jw3126
September 17, 2019, 12:18pm
1
I would like to solve a PDE system, where some quantities are vectors and others are scalars.
As an example I tried to do the following variant of the Poisson equation:
q = -k * grad(T)
div(q) = f
Here is what I tried:
mesh = UnitIntervalMesh(10)
Vscalar = FunctionSpace(mesh, "P", 2)
Vvector = VectorFunctionSpace(mesh, "P", 2)
vs = TestFunction(Vscalar)
vv = TestFunction(Vvector)
T = TrialFunction(Vscalar)
q = TrialFunction(Vvector)
k = Constant(1.0)
f = Constant(6.0)
F = dot(k*grad(T) + q, vv) * dx + dot(div(q) - f, vs) * dx
bc = DirichletBC(Vscalar, Constant(0.0), "on_boundary")
u = (Function(Vscalar), Function(Vvector))
solve(F == 0, u, bc)
This does not work however, my definition of u is not correct.
I think that you are already close to the correct solution. Instead of
jw3126:
Vscalar = FunctionSpace(mesh, “P”, 2)
Vvector = VectorFunctionSpace(mesh, “P”, 2)
use
Vscalar = FiniteElement("Lagrange", mesh.ufl_cell(), 2) # use quadratic temperature triangle
Vvector = VectorElement("Lagrange", mesh.ufl_cell(), 1) # use linear flux
Vmixed = FunctionSpace(mesh, Vscalar * Vvector)
T, q = TrialFunctions(Vmixed)
vs, vv = TestFunctions(Vmixed)
Be aware that for mixed FEM the function spaces have to “match”, otherwise you might get into trouble.
For boundary conditions use:
bc = DirichletBC(Vmixed.sub(0), Constant(0.0), "on_boundary")
Finally, solve
mixed_u = Function(Vmixed)
u, q = mixed_np1.split()
solve(lhs(F) == rhs(F), mixed_u, bc)
For more details see the tutorial on mixed formulation of the poisson equation .
jw3126
September 17, 2019, 2:48pm
3
Thanks very much! I updated my code:
mesh = UnitIntervalMesh(4)
el_scalar = FiniteElement("Lagrange", mesh.ufl_cell(), 2) # use quadratic temperature triangle
el_vector = VectorElement("Lagrange", mesh.ufl_cell(), 1) # use linear flux
el = MixedElement([el_scalar, el_vector])
Vmixed = FunctionSpace(mesh, el)
Vscalar = Vmixed.sub(0)
Vvector = Vmixed.sub(1)
k = Constant(1.0)
f = Constant(2.0)
F = dot(k*grad(T) + q, vv) * dx + dot(q, grad(vs)) * dx - f * vs * dx
solve(lhs(F) == rhs(F), u, bc)
T, q = u.split()
np.asarray(T.vector())
array([ 0.00000000e+00, -inf, -5.00000000e-01,
inf, -1.00000000e+00, -inf,
1.15849359e-16, inf, -inf,
5.00000000e-01, inf, 0.00000000e+00,
inf, 1.00000000e+00])
I have a couple of follow up questions:
The solution contains inf and is nonsense. Is there maybe an issue with the boundary condition?
If I change the solve into solve(F == 0, u, bc) I get an error:
ArityMismatch: Adding expressions with non-matching form arguments ('v_0',) vs ('v_0', 'v_1').
why?
Edit: I opened a new question about the ArityMismatch.
jw3126
September 17, 2019, 3:54pm
4
If I change the order of the elements to
el_scalar = FiniteElement("P", mesh.ufl_cell(), 1) # was 2 before
el_vector = VectorElement("P", mesh.ufl_cell(), 1)
The solution looks sane:
