Extracting surface part of a Function
I have a vector-valued function u defined on the full mesh. Now I want to export just (a part of) the surface of the mesh, including this function u. My attempt so far looks like this, but the result isn’t correct. Do I need some sort of reordering in the LHS of u_sarf.x.array[:] = ... instead of :? Or is
indices = np.ravel([3*parent_dofs + i for i in range(3)], order="F")not correct? BTW, what is the recommended way to go from “dofs” to actual array indices for vector-valued functions?
msh = dolfinx.mesh.create_box(MPI.COMM_WORLD, [[0.0, 0.0, 0.0], [1.0, 1.0, 1.0]], [5, 5, 5])
fdim = msh.topology.dim - 1
msh.topology.create_connectivity(2, 3)
whole_exterior = dolfinx.mesh.exterior_facet_indices(msh.topology)
V = dolfinx.fem.functionspace(msh, ("CG", 1, (3,)))
u = dolfinx.fem.Function(V)
def stuff(x):
    return [np.sin(2.0*np.pi*x[0]), np.cos(2.0*np.pi*x[1]), x[2]]
u.interpolate(stuff)
xdmf_full = dolfinx.io.XDMFFile(MPI.COMM_WORLD, "full.xdmf", "w")
xdmf_full.write_mesh(msh)
xdmf_full.write_function(u)
xdmf_full.close()
submesh, facet_map, vertex_map, _ = dolfinx.mesh.create_submesh(msh, fdim, whole_exterior)
V_sub = dolfinx.fem.functionspace(submesh, ("CG", 1, (3,)))
u_surf = dolfinx.fem.Function(V_sub)
parent_dofs = dolfinx.fem.locate_dofs_topological(V, fdim, whole_exterior)
u_surf.x.array[:] = u.x.array[indices]
xdmf_surf = dolfinx.io.XDMFFile(MPI.COMM_WORLD, "surf.xdmf", "w")
xdmf_surf.write_mesh(submesh)
xdmf_surf.write_function(u_surf)
Y-component of full mesh on the left, my attempt of surface mesh on the right.
Hello, dear can you tell me how you are getting this cube??. I have save the file and open it in paraview but not getting your figure( Cube type).
I’ve got a function for this, that hopefully will be merged into scifem eventually:
Interpolate from a parent mesh to a set of exterior facets
Author: Jørgen S. Dokken
SPDX License identifier: MIT
def interpolate_to_submesh(
    u_volume: dolfinx.fem.Function,
    u_surface: dolfinx.fem.Function,
    entity_map: npt.NDArray[np.int32],
    Interpolate a function `u_volume` into the function `u_surface`.
    Note:
        Does not work for DG as no dofs are associated with the facets
    Args:
        u_volume: Function to interpolate data from
        u_surface: Function to interpolate data to
        entity_map: Map from cells in the surface mesh to facets in the volume mesh
    V_vol = u_volume.function_space
    mesh = V_vol.mesh
    V_surf = u_surface.function_space
    submesh = V_surf.mesh
    if Version(dolfinx.__version__) > Version("0.9.0"):
        ip = V_surf.element.interpolation_points
        ip = V_surf.element.interpolation_points()
    expr = dolfinx.fem.Expression(u_volume, ip)
    mesh.topology.create_connectivity(mesh.topology.dim, submesh.topology.dim)
    mesh.topology.create_connectivity(submesh.topology.dim, mesh.topology.dim)
    c_to_e = mesh.topology.connectivity(mesh.topology.dim, submesh.topology.dim)
    e_to_c = mesh.topology.connectivity(submesh.topology.dim, mesh.topology.dim)
    # Pack integration entities, including ghosts
    integration_entities = np.zeros((len(entity_map), 2), dtype=np.int32)
    for i, facet in enumerate(entity_map):
        cells = e_to_c.links(facet)
        if len(cells) > 1:
            raise RuntimeError("Only exterior facets are supported for now")
        facets = c_to_e.links(cells[0])
        local_index = np.flatnonzero(facets == facet)
        assert len(local_index) == 1
        integration_entities[i] = (cells[0], local_index[0])
    # Data is (num_cells, num_points/num_dofs, value_size)
        data = expr.eval(mesh, integration_entities)
        data = expr.eval(mesh, integration_entities.flatten())
    submesh.topology.create_entity_permutations()
    cell_info = mesh.topology.get_cell_permutation_info()
    ft = V_surf.element.basix_element.cell_type
    for i in range(integration_entities.shape[0]):
        perm = np.arange(data.shape[1], dtype=np.int32)
        try:
            # Can be used once  https://github.com/FEniCS/basix/pull/913
            V_vol.element.basix_element.permute_subentity_closure_inv(
                perm, cell_info[integration_entities[i, 0]], ft, int(integration_entities[i, 1])
        except TypeError:
            entity_info = compute_entity_data(
                V_vol.element, cell_info[integration_entities[i, 0]], ft, integration_entities[i, 1]
            V_vol.element.basix_element.permute_subentity_closure_inv(perm, entity_info, ft)
        data[i] = data[i][perm]
    if len(data.shape) == 3:
        # Data is now (num_cells, value_size,num_points)
        data = data.swapaxes(1, 2)
        # Data is now (value_size, num_cells, num_points)
        data = data.swapaxes(0, 1)
    if expr.value_size == 1:
        shaped_data = data.flatten()
        shaped_data = data.reshape(expr.value_size, -1)
    u_surface._cpp_object.interpolate(shaped_data, np.arange(len(entity_map), dtype=np.int32))
    u_surface.x.scatter_forward()
Thank you for taking the time, this is much more involved than I realised. For me it triggers the TypeError, which is expected I guess, but I don’t know where compute_entity_data is from, so I can’t import it.
Here is an implementation of that function
from dolfinx import mesh, fem
import numpy.typing as npt
import basix
from packaging.version import Version
def compute_entity_data(
    element,
    cell_info: int,
    entity_type: basix.CellType,
    entity_index: int,
) -> int:
    Compute entity permutation data on a sub entity of the mesh.
    Note:
        This can be removed once https://github.com/FEniCS/basix/pull/913 is merged.
    Args:
        element: The element to compute permutations for
        cell_info: Permutation data for the cell
        entity_type: The type of the entity
        entity_index: The local index of the entity (relative to the cell)
    Returns:
        entity_info: Permutation data for the entity
    ct = element.basix_element.cell_type
    tdim = len(basix.cell.topology(ct)) - 1
    num_entity_dofs = len(element.basix_element.entity_dofs[2])
    face_start = 3 * num_entity_dofs if tdim == 3 else 0
    entity_info = 0
    edim = len(basix.cell.topology(entity_type)) - 1
    if edim == 0:
        pass
    elif edim == 1:
        entity_info = cell_info >> (face_start + entity_index) & 1
    elif edim == 2:
        entity_info = cell_info >> (3 * entity_index) & 7
        raise ValueError(f"Unsupported entity {entity_type}")
    return entity_info
It runs now, but still doesn’t give me the correct result. I’m assuming the entity map I have to pass in is the entity map returned by create_submesh, which I’ve called facet_map here. Is that correct? I’m using dolfinx 0.9.0.
from interpolate_submesh import interpolate_to_submesh
def stuff(x):
xdmf_full.close()
interpolate_to_submesh(u, u_surf, facet_map)
This is due to a bug on v0.9.0, that has been fixed on the nightly branch.
You can test this with for instance: ghcr.io/fenics/dolfinx/dolfinx:nightly
