I compute the solution of a system of time dependent PDEs as an np.ndarray of elements of of a FunctionSpace over a MixedElement (like arr_Y in the code below). This solution gets passed to a lot of other functions and I don’t want to pass the corresponding FucntionSpace with it all the time.
For “simple” function spaces this is not needed since I can get them from the solutions themselves via .function_space(), but somehow this does not work for the mixed case.
Below I have an example code showing this problem. I have marked three sections with i), ii) and iii) respectively for reference in my question (and hopefully your answers). For comparison I added the “simple” non mixed case in the code as well.
Q1: What should I do if I want to get the function_space in i) ?
Q2: Why does unpacking the numpy.ndarray still results in an numpy.ndarray in ii)?
Q3: How get I get the function space from an Indexed object in general (see iii)?
Of course these “problems” are not restricted to .function_space.
I would greatly appreciate any explanation of what is going on or any answers to any of my questions.
import numpy
mesh = UnitSquareMesh(4, 4)
S1 = FiniteElement('CG', mesh.ufl_cell(), 1)
V = FunctionSpace(mesh, S1)
S1S1 = MixedElement([S1, S1])
Y = FunctionSpace(mesh, S1S1)
lst_V = [Function(V), Function(V)]
lst_Y = [Function(Y), Function(Y)]
arr_V = numpy.array(lst_V)
arr_Y = numpy.array(lst_Y)
# this works
assert hasattr(lst_V[0], 'function_space')
assert hasattr(lst_Y[0], 'function_space')
# this also works
assert hasattr(arr_V[0], 'function_space')
# i) but this not
try:
assert hasattr(arr_Y[0], 'function_space')
except AssertionError:
print('`arr_Y[0]` does not have attribute `function_space`!')
# ii) I do not see why but indexing `arr_Y` still gives an `ndarray`
assert isinstance(arr_Y[0], numpy.ndarray)
# So I can unpack as many times as I want ...
assert isinstance(arr_Y[:][:][:], numpy.ndarray)
# iii) but also this does not work
try:
assert hasattr(arr_Y[0][0], 'function_space')
print('`arr_Y[0][0]` does not have attribute `function_space`!')
ad ii) observe that the arrays you create have different shapes (2-vector vs. 2x2 matrix). This is due to the fact that Function(Y), being a function in MixedFunctionSpace is iterable, (len(Function(Y)) is 2). Note that you’d get the same behavior with functions from VectorFunctionSpace.
ad i) it is not the most elegant solution but consider
x = numpy.zeros_like(arr_V)
x[0] = Function(Y)
ad iii) Operands of the Indexed node are the coefficient and the indices. Consider
thanks a lot, that really helped. I didn’t see that arr_y.shape was (2, 2).
Your suggestion of using .ufl_operands is also very good, but I it does not quite do what I expected.
Consider Y1, Y2 = Y.split().
For me it would make sense if (Function(Y)[0]).ufl_operands[0].function_space() == Y1
and (Function(Y)[1]).ufl_operands[0].function_space() == Y2
while in fact both times the result is the full space Y.
Is there also a way of extracting the correct subspace (without the information about the index)?
Something like this (except this does not work because of the reason above):
def print_function_space(func):
if isinstance(func, ufl.indexed.Indexed):
func = func.ufl_operands[0]
print(func.function_space())
