equation which is ,
-m \ddot{\mathbf{r}(l)} - \mathbf{T}(l) + m\mathbf{(g)} = 0`
In my FEniCSx implementation, I took the finite difference of the time derivative and wrote the variational form. I replaced T(L) in the weak form with the boundary condition. Here’s the corresponding code snippet:
# Weak form
F = (
      ufl.inner(mu * ((r - 2 * r_n + r_n1) / dt**2),w)*ufl.dx - ufl.inner(mu*g,w)* ufl.dx
    + EA * ufl.inner(((norm_r_prime - 1) / norm_r_prime) * r_prime, ufl.grad(w)) * ufl.dx
    - ufl.inner(md* ((r - 2 * r_n + r_n1) / dt**2 ) - md*g,w)*ufl.ds
Could anyone advise if this is the right way to handle the time-varying boundary condition that is coupled with the weak form?
Thank you in advance for any insights or corrections!
Blockquote
What about considering the methods used in
http://jsdokken.com/FEniCS-workshop/src/form_compilation.html
or
https://jsdokken.com/dolfinx-tutorial/chapter2/ns_code2.html
Thanks for sharing.I have gone through them.Those problems are catered towards linear problem.
Is there any similar resources for nonlinear problems?i tried Newton solver to solve the variational form i have outlined in above post but it is not converging.
The boundary conditions for a non-linear problem doesn’t really change how they should be set up.
Without having a code/implementation to consider, it is hard to give any further guidance.
here is the code snippet of my problem.I have written a variational form of my problem and setup a newton solver to solve it.
from dolfinx import mesh, fem ,default_real_type
from basix.ufl import element
import ufl.coefficient
from dolfinx.fem import dirichletbc
from dolfinx import default_real_type
# Create 1D mesh for s in [0, L]
L = 1.0  # Length of the domain
num_elements = 100  # Number of elements in the 1D mesh
domain = mesh.create_interval(MPI.COMM_WORLD, num_elements, [0, L])
# Define a vector function space in 3D (Lagrange element of degree 1)
#element =ufl.element("Lagrange", domain.ufl_cell(), 1, dim=3)
typeelement = element("Lagrange", domain.basix_cell(),1,shape = (3,) ,dtype=default_real_type)
V = fem.functionspace(domain, typeelement)
r = fem.Function(V)  # Solution function (trial function)
w = ufl.TestFunction(V)  # Test function
r_prime = ufl.grad(r) [:,0]
norm_r_prime = ufl.sqrt(ufl.inner(r_prime, r_prime))
# Define constants
mu = fem.Constant(domain, 0.1)  # Mass density, example value
md = fem.Constant(domain, 1.0)
EA = fem.Constant(domain, 10000.0 ) # Stiffness, example value
gr= np.transpose([0,-9.81,0])
g = ufl.as_vector(gr)  # Gravity vector in 3D
# Fix r at s = 0 to be zero (Dirichlet condition)
def left_boundary(x):
    return np.isclose(x[0], 0)
#u_bc_left = ufl.as_vector( np.transpose([0,0,0]))
u_bc_left = fem.Constant(domain, PETSc.ScalarType((0.0, 0.0, 0.0)))
left_bc = dirichletbc(u_bc_left, fem.locate_dofs_geometrical(V, left_boundary), V)
bcs = [left_bc]
dt = 0.01  # Time step size
t = 0.0
T_end = 2  # Final time
# Define the nonlinear term T(s)
T = EA * ((norm_r_prime - 1) / norm_r_prime) * r_prime
# Time-dependent acceleration term (assuming some finite difference approximation for r_ddot)
r_n = fem.Function(V)  # Solution at previous time step
r_n1 = fem.Function(V)
r_n.interpolate(lambda x: np.vstack((x[0], 0 * x[0], 0 * x[0])))
r_n1.x.array[:] = r_n.x.array  # Zero initial velocity
# Weak form definition
F = (
    +EA * ufl.inner(((norm_r_prime - 1) / norm_r_prime) * r_prime, ufl.grad(w)) * ufl.dx
    + ufl.inner(md* ((r - 2 * r_n + r_n1) / dt**2 ) - md*g,w)*ufl.ds
# Create nonlinear problem
problem = NonlinearProblem(F, r, bcs)
# Create solver
solver.atol = 1e-2
solver.rtol = 1e-2
# Time-stepping loop
while t < T_end:
    # Update r_ddot (acceleration term) based on finite difference
    solver.solve(r)
    print(t)
    # Update previous solutions
    r_n1.x.array[:], r_n.x.array[:] =r_n.x.array, r.x.array
    # Update time
with XDMFFile(domain.comm, "solution.xdmf", "w") as file:
    file.write_mesh(domain)
    file.write_function(r)
I tried varying the timestep and error tolerance but it didn,t worked.
Adding:
dolfinx.log.set_log_level(dolfinx.log.LogLevel.DEBUG)
prior to your loop, you will get the output:
[2024-11-21 14:12:59.423] [info] Newton iteration 0: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.424] [info] PETSc Krylov solver starting to solve system.
[2024-11-21 14:12:59.424] [debug] Elapsed wall, usr, sys time: 0.000000, 0.000000, 0.000000 (PETSc Krylov solver)
[2024-11-21 14:12:59.424] [info] Newton iteration 1: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.424] [info] Newton iteration 2: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.424] [info] Newton iteration 3: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.424] [info] Newton iteration 4: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.424] [info] Newton iteration 5: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.424] [info] Newton iteration 6: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.425] [debug] Elapsed wall, usr, sys time: 0.000000, 0.000000, 0.000000 (PETSc Krylov solver)
[2024-11-21 14:12:59.425] [info] Newton iteration 7: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.425] [info] PETSc Krylov solver starting to solve system.
[2024-11-21 14:12:59.425] [info] Newton iteration 8: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.425] [info] Newton iteration 9: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.425] [info] Newton iteration 10: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.425] [info] Newton iteration 11: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.425] [info] Newton iteration 12: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.425] [info] Newton iteration 13: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.425] [info] Newton iteration 14: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.425] [info] Newton iteration 15: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.426] [info] PETSc Krylov solver starting to solve system.
[2024-11-21 14:12:59.426] [debug] Elapsed wall, usr, sys time: 0.000000, 0.000000, 0.000000 (PETSc Krylov solver)
[2024-11-21 14:12:59.426] [info] Newton iteration 16: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.426] [info] Newton iteration 17: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.426] [info] Newton iteration 18: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.426] [info] Newton iteration 19: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.426] [info] Newton iteration 20: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.426] [info] Newton iteration 21: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.426] [info] Newton iteration 22: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.426] [info] Newton iteration 23: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.426] [info] Newton iteration 24: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.427] [info] PETSc Krylov solver starting to solve system.
[2024-11-21 14:12:59.427] [debug] Elapsed wall, usr, sys time: 0.000000, 0.000000, 0.000000 (PETSc Krylov solver)
[2024-11-21 14:12:59.427] [info] Newton iteration 25: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.427] [info] Newton iteration 26: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.427] [info] Newton iteration 27: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.427] [info] Newton iteration 28: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.427] [info] Newton iteration 29: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.427] [info] Newton iteration 30: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.427] [info] Newton iteration 31: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.427] [info] Newton iteration 32: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.428] [info] Newton iteration 33: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.428] [info] PETSc Krylov solver starting to solve system.
[2024-11-21 14:12:59.428] [debug] Elapsed wall, usr, sys time: 0.000000, 0.000000, 0.000000 (PETSc Krylov solver)
[2024-11-21 14:12:59.428] [info] Newton iteration 34: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.428] [info] Newton iteration 35: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.428] [info] Newton iteration 36: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.428] [info] Newton iteration 37: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.428] [info] Newton iteration 38: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.428] [info] Newton iteration 39: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.428] [info] Newton iteration 40: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] Newton iteration 41: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] PETSc Krylov solver starting to solve system.
[2024-11-21 14:12:59.429] [debug] Elapsed wall, usr, sys time: 0.000000, 0.000000, 0.000000 (PETSc Krylov solver)
[2024-11-21 14:12:59.429] [info] Newton iteration 42: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] Newton iteration 43: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] Newton iteration 44: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] Newton iteration 45: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] Newton iteration 46: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] Newton iteration 47: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] Newton iteration 48: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] Newton iteration 49: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:12:59.429] [info] Newton iteration 50: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
  File "/root/shared/mwe.py", line 87, in <module>
    solver.solve(r)
  File "/usr/local/dolfinx-real/lib/python3.12/dist-packages/dolfinx/nls/petsc.py", line 51, in solve
    n, converged = super().solve(u.x.petsc_vec)
RuntimeError: Newton solver did not converge because maximum number of iterations reached
which means that your solver don’t even converge for the first iteration.
We can then add the following options to get deeper into the problem:
solver.krylov_solver.setType("preonly")
solver.krylov_solver.getPC().setType("lu")
solver.krylov_solver.getPC().setFactorSolverType("mumps")
solver.krylov_solver.setErrorIfNotConverged(True)
yielding
[2024-11-21 14:14:45.932] [info] Newton iteration 0: r (abs) = -nan (tol = 0.01), r (rel) = -nan (tol = 0.01)
[2024-11-21 14:14:45.932] [info] PETSc Krylov solver starting to solve system.
[2024-11-21 14:14:45.934] [info] PETSc error in '/src/dolfinx/cpp/dolfinx/la/petsc.cpp', 'KSPSolve'
[2024-11-21 14:14:45.934] [info] PETSc error code '76' 'Error in external library'
[2024-11-21 14:14:45.934] [debug] Elapsed wall, usr, sys time: 0.000000, 0.000000, 0.000000 (PETSc Krylov solver)
  File "/root/shared/mwe.py", line 92, in <module>
    solver.solve(r)
RuntimeError: Failed to successfully call PETSc function 'KSPSolve'. PETSc error code is: 76, Error in external library
We next assemble the residual F prior to the loop:
print(dolfinx.fem.assemble_vector(dolfinx.fem.form(F)).array)
yielding
array([nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan,
       nan, nan, nan, nan])
which means that something in F is singular.
One thing that stands out is that you define r_prime twice:
and your initial r is zero everwhere, meaning that dividing by norm_r_prime gives you something singular.
I hope this can serve as a guide on how to debug time dependent, non-linear problems in the future.
Thank you for your insight about debugging.i just initialized r with non zero value and problem got resolved.
