I’m new to FEniCSx and have been learning by solving some scalar-valued PDEs, which I managed to do successfully using the provided documentation. However, I’m currently facing issues when working with vector PDEs,
specifically in creating 3D vector elements.Below is the code snippet
domain = mesh.create_interval(MPI.COMM_WORLD, num_elements, [0, L])
typeelement = element("Lagrange", domain.basix_cell(), 1,shape = (3,) ,dtype=default_real_type)
V = fem.functionspace(domain, typeelement)
r = fem.Function(V) # Solution function (trial function)
r_prime = ufl.grad(r)
norm_r_prime = ufl.sqrt(ufl.dot(r_prime, r_prime))
when i run the above code,the error is shown as following.
return Dot(a, b)
raise ValueError("Dimension mismatch in dot product.")
can you please help me with resolving this issue and it.
Thank you it worked.But i got another two problems:
first,
the shape of r_prime is (3,1,1). whereas ‘r’ and testfunction ’ w’ is of (3,1),.which is same as defined.The problem is that i am not able to do ufl.inner(w,r_prime) because of shape difference.Can please help me to convert r_prime to 3x1 vector.
and second question is unrelated to this, which is defining constant (3x1) vector.
example snippet is
