Hello dokken,
Here is the one of the simple example for 2D problem. I extracted a stress component and if you compare the results of T2 and Q1 at the corners (legend setting -50 to 120) there appears weird distribution for quadrilateral element.
From my other observations, it is not about the projection but I could not figure out the reason.
%matplotlib inline
"eliminate_zeros": True, \
"precompute_ip_const": True}
Type ="T2"
inc_load =np.array([ 0. ,0.1,0.2,0.3,0.4, 0.5])
E, nu = 200, 0.49
Element = "CG"
if Type=="T2":
order_u=2
mesh = RectangleMesh(Point(0., 0.), Point(1, 1), 64,64, "right/left")
if Type=="Q1":
order_u=1
mesh=UnitSquareMesh.create(64, 64, CellType.Type.quadrilateral)
mu, lmbda = Constant(E/(2*(1 + nu))), Constant(E*nu/((1 + nu)*(1 - 2*nu)))
V2 = VectorFunctionSpace(mesh, Element, order_u)
du = TrialFunction(V2)
v = TestFunction(V2)
u = Function(V2)
quad_degree=3
metadata = {"quadrature_degree": quad_degree, "quadrature_scheme": "default"}
dxm = dx(metadata=metadata)
# Kinematics
d = 3
grad_u = grad(u)
grad_u3 = as_tensor([[grad_u[0, 0], grad_u[0, 1], 0.0 ], [grad_u[1, 0], grad_u[1, 1],0.0], [0.0, 0.0,0.0]])
I = Identity(d) # Identity tensor
F = I + grad_u3 # Deformation gradient
J=det(F)
C= variable(C)
I1 = tr(C)
I2 = 1/2*((tr(C))**2-tr(C*C))
I3 = det(C)
tol =1e-14
class clamped_boundary_up(SubDomain): #Region definition to be fixed
return on_boundary and near(x[1],0,tol)
class clamped_boundary_down(SubDomain): #Region definition to be fixed
return on_boundary and near(x[1],H,tol)
up_bc = clamped_boundary_up()
down_bc = clamped_boundary_down()
boundary_part = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
boundary_part.set_all(0)
up_bc.mark(boundary_part, 2)
Tr = Expression(('pr', '0.0'),degree=1,pr=0)
bc1 = DirichletBC(V2, Tr, up_bc)
bc2 = DirichletBC(V2, Constant((0, 0)), down_bc)
bc = [bc1, bc2]
psi_iso = (lmbda/4)*(I3-1)-((lmbda/2)+mu)*ln((I3)**(0.5))+(mu/2)*(I1-3)
psi = psi_iso
S_ =2*diff(psi_iso,C)
Cauchy = (F*S_*F.T)/J
vert = as_vector((1.0, 0.0, 0.0))
Cauchy_vert = inner(Cauchy,outer(vert,vert))
# Total potential energy
Pi = psi*dxm
F = derivative(Pi, u, v)
# Compute Jacobian of F
J = derivative(F, u, du)
problem = NonlinearVariationalProblem(F, u, bc, J=J)
file_results = XDMFFile("Result.xdmf")
P1_1 = FunctionSpace(mesh, "CG", 1)
sigma = Function (P1_1)
for t in inc_load:
Tr.pr=t
solver.solve()
sigma.assign(project(Cauchy_vert,P1_1,form_compiler_parameters={"quadrature_degree":quad_degree}))
file_results.write(u, t)
file_results.write(sigma, t)
