Hi all,
I have a problem simulating the inflation of a hyper-elastic membrane to increasing pressures.
Since I’m new in Fenics, I started from the demo code (https://fenicsproject.org/docs/dolfin/1.4.0/python/demo/documented/hyperelasticity/python/documentation.html) and adapt it as follows:
import pdb
"eliminate_zeros": True, \
"precompute_ip_const": True}
mesh = BoxMesh(Point(0.0, 0.0, 0.0),Point(1.0, 0.05, 1.0), 20, 10, 20)
#UnitCubeMesh(24, 16, 16)
N = FacetNormal(mesh)
# Mark boundary subdomians
left = CompiledSubDomain("near(x[0], side) && on_boundary", side = 0.0)
right = CompiledSubDomain("near(x[0], side) && on_boundary", side = 1.0)
top = CompiledSubDomain("near(x[1], side) && on_boundary", side = 0.05)
bottom = CompiledSubDomain("near(x[1], side) && on_boundary", side = 0.0)
front = CompiledSubDomain("near(x[2], side) && on_boundary", side = 1.0)
back = CompiledSubDomain("near(x[2], side) && on_boundary", side = 0.0)
# Define Dirichlet boundary (x = 0 or x = 1)
c = Expression(("0.0", "0.0", "0.0"),degree=3)
bcb = DirichletBC(V, c, bottom)
bct = DirichletBC(V, c, top)
bcl = DirichletBC(V, c, left)
bcr = DirichletBC(V, c, right)
bcf = DirichletBC(V, c, front)
bcba = DirichletBC(V, c, back)
#bcr = DirichletBC(V, r, right)
bcs = [bcl, bcr,bcf,bcba]
# Define functions
du = TrialFunction(V) # Incremental displacement
v = TestFunction(V) # Test function
u = Function(V) # Displacement from previous iteration
B = Constant((0.0, 0.0, 0.0)) # Body force per unit volume
T = Constant((0.0, 0.0, 0.0)) # Traction force on the boundary
# Kinematics
d = u.geometric_dimension()
I = Identity(d) # Identity tensor
# Elasticity parameters
E, nu = 10.0, 0.3
mu, lmbda = Constant(E/(2*(1 + nu))), Constant(E*nu/((1 + nu)*(1 - 2*nu)))
file = File("results/displacement.pvd");
dt=0.05
p_f=1
p_0=0.01
NN=(p_f-p_0)/dt
pressures=np.linspace(p_0,p_f,int(NN))
for p in pressures:
print()
print('pressure: ',p)
T = Constant((0.0, p, 0.0)) # Body force per unit volume
Finv=inv(F)
Ic = tr(C)
J = det(F)
n = J*Finv.T*N
psi = (mu/2)*(Ic - 3) - mu*ln(J) + (lmbda/2)*(ln(J))**2
pr=Constant((p))
# Total potential energy
Pi = psi*dx - dot(B, u)*dx - dot(T, u)*ds - dot(u,pr*n)*ds
#Pi = psi*dx - dot(B, u)*dx - dot(u,pr*n)*ds
# Compute first variation of Pi (directional derivative about u in the direction of v)
F = derivative(Pi, u, v)
# Compute Jacobian of F
J = derivative(F, u, du)
# Solve variational problem
solve(F == 0, u, bcs, J=J,
form_compiler_parameters=ffc_options,
solver_parameters={
"newton_solver":{\
"relaxation_parameter":0.5,
"relative_tolerance":1e-6 ,
"maximum_iterations":100,
#pdb.set_trace()
file << (u,p);
The idea of the for loop is that by increasing the pressure progressively, a partial solution can be computed and then used as an initial point for the next step.
I am not sure how to implement the internal pressure forces. I tried two approaches:
Changing the value to T = Constant((0.0, p, 0.0)), where p is the pressure value. This method results in applying forces to each cell at the boundary surface:
As pressure can be seen as a force that is applied normal to the surface, I used the following (following implementation of neuman bc from Fenics mechancis based on Nanson’s formula ):
Pi = psi*dx - dot(B, u)dx - dot(u,prn)*ds. This results in a weirdly deformed membrane
I would appreciate any hints on the implementation of an inflatable membrane.
Sorry if the question/solution is obvious but my understanding of finite element is limited.
Thanks
