I would like to impose a pulse function condition on a boundary.
For example, let consider that we have a rectangular box and we want to impose the following pressure condition on the left boundary:
P = 1 on left surface if t = 0
P = 0 on left surface if t > 0
mesh = UnitSquareMesh(10, 10)
t = 0
expr = Expression("t<tol? 1: 0",degree=1, t=t, tol=1e-13)
out = File("pulse.pvd")
bc = DirichletBC(V, expr, "x[0]<DOLFIN_EPS and on_boundary")
bc.apply(u.vector())
out << u
expr.t = 5
out << u
Thank you very much.
I have followed that tutorial and the minimal example that you provided, and I have managed to write a full working code for dolfinx.
I will leave it bellow in case that anyone else is interested in this problem.
from dolfinx.fem import (Constant, DirichletBC, Function, FunctionSpace, apply_lifting, assemble_matrix,
assemble_scalar, assemble_vector, create_vector, locate_dofs_topological, set_bc)
from ufl import inner, div, dx
# Mesh
mesh = dolfinx.UnitSquareMesh(MPI.COMM_WORLD, 10, 10)
gdim = 2
# Velocity element space
v_cg2 = ufl.VectorElement('CG', mesh.ufl_cell(), 2)
V = dolfinx.FunctionSpace(mesh, v_cg2)
# Define pulse function for velocity in the left boundary
t = 0
class LeftVelocity():
def __init__(self, t):
self.t = t
def __call__(self, x):
values = np.zeros((gdim, x.shape[1]),dtype=PETSc.ScalarType)
if t == 0:
values[0] = 1
values[0] = 0
return values
# Get dofs of the left boundary
def left(x):
return np.isclose(x[0], 0)
left_dofsp = dolfinx.fem.locate_dofs_geometrical(V, left)
# Define boundary condition
u_left = Function(V)
left_velocity = LeftVelocity(t)
u_left.interpolate(left_velocity)
bc = dolfinx.DirichletBC(u_left, left_dofsp)
dolfinx.fem.set_bc(u.vector, [bc])
# Output file
out = XDMFFile(MPI.COMM_WORLD, "Pulse.xdmf", "w")
out.write_mesh(mesh)
out.write_function(u, t)
dt = 0.1
for i in range(10):
# Update left boundary condition
left_velocity.t = t
# Output file
out.close()
