Thank you, I thought it would be downloaded automatically. I tried some things and it didn’t work so a deleted and re-installed Miniconda. Now when trying to
conda install -c conda-forge fenics-dolfinx
I get
Found conflicts! Looking for incompatible packages.
This can take several minutes. Press CTRL-C to abort.
failed
UnsatisfiableError: The following specifications were found
to be incompatible with the existing python installation in your environment:
Specifications:
- fenics-dolfinx -> python[version='2.7.*|3.5.*|3.6.*|3.6.12|3.6.12|3.7.10|3.7.10|3.7.12|3.8.12|3.8.16|3.9.16|>=3.11,<3.12.0a0|3.9.10|>=3.6,<3.7.0a0|3.7.9|3.6.9|3.6.9|3.6.9|>=2.7,<2.8.0a0|3.6.9|>=3.5,<3.6.0a0|3.4.*|>=3.7|3.10.*|3.9.*|3.8.*|3.7.*',build='0_73_pypy|1_73_pypy|3_73_pypy|4_73_pypy|5_73_pypy|5_73_pypy|1_73_pypy|0_73_pypy|0_73_pypy|2_73_pypy']
- fenics-dolfinx -> python[version='>=3.10,<3.11.0a0|>=3.9,<3.10.0a0|>=3.8,<3.9.0a0|>=3.7,<3.8.0a0']
Your python: python=3.11
If python is on the left-most side of the chain, that's the version you've asked for.
When python appears to the right, that indicates that the thing on the left is somehow
not available for the python version you are constrained to. Note that conda will not
change your python version to a different minor version unless you explicitly specify
that.
The following specifications were found to be incompatible with your system:
- feature:/linux-64::__glibc==2.31=0
- python=3.11 -> libgcc-ng[version='>=11.2.0'] -> __glibc[version='>=2.17']
Your installed version is: 2.31
Is dolfinx not compatible with Python 3.11 ? Or libgcc causes the problem ?
Hi Eloi. I have a similar issue. I can not import gmsh. I have installed gmsh 4.11 but the proble still exists. Does gmsh need to be installed before installing dolfinx?
