I have noticed something strange with GMSH boundary markers. They work with Dirichlet BCs but not with ds. I have the following GMSH file made by GMSH 3.0.4:
// Gmsh project created on Sat Aug 20 11:37:10 2022
Point(1) = {0, 0, 0, 1.0};
Point(2) = {0.000025, 0, 0, 1.0};
Point(3) = {-0.000025, 0, 0, 1.0};
Point(4) = {0, 0.000015, 0, 1.0};
Point(5) = {0, -0.000015, 0, 1.0};
Point(6) = {0.00002, 0, 0, 1.0};
Point(7) = {0.0000225, 0, 0, 1.0};
Point(8) = {0.0000175, 0, 0, 1.0};
Point(9) = {0.00002, 0.0000025, 0, 1.0};
Point(10) = {0.00002, -0.0000025, 0, 1.0};
Ellipse(1) = {4, 1, 2, 3};
Ellipse(2) = {4, 1, 3, 2};
Ellipse(3) = {5, 1, 3, 2};
Ellipse(4) = {5, 1, 2, 3};
Circle(5) = {7, 6, 9};
Circle(6) = {9, 6, 8};
Circle(7) = {8, 6, 10};
Circle(8) = {10, 6, 7};
Line Loop(1) = {2, -3, 4, -1};
Line Loop(2) = {6, 7, 8, 5};
Plane Surface(1) = {1, 2};
Plane Surface(2) = {2};
Physical Line(1) = {2, 1, 4, 3};
Physical Line(2) = {7, 6, 5, 8};
Physical Surface(3) = {1};
Physical Surface(4) = {2};
Then I use dolfin-convert to get the corresponding XML files. Then I use the MWE below to convert them to xdmf and check the boundaries.
#Reading the .xml files
mesh = Mesh("Mesh.xml")
Volume = MeshFunction("size_t", mesh, "Mesh_physical_region.xml")
bnd_mesh = MeshFunction("size_t", mesh, "Mesh_facet_region.xml")
#Converting to .xmdf and Saving
xdmf = XDMFFile(mesh.mpi_comm(),"Mesh.xdmf")
xdmf.write(mesh)
xdmf.write(Volume)
xdmf = XDMFFile(mesh.mpi_comm(),"boundaries.xdmf")
xdmf.write(bnd_mesh)
xdmf.close()
#Reading the mesh
mesh= Mesh()
xdmf = XDMFFile(mesh.mpi_comm(), "Mesh.xdmf")
xdmf.read(mesh)
with XDMFFile("Mesh.xdmf") as infile:
infile.read(mvc, "f")
Volume = cpp.mesh.MeshFunctionSizet(mesh, mvc)
xdmf.close()
mvc2 = MeshValueCollection("size_t", mesh, 1)
with XDMFFile("boundaries.xdmf") as infile:
infile.read(mvc2, "f")
bnd_mesh = cpp.mesh.MeshFunctionSizet(mesh, mvc2)
#Defining the measures
dx = dx(metadata={'quadrature_degree': 2},
subdomain_data=Volume)
ds = ds(metadata={'quadrature_degree': 2},
subdomain_data=bnd_mesh)
#Testing Dirichlet
S = FunctionSpace(mesh,'P',1)
f = Function(S)
bc1 = DirichletBC(S, Constant(1), bnd_mesh,1)
bc2 = DirichletBC(S, Constant(2), bnd_mesh,2)
bcs = [bc1,bc2]
for bc in bcs:
bc.apply(f.vector())
File('test/f.pvd')<<f
#Testing ds
R = FunctionSpace(mesh,'R',0)
a_1 = project(Constant(1),R)
Domain_vol = project(assemble(a_1*ds(1)),R)
print(Domain_vol.vector().get_local())
Domain_vol = project(assemble(a_1*ds(2)),R)
This does the value assignments using the Dirichlet BCs for both boundaries correctly. Also the first assemble runs without any issues. But for the second one I get the following error:
*** Error: Unable to assemble system.
*** Reason: expected a linear form for L.
*** Where: This error was encountered inside SystemAssembler.cpp.
*** Process: 0
*** Git changeset: f0a90b8fffc958ed612484cd3465e59994b695f9
I am certain something is wrong with ds, but I cannot figure it out. I would really appreciate it if you could help me with this.
