But I did define c as c = TrialFunction(W). Below is the entire code along with the gmsh script of the geometry.
Python script:
from dolfin import Mesh, XDMFFile, File, MeshValueCollection, cpp
"eliminate_zeros": True, \
"precompute_ip_const": True}
import numpy
out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
if prune_z:
out_mesh.prune_z_0()
return out_mesh
msh = meshio.read("intimapdgf.msh")
triangle_mesh = create_mesh(msh, "triangle", True)
line_mesh = create_mesh(msh, "line", True)
meshio.write("mf.xdmf", line_mesh)
mesh = Mesh()
infile.read(mesh)
ds_custom = Measure("ds", domain=mesh, subdomain_data=mf)
# Normal vector to the intima
W = FunctionSpace(mesh, "Lagrange", 1)
# Define boundary condition and neumann boundary functions
D, k, t = 0.7, 0.3, 3
f0, ts = 5, 2
gamma1 = (-1/D)*Constant(f0*t/(ts + t)) # Neumann condition on inner curve -dot(grad(c),n)=gamma1
gamma2 = Constant(0.0) # Dirichlet condition on outer circle
bc2 = DirichletBC(W, gamma2, mf, 2)
bcs=[bc2]
w = TestFunction(W)
c = Function(W)
a = inner(grad(c), grad(w))*dx
a -= -((((k/D)*c)*w)*dx) - inner(gamma1, w)*ds_custom(1)
# Compute solution
solve(a == 0, c, bcs)
# Save solution to file in PVD format for Paraview
file = File("intimapdgf.pvd");
file << c;
gmsh script:
SetFactory("OpenCASCADE");
Circle(2) = {0, 0, 0, 3, 0, 2*Pi};
Point(3) = {-1.6, 0.3, 0, 1.0};
Point(4) = {-1.4, -0.7, 0, 1.0};
Point(5) = {-1.1, -1.3, 0, 1.0};
Point(6) = {-0.3, -1.7, 0, 1.0};
Point(7) = {0.8, -2.1, 0, 1.0};
Point(8) = {1.7, -1.3, 0, 1.0};
Point(9) = {1.7, -0.4, 0, 1.0};
Point(10) = {1.9, 0.5, 0, 1.0};
Point(11) = {1.6, 1.2, 0, 1.0};
Point(12) = {0.9, 1.5, 0, 1.0};
Point(13) = {0, 1.5, 0, 1.0};
Point(14) = {-0.6, 0.9, 0, 1.0};
Spline(3) = {3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 3};
Physical Curve("C2", 2) = {2};
Physical Curve("C3", 3) = {1};
Hide "*";
Show {
Point{3}; Curve{3};
Curve Loop(1) = {2};
Curve Loop(2) = {3};
Plane Surface(1) = {1, 2};
Hide "*";
Show {
Point{1}; Point{2}; Point{3}; Curve{1}; Curve{2}; Curve{3};
Curve Loop(3) = {1};
Curve Loop(4) = {2};
Plane Surface(2) = {3, 4};
Show "*";
Physical Surface("intima", 4) = {1};
Hide "*";
Show {
Point{1}; Point{2}; Point{3}; Curve{1}; Curve{2}; Curve{3}; Surface{1}; Surface{2};
Physical Curve("C1", 1) = {3};
