Thank you very much for your answer,
I implemented this problem (equations given in the above), I didn’t encounter any errors, but the results are weird, not in line with theoretical expectations. Do you see any obvious mistakes in the implementation?
I will add import and mesh generation steps additionally, and in the below of these import and my mesh generatio codes, I will give the main body of the code. I may have imported some packages more than once in the importing step, but this code works well with no error. I used Dolfinx 0.7.2 and Dolfinx Complex Python 3 Jupyter Notebook.
from dolfinx.mesh import locate_entities_boundary, meshtags
from dolfinx.io import gmshio
from dolfinx import fem, mesh, plot
import pyvista
import scipy.sparse
from dolfinx import mesh, fem, plot, io
import dolfinx.fem.petsc
from dolfinx.fem import (Constant, Function, functionspace, FunctionSpace, assemble_scalar,
dirichletbc, form, locate_dofs_topological,assemble_matrix)
from dolfinx.mesh import create_unit_square, locate_entities, meshtags
from ufl import (FacetNormal, Measure, SpatialCoordinate, TestFunction, TrialFunction,
div, dot, dx, grad, inner, lhs, rhs)
import scipy
from dolfinx import mesh as dfx_mesh
# Define geometric and topological dimensions
gdim = 2
shape = "triangle"
degree = 1
# Define the cell and domain
cell = ufl.Cell(shape, geometric_dimension=gdim)
domain = ufl.Mesh(ufl.VectorElement("Lagrange", cell, degree))
# Define all the vertices for the mesh
vertices = np.array([[0.1, 0.1], # Vertex 0
[0.1, 1.1], # Vertex 1
[0.6, 0.1], # Vertex 2
[0.6, 1.1], # Vertex 3
[1.1, 0.1], # Vertex 4
[1.1, 1.1]]) # Vertex 5
vertices=vertices*(10**(-2))
# Define four cells (triangles) using the vertices defined above
cells = np.array([[0, 1, 2], # 1 triangle
[1, 2, 3], # 2 triangle
[2, 4, 3], # 3 triangle
[4, 5, 3]], # 4 triangle
dtype=np.int32)
# Create the mesh
meshc = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, cells, vertices, domain)
tdim = meshc.topology.dim
fdim = tdim - 1
meshc.topology.create_connectivity(fdim, tdim)
# Check if PyVista backend is available
print(pyvista.global_theme.jupyter_backend)
pyvista.start_xvfb() # Start virtual framebuffer if necessary
# Create and plot the mesh using PyVista
topology, cell_types, geometry = plot.vtk_mesh(meshc, gdim)
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
plotter = pyvista.Plotter()
plotter.view_xy()
# Show the plot in an interactive window or save to a file
if not pyvista.OFF_SCREEN:
plotter.show()
figure = plotter.screenshot("adjacent_triangles_mesh.png")
import pyvista
from dolfinx import plot
def refine_mesh(cell_to_node, coords, num_refinements):
"""Refine the mesh recursively."""
if num_refinements == 0:
# Base case, return the original cell to node connectivity and coordinates
return cell_to_node, coords
# Create new triangles using midpoints
new_cell_to_node = []
new_coords = coords.copy()
# Dictionary to keep track of the midpoints that have already been added
edge_to_midpoint = {}
for cell in cell_to_node:
# Find the midpoints for the current cell
cell_coords = coords[cell]
midpoints = []
midpoint_indices = []
for i in range(len(cell)):
edge = tuple(sorted((cell[i], cell[(i + 1) % len(cell)])))
if edge not in edge_to_midpoint:
# Calculate midpoint for a new edge
midpoint = (cell_coords[i] + cell_coords[(i + 1) % len(cell)]) / 2.0
new_coords = np.vstack((new_coords, midpoint))
midpoint_index = len(new_coords) - 1
edge_to_midpoint[edge] = midpoint_index
# Get the existing midpoint index for the edge
midpoint_index = edge_to_midpoint[edge]
midpoints.append(new_coords[midpoint_index])
midpoint_indices.append(midpoint_index)
# Define new cells using the original vertices and midpoints
new_cells = [
[cell[0], midpoint_indices[0], midpoint_indices[2]],
[midpoint_indices[0], cell[1], midpoint_indices[1]],
[midpoint_indices[2], midpoint_indices[1], cell[2]],
midpoint_indices, # the central triangle
new_cell_to_node.extend(new_cells)
# Recursively refine the new mesh
return refine_mesh(new_cell_to_node, new_coords, num_refinements - 1)
# Continue with the rest of your code to use the refined mesh...
# Get the cell to node connectivity and coordinates of the original mesh
cell_to_node = meshc.topology.connectivity(2, 0).array.reshape(-1, 3)
coords = meshc.geometry.x
# Choose the number of refinements
num_refinements = 1 # Change this to the desired number of refinement levels
# Refine the mesh
refined_cell_to_node, refined_coords = refine_mesh(cell_to_node, coords, num_refinements)
cells = np.asarray(refined_cell_to_node, dtype=np.int32)
xs = np.asarray(refined_coords, dtype=np.float64).reshape(-1, 3)
pos = refined_coords[:, :2]
gdim = 2
shape = "triangle"
degree = 1
# Create the mesh
mesh = dolfinx.mesh.create_mesh(MPI.COMM_WORLD, refined_cell_to_node, pos, domain)
tdim = mesh.topology.dim
fdim = tdim - 1
topology, cell_types, geometry = plot.vtk_mesh(mesh, gdim)
plotter.view_xy()
plotter.show()
######MAIN BODY OF THE CODE/IMPLEMENTATION
#Spatial Coordinates, Function Spaces and Facet Normal
x = SpatialCoordinate(mesh)
V = FunctionSpace(mesh, ("Nedelec 1st kind H(curl)", 1))
u = ufl.TrialFunction(V)
n = ufl.FacetNormal(mesh)
# %%%WR 975 WAVEGUIDE Parameters%%%
length_a_waveguide= (247.65)*(10**(-3))
length_b_waveguide= (123.825)*(10**(-3))
frequency=1*(10**9)
speed_of_light=(3)*(10**8)
wavelength=(speed_of_light)/frequency
k0=(2*(np.pi))/wavelength
# angular_freq=2*np.pi*frequency
# first_term=((angular_freq)**2)/((speed_of_light)**2)
first_term=k0**2
second_term= ((np.pi)/length_a_waveguide)**2
beta_10=first_term-second_term
beta_10
# ##Start to weak form
L_lhs= (ufl.inner(ufl.curl(u),ufl.curl(v))*ufl.dx) - ((beta_10)*(beta_10)*(ufl.inner(u,v)*ufl.dx))
coordinates = mesh.geometry.x[:, :2]
# Find the minimum and maximum values for x and y
min_x, min_y = np.min(coordinates, axis=0)
max_x, max_y = np.max(coordinates, axis=0)
# Create boundary conditions using these values
boundaries = [
(1, lambda x: np.isclose(x[0], min_x)),
(2, lambda x: np.isclose(x[0], max_x)),
(3, lambda x: np.isclose(x[1], min_y)),
(4, lambda x: np.isclose(x[1], max_y))
fdim = mesh.topology.dim - 1
facets = locate_entities(mesh, fdim, locator)
facet_indices.append(facets)
facet_tag = meshtags(mesh, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = Measure("ds", domain=mesh, subdomain_data=facet_tag)
#Dirichlet BCs
facets3 = facet_tag.find(3)
u_D3 = fem.Function(V)
u_D3.x.array[:] = 0
dofs_D3 = fem.locate_dofs_topological(V, fdim, facets3)
bcD3 = fem.dirichletbc(u_D3, dofs_D3)
facets4 = facet_tag.find(4)
u_D4 = fem.Function(V)
u_D4.x.array[:] = 0
dofs_D4 = fem.locate_dofs_topological(V, fdim, facets4)
bcD4 = fem.dirichletbc(u_D4, dofs_D4)
bc = [bcD3, bcD4]
# Definition of cross product in 2D
def cross_2D(n, v):
# n = (0, 0, 1) for a mesh in the xy-plane
return ufl.as_vector((-v[1], v[0]))
# Input port
bc1 = 1j * (beta_10) * ufl.inner(cross_2D(n, u), cross_2D(n,v)) * ds(1)
L_lhs += bc1
# Output port
bc2 = 1j * (beta_10) * ufl.inner(cross_2D(n, u), cross_2D(n,v)) * ds(2)
L_lhs += bc2
#E_inc definition
class Einc:
def __init__(self, E0, a):
self.E0 = E0
self.a = a
def eval(self, x):
ey = self.E0 * np.sin(np.pi * x[0] / self.a)
ex = np.full_like(ey, 0.0+0j, dtype=np.complex128)
return (ex,ey)
E0 = 0.5
incident_field = Einc(E0, length_a_waveguide)
#Build RHS
uh = fem.Function(V, dtype=np.complex128)
uh.interpolate(incident_field.eval)
f_inc = 2j * (beta_10) * ufl.inner(cross_2D(n, u), cross_2D(n, uh)) * ds(1)
uh.name = "Einc"
##Solving the equation
problem = fem.petsc.LinearProblem(L_lhs, f_inc, bcs=bc, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
solution=problem.solve()
print(solution)
