If it is correct to put function and mixed function together in a weak form?
I use Lagrange mixed element / mixed function for a weak form of a coupled model, where a function is also involved. I am not sure if it is correct as the DOF order of a mixed functionspace may differ from that of a functionspace. If not true, how can I modify it? In my following code, the aforementioned concern is represented by
tau1 = c1 * (ufl.grad(u) + ufl.grad(u).T) + c2 * ufl.grad(u) * tau
weak_form = (ufl.inner(u-un, v) + ufl.inner(tau1, ufl.grad(v)) + ufl.inner(p-pn, q)) * ufl.dx
where tau is built on a functionspace, while other variables are from mixed functionspace.
Full MWE:
# Test to put function and mixed function together in a weak form
# DOLFINx version: 0.7.3
from dolfinx import fem, mesh
# Mesh
_mesh = mesh.create_unit_square(MPI.COMM_WORLD, 10, 10)
ndims = _mesh.topology.dim
# Elements
V_order = 2
Q_order = 1
VE = ufl.FiniteElement("Lagrange", _mesh.ufl_cell(), V_order) # dummy VectorElement for velocity (vector)
FE = ufl.FiniteElement("Lagrange", _mesh.ufl_cell(), Q_order) # FiniteElement for pressure (scalar)
ME = ufl.MixedElement([*([VE] * ndims), FE]) # mixed element to mimic P2-P1 elements
# Mixed functionspace and function
MFS = fem.functionspace(_mesh, ME) # mixed functionspace
T = fem.functionspace(_mesh, ("Lagrange", V_order, (ndims, ndims))) # tensor functionspace
Un = fem.Function(MFS) # mixed function
Unt = ufl.split(Un) # Un tuple
un = ufl.as_vector(Unt[:ndims]) # mixed function
pn = Unt[ndims] # mixed function
tau = fem.Function(T) # function
# TrailFunctions
trail_functions = ufl.TrialFunctions(MFS)
u = ufl.as_vector(trail_functions[:ndims])
p = trail_functions[-1]
# TestFunctions
test_functions = ufl.TestFunctions(MFS)
v = ufl.as_vector(test_functions[:ndims])
q = test_functions[-1]
# Forms to test the functionalities programmingly
c1, c2 = 1, 2 # some coefficients
a = fem.form(ufl.lhs(weak_form))
L = fem.form(ufl.rhs(weak_form))
