What happened to VectorElement?
What has become of VectorElement? It is referenced in the ufl documentation and this tutorial but I can’t find its definition in the latest ufl version.
On the main branch of DOLFINx, ufl.VectorElement has been replaced with basix.ufl.element(family, cell, degree, shape=(N,))
to create a N-dimensional vector space for a given Finite element family.
what about the fem.VectorFunctionSpace is it also updated
See: Add shape argument to `FunctionSpace` for creating blocked scalar element spaces by garth-wells · Pull Request #2766 · FEniCS/dolfinx · GitHub
as it highlights the api change
i have tried used the command
from dolfinx.fem import (Expression, Function, FunctionSpaceBase, dirichletbc,
form, functionspace, locate_dofs_topological)
i am using FEniCSx on Colab research
ImportError Traceback (most recent call last)
in <cell line: 1>()
----> 1 from dolfinx.fem import (Expression, Function, FunctionSpaceBase, dirichletbc,
2 form, functionspace, locate_dofs_topological)
3
4 shape = (gdim,)
5 Vu = dolfinx.fem.functionspace(mesh, (‘CG’, 2, shape))
ImportError: cannot import name ‘FunctionSpaceBase’ from ‘dolfinx.fem’ (/usr/local/lib/python3.10/dist-packages/dolfinx/fem/init.py)
Just remove FunctionSpaceBasee as an import. That is what your error message is stating isn’t defined
hi dokken,
i have even tried that and not able to create the vector functional space
we have
gdim = mesh.geometry.dim
M = functionspace(mesh, (“Lagrange”, 1, (gdim,)))
AttributeError Traceback (most recent call last)
in <cell line: 1>()
----> 1 M = functionspace(mesh, (“Lagrange”, 1, (gdim,)))
2
3 u = ufl.TrialFunction(Vu)
4 v = ufl.TestFunction(Vu)
5
/usr/local/lib/python3.10/dist-packages/dolfinx/fem/function.py in functionspace(mesh, element, form_compiler_options, jit_options)
592 ufl_e = basix.ufl.element(
593 e.family,
→ 594 mesh.basix_cell(),
595 e.degree,
596 shape=e.shape,
AttributeError: module ‘dolfinx.mesh’ has no attribute ‘basix_cell’
i am using FEniCSx on google colab
try:
except ImportError:
!wget “https://fem-on-colab.github.io/releases/fenicsx-install-real.sh” -O “/tmp/fenicsx-install.sh” && bash “/tmp/fenicsx-install.sh”
Could you provide a minimal reproducible example, which I can run myself, as it Seems like you are not sending in mesh correctly, But i cannot be certain as you haven’t included all imports and definitions
you surely have a from dolfinx import mesh at the top of your file, and are not creating the actual mesh (or maybe you are creating it, but calling it msh or domain)
Note that screenshot is from the “latest” UFL document.
But:
$ python
Python 3.13.0 | packaged by conda-forge | (main, Oct  8 2024, 20:04:32) [GCC 13.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import ufl
>>> ufl.__version__
'2024.2.0'
>>> ufl.VectorElement
  File "<python-input-2>", line 1, in <module>
    ufl.VectorElement
AttributeError: module 'ufl' has no attribute 'VectorElement'
Moreover, google returns no hits for:
'2024.2.0' site:https://fenics.readthedocs.io
Here is my environment.yml file for conda:
channels:
  - nvidia
  - conda-forge
  - default
dependencies:
  - fenics-dolfinx
  - python-gmsh
  - pyvista
  - scipy
  - petsc4py
  - fenics-ufl
  - cuda-toolkit
That is not the latest documentation. That page is for the latest ufl compatible with dolfin.
For the latest documentation see https://docs.fenicsproject.org/
