I’m trying to do this projection as part of a post-processing step. I have a Function over the entire volume, and I want to plot an expression containing that Function on a few boundaries.
I think this should illustrate what I’m trying to do:
from dolfinx import fem, mesh
import pyvista4dolfinx as p4d
domain = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10, mesh.CellType.triangle)
# Simple demonstration vector function f(x, y) = (x, y)
V = fem.functionspace(domain, ("Lagrange", 1, (2,)))
u = fem.Function(V)
u.interpolate(lambda x: (x[0] + 0.1, x[1] + 0.1))
p4d.plot(u, show=True, factor=0.1)
# Create a subdomain over the top boundary
top_facets = mesh.locate_entities_boundary(
domain, fdim, lambda x: np.isclose(x[1], 1.0)
subdomain, entity_map, _, _ = mesh.create_submesh(domain, fdim, top_facets)
V_boundary = fem.functionspace(subdomain, ("Lagrange", 1, (2,)))
u_sub = fem.Function(V_boundary)
expr = fem.Expression(
u, V_boundary.element.interpolation_points, entity_maps=[entity_map]
u_sub.interpolate(expr)
plt = p4d.plot(u_sub, factor=0.1)
p4d.plot(domain, plotter=plt, show=True)
But it’s not working:
[0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
I’ve searched the forum and found a few attempts at doing precisely what I’m trying to do, but they’re all fairly outdated. I also looked at several interpolation and expression tests, nothing got me quite there.
There’s an example with an expression over quadrature points, but the only option seems to be to eval, which is not really helpful for plotting.
The closest I got was by handrolling an L2 projector, but there’s always a single facet with a completely wrong value that messes up the visualization (see issue 4291 in github).
Some help is really appreciated! Thanks!
