I’ve been trying to implement the linear elasticity tutorial on Google Colab using a FEM on Colab installation of dolfinx 0.8.0.0. So far I have been unable to properly set a constant vector for the Dirichlet boundary condition of the problem.
So far I’ve been using the exact code of the implementation, except for the use of fem.functionspace instead of fem.VectorFunctionSpace
This is the code I’ve been using so far
from dolfinx import mesh, fem, default_scalar_type
L = 1
W = 0.2
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],
[20, 6, 6], cell_type=mesh.CellType.hexahedron)
V = fem.functionspace(domain, ("Lagrange", 1))
def clamped_boundary(x):
return np.isclose(x[0], 0)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
However, I always get the following error
TypeError Traceback (most recent call last)
/usr/local/lib/python3.10/dist-packages/dolfinx/fem/bcs.py in dirichletbc(value, dofs, V)
174 try:
--> 175 bc = bctype(_value, dofs, V)
176 except TypeError:
TypeError: __init__(): incompatible function arguments. The following argument types are supported:
1. __init__(self, g: ndarray[dtype=float64, writable=False, order='C'], dofs: ndarray[dtype=int32, writable=False, shape=(*), order='C'], V: dolfinx.cpp.fem.FunctionSpace_float64) -> None
2. __init__(self, g: dolfinx.cpp.fem.Constant_float64, dofs: ndarray[dtype=int32, writable=False, shape=(*), order='C'], V: dolfinx.cpp.fem.FunctionSpace_float64) -> None
3. __init__(self, g: dolfinx.cpp.fem.Function_float64, dofs: ndarray[dtype=int32, writable=False, shape=(*), order='C']) -> None
4. __init__(self, g: dolfinx.cpp.fem.Function_float64, dofs: list[ndarray[dtype=int32, writable=False, shape=(*), order='C']], V: dolfinx.cpp.fem.FunctionSpace_float64) -> None
Invoked with types: dolfinx.cpp.fem.DirichletBC_float64, ndarray, ndarray, dolfinx.fem.function.FunctionSpace
1 frames
--> 177 bc = bctype(_value, dofs, V._cpp_object)
178 else:
179 bc = bctype(_value, dofs)
RuntimeError: Rank mis-match between Constant and function space in DirichletBC
This error can be bypassed by using u_D = default_scalar_type(0). However, this generates issues with the dimension of the boundary condition latter on.
Can anybody help me understand what is going wrong with this impementation?
