Problem with solving Stokes with RT1-DG0?
Hi all,
I am testing solving a basic Stokes problem with some different elements, and I have problems getting the correct solution with RT1-DG0. It works fine for RT2-DG0 and P2-P1 Taylor-Hood elements. Is there something I’m missing to do for the RT1-DG0 pair?
Here’s the MWE based on the Stokes solve in demo_navier_stokes.py:
from numpy import sin, cos, pi
from ufl import inner, outer, grad, div, dx, dS, ds, avg, jump
from dolfinx.fem.petsc import assemble_matrix_block, assemble_vector_block
N = 32 * 4
mesh = dolfinx.mesh.create_unit_square(
    MPI.COMM_WORLD, N, N, dolfinx.mesh.CellType.triangle
# # P2-P1 works fine
# V = dolfinx.fem.functionspace(mesh, ("Lagrange", 2, (mesh.geometry.dim,)))
# Q = dolfinx.fem.functionspace(mesh, ("Lagrange", 1))
# RT2-DG0 works fine
V = dolfinx.fem.functionspace(mesh, ("RT", 2))
Q = dolfinx.fem.functionspace(mesh, ("DG", 0))
# # RT1-DG0 doesn't work
# V = dolfinx.fem.functionspace(mesh, ("RT", 1))
# Q = dolfinx.fem.functionspace(mesh, ("DG", 0))
u, p = ufl.TrialFunction(V), ufl.TrialFunction(Q)
v, q = ufl.TestFunction(V), ufl.TestFunction(Q)
n = ufl.FacetNormal(mesh)
h = ufl.CellDiameter(mesh)
def tensor_jump(v, n):
    return outer(v("+"), n("+")) + outer(v("-"), n("-"))
beta = dolfinx.fem.Constant(mesh, 10.0)
a_interior = (
    inner(grad(u), grad(v)) * dx
    - inner(avg(grad(u)), tensor_jump(v, n)) * dS
    - inner(tensor_jump(u, n), avg(grad(v))) * dS
    + beta / avg(h) * inner(jump(u), jump(v)) * dS
a_bdry = (
    -inner(grad(u), outer(v, n)) * ds
    - inner(outer(u, n), grad(v)) * ds
    + beta / h * inner(u, v) * ds
a_h = a_interior + a_bdry
b_h = -inner(div(u), q) * dx
bT_h = -inner(p, div(v)) * dx
a = dolfinx.fem.form([[a_h, bT_h], [b_h, None]])
def f_expr(x):
    # fmt: off
    return np.stack(
            2*pi*sin(2*pi*x[1])*(cos(2*pi*x[0]) - 2*pi*pi*cos(2*pi*x[0]) + pi*pi),
            2*pi*sin(2*pi*x[0])*(cos(2*pi*x[1]) + 2*pi*pi*cos(2*pi*x[1]) - pi*pi)
    # fmt: on
f = dolfinx.fem.Function(V)
f.interpolate(f_expr)
L0 = inner(f, v) * dx
L1 = inner(dolfinx.fem.Constant(mesh, 0.0), q) * dx
L = dolfinx.fem.form([L0, L1])
def zero(x):
    return np.stack((np.zeros_like(x[0]), np.zeros_like(x[1])))
bdry_facets = dolfinx.mesh.exterior_facet_indices(mesh.topology)
bdry_dofs = dolfinx.fem.locate_dofs_topological(V, mesh.topology.dim - 1, bdry_facets)
u_D = dolfinx.fem.Function(V)
u_D.interpolate(zero)
bc_u = dolfinx.fem.dirichletbc(u_D, bdry_dofs)
bcs = [bc_u]
A = dolfinx.fem.petsc.assemble_matrix_block(a, bcs=bcs)
b = dolfinx.fem.petsc.assemble_vector_block(L, a, bcs=bcs)
ksp = PETSc.KSP().create(mesh.comm)
ksp.setOperators(A)
ksp.setType("preonly")
ksp.getPC().setType("lu")
ksp.getPC().setFactorSolverType("mumps")
opts = PETSc.Options()
opts["mat_mumps_icntl_14"] = 80
# opts["mat_mumps_icntl_24"] = 1
# opts["mat_mumps_icntl_25"] = 0
ksp.setFromOptions()
x = A.createVecRight()
ksp.solve(b, x)
u_h, p_h = dolfinx.fem.Function(V), dolfinx.fem.Function(Q)
offset = V.dofmap.index_map.size_local * V.dofmap.index_map_bs
u_h.x.array[:offset] = x.array[:offset]
# From demo_navier_stokes:
def domain_average(mesh, v):
    """Compute the average of a function over the domain"""
    vol = mesh.comm.allreduce(
        dolfinx.fem.assemble_scalar(
            dolfinx.fem.form(dolfinx.fem.Constant(mesh, 1.0) * dx)
        op=MPI.SUM,
    return (1 / vol) * mesh.comm.allreduce(
        dolfinx.fem.assemble_scalar(dolfinx.fem.form(v * dx)), op=MPI.SUM
p_h.x.array[: (len(x.array) - offset)] = x.array[offset:]
p_h.x.array[:] -= domain_average(mesh, p_h)
W = dolfinx.fem.functionspace(mesh, ("DG", 2, (mesh.geometry.dim,)))
u_viz = dolfinx.fem.Function(W)
u_viz.interpolate(u_h)
t = 0.0
u_file = dolfinx.io.VTXWriter(mesh.comm, "u.bp", u_viz)
p_file = dolfinx.io.VTXWriter(mesh.comm, "p.bp", p_h)
u_file.write(t)
p_file.write(t)
