I am new to fenics, but have been very much enjoying it the past week! I am wanting to try a 3D version of this worked example:
https://fenicsproject.org/olddocs/dolfin/2019.1.0/python/demos/maxwell-eigenvalues/demo_maxwell-eigenvalues.py.html?highlight=tangential%20boundary%20condition#
I think I have everything working, but just wanted to double check boundary conditions. Here is my code:
from numpy import where
N = 8
mm = 1
mesh = UnitCubeMesh(N,N,N)
V1 = FunctionSpace(mesh,“N1curl”,mm)
bcs1 = [DirichletBC(V1, Constant((0.0,0.0,0.0)), DomainBoundary())]
u1 = TrialFunction(V1)
v1 = TestFunction(V1)
a1 = inner(curl(u1),curl(v1))*dx
b1 = inner(u1,v1)*dx
dummy = v1[0]*dx
A1 = PETScMatrix()
assemble_system(a1, dummy, bcs1, A_tensor=A1)
B1 = PETScMatrix()
assemble_system(b1, dummy, bcs1, A_tensor=B1)
[bc.zero(B1) for bc in bcs1]
I then pass A1 and B1 to eigensolver and everything works great. My question: the boundary condition should be that elements u of the trial and test space should have u\times n=0 for outward normal n - have I understood the internal workings of fenics correctly (i.e., is the line where I define bcs1 correct)? Note also that I am playing around with the order mm too.
Many thanks!
