Problem with solving poisson in primal form
I’ve been trying to test the convergence of a solver that I wrote based on the post here: https://fenicsproject.org/olddocs/dolfin/1.3.0/python/demo/documented/poisson/python/documentation.html#:~:text=The%20Poisson%20equation%20is%20the,gon%20ΓN.
Im using an exact solution that is polynomial, thus with a sufficiently high degree FEM space I should be able to recover it exactly.
Im posting the code I’m using
def solver_online(A, mesh, degree, f):
    V = FunctionSpace(mesh, "Lagrange", degree)
    def boundary(x):
        return (
            x[0] < DOLFIN_EPS
            or x[0] > 1.0 - DOLFIN_EPS
            or x[1] < DOLFIN_EPS
            or x[1] > 1.0 - DOLFIN_EPS
    # Define boundary condition
    u0 = Constant(0.0)
    bc = DirichletBC(V, u0, boundary)
    df = Expression(f, degree=degree)
    a = inner(Constant(A) * grad(u), grad(v)) * dx
    L = df * v * dx
    # Compute solution
    solve(a == L, u, bc)
    return u, V
def test_primal_convergence(hs, degree, f, p_expression) :
    for h in hs:
        mesh = UnitSquareMesh(
            round(1 / (h * np.sqrt(2))),
        print(f"{h = }")
        p, V = solver_online(
            np.array([[5, 1], [1, 5]]),
            mesh,
            degree,
            f,
        p_exact = interpolate(
            Expression(p_expression, degree=degree),
            V,
        set_log_level(50)
        p_err = np.sqrt(assemble((p - p_exact) ** 2 * dx(domain=mesh)))
        print(f"{p_err = }\n")
if __name__ == "__main__":
    hs = [0.25, 0.125, 0.0625]
    p_expression = "x[0]*(1-x[0])*x[1]*(1-x[1])"
    degree = 3
    f = "2*(1-2*x[0])*(1-2*x[1])-10*x[1]*(1-x[1])-10*x[0]*(1-x[0])"
    print("running primal formulation convergence test\n\n")
This is what I’m getting printed on the terminal:
h = 0.25
Solving linear variational problem.
p_err = 0.06668253828972745
h = 0.125
p_err = 0.06666780805961044
h = 0.0625
p_err = 0.06666677073449483`
Looks like you haven’t implemented the correct source term (as the error remains constant). I am not at a computer, and cannot have a look at your code in detail, But i would suggest having a look at Error control: Computing convergence rates — FEniCSx tutorial
I was forgetting about the minus sign:(
  • div A grad p = f
thank you very much!
