Hello, I installed a Docker fenics constainer via
docker run -ti -v $(pwd):/home/fenics/shared quay.io/fenicsproject/dev
I then start and attach the container, and try to run a the following file generate_mesh.py that generates the mesh for a FE problem
import numpy
import pygmsh
import argparse
However, I get the following error message
$ python3 generate_mesh.py
File "generate_mesh.py", line 4, in <module>
import pygmsh
File "/usr/local/lib/python3.6/dist-packages/pygmsh/__init__.py", line 1, in <module>
from . import geo, occ
File "/usr/local/lib/python3.6/dist-packages/pygmsh/geo/__init__.py", line 1, in <module>
from .geometry import Geometry
File "/usr/local/lib/python3.6/dist-packages/pygmsh/geo/geometry.py", line 4, in <module>
File "/usr/local/lib/python3.6/dist-packages/gmsh.py", line 86, in <module>
lib = CDLL(libpath)
File "/usr/lib/python3.6/ctypes/__init__.py", line 348, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libGLU.so.1: cannot open shared object file: No such file or directory
Do you know what is wrong here ? Thank you!
