Hi all,
I am having the following error when I try to assign the boundary markers:
Error : Unknown OpenCASCADE entity of dimension 2 with tag -1
The simplified version of my code is:
# Geometry
L = 1
H = 0.05
if rank == 0:
fluid = gmsh.model.occ.addBox(-L/2, -H/2, -H/2, L, H, H)
gmsh.model.occ.synchronize()
# Domain markers
fluid_marker = 1
if rank == 0:
gmsh.model.addPhysicalGroup(volumes[0][0], [volumes[0][1]], fluid_marker)
gmsh.model.setPhysicalName(volumes[0][0], fluid_marker, "Fluid")
# Boundary markers
inlet_marker = 2
outlet_marker = 3
walls_marker = 5
inlet = []
outlet = []
walls = []
if rank == 0:
boundaries = gmsh.model.getBoundary(volumes)
for boundary in boundaries:
The error refers to the last line of the previous code: center_of_mass = gmsh.model.occ.getCenterOfMass(boundary[0], boundary[1])
Therefore, I printed the variable boundaries
to see what is happening:
print(boundaries)
[(2, -1), (2, 2), (2, -3), (2, 4), (2, -5), (2, 6)]
As you can see, there are three negative indices that are causing the error (the output should be [(2, 1), (2, 2), (2, 3), (2, 4), (2, 5), (2, 6)])
The dolfinx version that I am using is:
0.3.0 35d705001bdd42b859ac7f32f124cbf9a41d9b3b
Does anybody know what I am doing wrong?
Thank you very much in advance.
