I am writing code for mixed formulaton for poisson using fenicsx, but I am not getting error computation using exact solution. Here, is the minimal code.
Please suggest something
from dolfinx import fem, mesh, plot
import pyvista as pv
domain = mesh.create_unit_square(comm=MPI.COMM_WORLD,
nx=2, ny=2,
cell_type=mesh.CellType.triangle)
P1 = ufl.FiniteElement(family='BDM', cell=domain.ufl_cell(), degree=1)
P2 = ufl.FiniteElement(family='DG', cell=domain.ufl_cell(), degree=0)
W = fem.FunctionSpace(mesh=domain, element=ufl.MixedElement([P1, P2]))
# test and trial functions
tau, v = ufl.TestFunctions(function_space=W)
sigma, u = ufl.TrialFunctions(function_space=W)
# function determining if a node is on the tray top
def on_left_and_right(x):
return np.logical_or(np.isclose(x[0], 0),
np.isclose(x[0], 1))
W0, _ = W.sub(0).collapse()
u_zero = fem.Function(W0)
u_zero.x.array[:] = 0.0
# print(u_zero.x.array[:])
boundary_facets = mesh.locate_entities_boundary(mesh=domain,
dim=domain.topology.dim-1,
marker=on_left_and_right)
boundary_dofs = fem.locate_dofs_topological(V=(W.sub(0), W0),
entity_dim=domain.topology.dim-1,
entities=boundary_facets)
# apply Dirichlet BC
bc = fem.dirichletbc(value=u_zero,
dofs=boundary_dofs,
V=W.sub(0)) # V.sub(0): Corresponds to BDM element
# apply Neumann BC
x = ufl.SpatialCoordinate(domain=domain)
f = 10.0 * ufl.exp(-((x[0] - 0.5)**2 + (x[1] - 0.5)**2) / 0.02)
g = ufl.sin(5 * x[0])
# Variational form
a = (ufl.dot(sigma, tau) + ufl.div(tau) * u + ufl.div(sigma) * v) * ufl.dx
L = -ufl.inner(f, v) * ufl.dx + ufl.inner(g, v) * ufl.ds
# Solve
problem = LinearProblem(a, L, [bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
###### Define Exact solution
Q, _ = W.sub(0).collapse()
# dofs_top = fem.locate_dofs_topological((W.sub(1), Q), fdim, facets_top)
uD = fem.Function(Q)
uD.interpolate(lambda x: x[0]*( 1 - x[0]) + x[1]*( 1 - x[1]) ) ###### Exact solution
##### Error_max
# error_max = np.max(np.abs(uD.x.array-uh.x.array))
L2_error = fem.form(ufl.inner(uh - uD, uh - uD) * ufl.dx)
