Problem with Projection
Dear all,
I’m trying to project the norm of the gradient of a solution into a function space. In the FEniCs version, this operation was possible using project(). In FEniCSx, this procedure is not as simple.
I followed a discussion (Find gradient of solution in dolfinx) on this subject and created a function for projection but I always get an error.
The equation I solve is the poisson equation with the source term zero
Here’s the function I’m using and the error
def normalizeAndProj_vec(u, mesh, V):
    Normalizes the gradient of the solution u and projects it into the specified V.
    Parameters:
    u (Function): The solution whose gradient is to be normalized.
    mesh (Mesh): The mesh on which the function is defined.
    V (FunctionSpace): The function space into which the normalized gradient is to be projected.
    Returns:
    Function: The normalized gradient projected into FiberSpace.
    # Calculate the gradient of u
    grad_u = grad(u)
    # Define the test and trial functions
    w = TrialFunction(V)
    # Define the variational problem for the projection
    a = inner(w, v) * dx
    L = inner(grad_u, v) * dx
    # Solve the projection problem
    grad_uh = fem.Function(V)
    problem = fem.petsc.LinearProblem(a, L)
    grad_uh = problem.solve()
    # Normalize the projected gradient
    norm_grad_uh = fem.Function(V)
    norm_uh_expr = grad_uh / sqrt(dot(grad_uh, grad_uh))
    # Interpolate the normalized gradient
    norm_grad_uh.interpolate(lambda x: norm_uh_expr.eval(x))
    return norm_grad_uh
the error
  File "/home/djoumessi/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ufl/operators.py", line 167, in inner
    return Inner(a, b)
  File "/home/djoumessi/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ufl/tensoralgebra.py", line 162, in __new__
    raise ValueError(f"Shapes do not match: {ufl_err_str(a)} and {ufl_err_str(b)}")
ValueError: Shapes do not match: <Grad id=139755148445568> and <Argument id=139756261500464>
I was wondering if there wasn’t a simple approach to this?
Thanks in advance.
The code you provided isn’t complete. The error is probably in how you define V when calling your normalizeAndProj_vec function, but we can only guess since you didn’t post the full code. See Read before posting: How do I get my question answered?
Say that V is a FE space for a scalar field, and hence u is a scalar field. When you ask grad(u), you are getting a vector field, and so you must be passing a FE space which is not V (scalar field), but the equivalent FE space of V for a vector field.
Thank you for your prompt reply.
sorry for the inconvenience.
I change the V to be a VectorFunctionSpace but I’ve another error,
Here is the MWE reproduicing the error.
Thanks
from dolfinx import mesh
from dolfinx.fem import functionspace, FunctionSpace, VectorFunctionSpace
from ufl import grad, TestFunction, TrialFunction, inner, dx, sqrt, dot
# create domain and function space
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
V = FunctionSpace(domain, ("Lagrange", 1))
FiberSpace = VectorFunctionSpace (domain, ("Lagrange", 1))
from dolfinx import fem
uD = fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
import numpy
# Create facet to cell connectivity required to determine boundary facets
tdim = domain.topology.dim
fdim = tdim - 1
boundary_dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
bc = fem.dirichletbc(uD, boundary_dofs)
u = ufl.TrialFunction(V)
f = fem.Constant(domain, default_scalar_type(-6))
# Bi and Linear form
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
# function for the projection
    Parameters:
    Returns:
    grad_u = grad(u)
    #norm_grad_uh.interpolate(lambda x: norm_uh_expr.eval(x))
    norm_grad_uh.interpolate(norm_uh_expr)
    return norm_grad_uh
Nr = normalizeAndProj_vec(uh, domain, FiberSpace)
Write the error within “```”.
here is the error
WARNING:py.warnings:/home/djoumessi/Bureau/IMT4/Fenicsx_tutorial/read_mesh/minimal/MWE.py:9: DeprecationWarning: This method is deprecated. Use FunctionSpace with an element shape argument instead
  File "/home/djoumessi/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/fem/function.py", line 397, in interpolate
    _interpolate(u, cells)
  File "/home/djoumessi/miniconda3/envs/fenicsx-env/lib/python3.12/functools.py", line 909, in wrapper
  File "/home/djoumessi/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/fem/function.py", line 373, in _interpolate
    self._cpp_object.interpolate(u, cells, nmm_interpolation_data)
TypeError: interpolate(): incompatible function arguments. The following argument types are supported:
    1. (self: dolfinx.cpp.fem.Function_float64, f: numpy.ndarray[numpy.float64], cells: numpy.ndarray[numpy.int32]) -> None
    2. (self: dolfinx.cpp.fem.Function_float64, u: dolfinx.cpp.fem.Function_float64, cells: numpy.ndarray[numpy.int32], nmm_interpolation_data: Tuple[List[int], List[int], List[float], List[int]]) -> None
    3. (self: dolfinx.cpp.fem.Function_float64, expr: dolfinx::fem::Expression<double, double>, cells: numpy.ndarray[numpy.int32]) -> None
Invoked with: <dolfinx.cpp.fem.Function_float64 object at 0x7f5181e4ccf0>, ComponentTensor(Division(Indexed(Coefficient(FunctionSpace(Mesh(blocked element (Basix element (P, quadrilateral, 1, gll_warped, unset, False), (2,)), 0), blocked element (Basix element (P, quadrilateral, 1, gll_warped, unset, False), (2,))), 3), MultiIndex((Index(8),))), Sqrt(Dot(Coefficient(FunctionSpace(Mesh(blocked element (Basix element (P, quadrilateral, 1, gll_warped, unset, False), (2,)), 0), blocked element (Basix element (P, quadrilateral, 1, gll_warped, unset, False), (2,))), 3), Coefficient(FunctionSpace(Mesh(blocked element (Basix element (P, quadrilateral, 1, gll_warped, unset, False), (2,)), 0), blocked element (Basix element (P, quadrilateral, 1, gll_warped, unset, False), (2,))), 3)))), MultiIndex((Index(8),))), array([ 0,  1,  2,  3,  4,  5,  6,  7,  8,  9, 10, 11, 12, 13, 14, 15, 16,
       17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33,
       34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50,
       51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63], dtype=int32), ((), (), (), ())
  File "/home/djoumessi/Bureau/IMT4/Fenicsx_tutorial/read_mesh/minimal/MWE.py", line 78, in <module>
  File "/home/djoumessi/Bureau/IMT4/Fenicsx_tutorial/read_mesh/minimal/MWE.py", line 73, in normalizeAndProj_vec
  File "/home/djoumessi/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/dolfinx/fem/function.py", line 402, in interpolate
    self._cpp_object.interpolate(np.asarray(u(x), dtype=self.dtype), cells)
  File "/home/djoumessi/miniconda3/envs/fenicsx-env/lib/python3.12/site-packages/ufl/exproperators.py", line 340, in _call
    if arg in ("+", "-"):
ValueError: The truth value of an array with more than one element is ambiguous. Use a.any() or a.all()
Projection may not be needed at all.
I’ve simplified your code to
import mpi4py
import dolfinx.fem
def normalize_gradient(u, V):
    Normalizes the gradient of the solution u and interpolates it into the specified V.
    Parameters:
    V (FunctionSpace): The function space into which the normalized gradient is to be interpolated.
    Returns:
    grad_uh = ufl.grad(uh)
    norm_grad_u_ufl = grad_uh / ufl.sqrt(ufl.dot(grad_uh, grad_uh))
    norm_grad_u_expr = dolfinx.fem.Expression(norm_grad_u_ufl, V.element.interpolation_points())
    norm_grad_u_interp = dolfinx.fem.Function(V)
    norm_grad_u_interp.interpolate(norm_grad_u_expr)
    return norm_grad_u_interp
domain = dolfinx.mesh.create_unit_square(mpi4py.MPI.COMM_WORLD, 8, 8, dolfinx.mesh.CellType.quadrilateral)
V = dolfinx.fem.functionspace(domain, ("P", 2))
uh = dolfinx.fem.Function(V)
uh.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
# Gradient of a continuous function may be discontinuous -> use DP instead of P
# Gradient of a polynomial of degree p is a polynomial of degree p - 1 -> decrease the polynomial order
FiberSpace = dolfinx.fem.functionspace(domain, ("DP", 1, (domain.topology.dim, )))
norm_grad_uh_interp = normalize_gradient(uh, FiberSpace)
I haven’t tested this thoroughly (not even exporting the resulting field for visualization in paraview), but hopefully it should give you an hint on how to proceed in your case.
Thank very much @francesco-ballarin its works.
But I would not close the discussion now.
