I’m quite new to fenics, this being the first project aside from playing with the tutorials / examples provided here: The FEniCSx tutorial — FEniCSx tutorial
I’m running it in a docker container using “dolfinx/lab:stable” and using the complex number compatible kernel DOLFINx.
I’m trying to simulate the Takagi-Taupin equations on a simple 2D rectangle. As in step 1 of the procedure described in this paper X-ray dynamical diffraction from single crystals with arbitrary shape and strain field: A universal approach to modeling.
The code is running without errors but the results make me suspect I’ve not implemented the boundary condition the way I expected. This is further supported by the last figure where I was trying to plot where in the mesh it thinks the boundary Gamma is not showing the top and left side of the rectangle but a bottom right corner.
If someone could tell me where I made a mistake (in the BC or elsewhere) or just tel me if I’m properly plotting the selected boundary that would be great.
from mpi4py import MPI #message passage interface (How to comunicate between processes mostly relevant for parralelisiation)
from dolfinx.fem import petsc
sample_width = 300e-6 #in m
sample_height = 100e-6 #in m
res_x = 12*5
res_y = 4*5
Amplitude = 1. #Amplitude of incomming wave
lam = 25e-6 #Wavelength in m
Angle_in = 17.7 #Incident angle w.r.t. surface of incomming plane wave in degrees
Angle_in_rad = np.deg2rad(Angle_in)
s0 = np.array([np.cos(Angle_in_rad),-np.sin(Angle_in_rad),0.]) # Direction of incomming wave vector
s0 = s0 / np.linalg.norm(s0) # Normalisation
s0 = 2*np.pi*s0 / lam
s_0 = ufl.as_vector(s0[:2])
chi0 = 11.7
chih = 11.
chibh = 11.
#Generating the mesh
domain = dolfinx.mesh.create_rectangle(comm = MPI.COMM_WORLD, # message passage interface
points = [[0.,0.],[sample_width,sample_height]], #corners of rectangle lowerleft - upper right
n = (res_x,res_y), #horizontal and vertical resolution
dtype = np.float64 #data type for mesh geometry (how accuratly the positions can be saved
V = dolfinx.fem.functionspace(mesh = domain,
element = ("Lagrange",1) #use standard scale lagrange elements of continuous polynomials of order 2
#Functions defining different boundary segments
def boundary_Gamma(x):
bound = np.logical_or(np.isclose(x[0,:], 0.), np.isclose(x[1,:], sample_height),dtype=bool)
return bound
def boundary_notGamma(x):
bound = np.invert(boundary_Gamma(x))
return bound
# creating different integration measures for different boundary segments
boundaries = [(1, boundary_Gamma),
(2, boundary_notGamma)]
facets = dolfinx.mesh.locate_entities(domain, fdim, locator)
facet_indices.append(facets)
facet_tag = dolfinx.mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = ufl.classes.Measure("ds", domain=domain, subdomain_data=facet_tag) #create custom measure to integrate over different boundary regions seperatly
D0 = ufl.TrialFunction(V)
def Da0(x):
'''Represents the incomming wave, returns amplitude of that wave at position'''
# print(type(x))
# global Y
# Y = x
return Amplitude*np.exp(1j*np.dot(s0,x))
chi_0 = dolfinx.fem.Constant(domain,chi0)
chi_h = dolfinx.fem.Constant(domain,chih)
chi_bh = dolfinx.fem.Constant(domain,chibh)
Da_0 = dolfinx.fem.Function(V,
name = 'Da0',
dtype=complex)
Da_0.interpolate(Da0)
Dh_start = dolfinx.fem.Constant(domain, PETSc.ScalarType(0 - 0j))
const1 = dolfinx.fem.Constant(domain, PETSc.ScalarType(-1j * (np.pi / lam) * chi0))
const2 = dolfinx.fem.Constant(domain, PETSc.ScalarType(1j * (np.pi/lam) * chibh * Dh_start))
# # later to use when D_h not identically zero
# D_h = dolfinx.fem.Function(V,
# name = 'Dh',
# dtype=complex)
# D_h.x.array[:] = 0.0
#Define dirichlet BC where on the segment defined by boundary_Gamma D0 should equal the incomming wave
bc = dolfinx.fem.dirichletbc(Da_0, dolfinx.fem.locate_dofs_geometrical(V, boundary_Gamma))
#Defining lhs as a and rhs as b
a = (- ufl.inner(s_0*D0, ufl.grad(v)) + ufl.inner(const1 *D0, v)) * ufl.dx + ufl.inner(D0,v) * ds(2) #
l = ufl.inner(const2,v) * ufl.dx - ufl.inner(Da_0, v) * ds(1)
problem = petsc.LinearProblem(a,l,bcs=[bc])
D0_solve = problem.solve()
import pyvista
from dolfinx import plot
pyvista.start_xvfb()
tdim = domain.topology.dim
domain.topology.create_connectivity(tdim, tdim)
topology, cell_types, geometry = plot.vtk_mesh(domain,tdim)
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
plotter = pyvista.Plotter()
plotter.view_xy()
if not pyvista.OFF_SCREEN:
plotter.show()
figure = plotter.screenshot("fundamentals_mesh.png")
u_topology, u_cell_types, u_geometry = plot.vtk_mesh(V)
u_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
# u_grid.point_data["D_h"] = D_h.x.array.imag
# u_grid.set_active_scalars("D_h")
# u_grid.point_data["Da_0"] = Da_0.x.array.real
# u_grid.set_active_scalars("Da_0")
# u_grid.point_data["Da_0"] = Da_0.x.array.imag
# u_grid.point_data["D0"] = D0_solve.x.array.real
# u_grid.set_active_scalars("D0")
# u_grid.point_data["D0"] = D0_solve.x.array.real**2 + D0_solve.x.array.imag**2
u_plotter = pyvista.Plotter()
u_plotter.add_mesh(u_grid, show_edges=False)
u_plotter.view_xy()
u_plotter.show()
# cells, types, x = plot.vtk_mesh(V, entities=facet_tag.find(1))
subplotter = pyvista.Plotter(shape=(1, 2))
subplotter.subplot(0, 0)
subplotter.add_text("Mesh with markers", font_size=14, color="black", position="upper_edge")
subplotter.add_mesh(grid, show_edges=True, show_scalar_bar=False)
subplotter.view_xy()
dof_gamma = dolfinx.mesh.locate_entities_boundary(domain,fdim,boundary_Gamma)
# dof_gamma = dolfinx.fem.locate_dofs_geometrical(V, boundary_Gamma)
cells, types, x = plot.vtk_mesh(V, entities = dof_gamma)
sub_grid = pyvista.UnstructuredGrid(cells, types, x)
subplotter.subplot(0, 1)
subplotter.add_text("Subset of mesh", font_size=14, color="black", position="upper_edge")
subplotter.add_mesh(sub_grid, show_edges=True, edge_color="black")
if pyvista.OFF_SCREEN:
figsize = 100
subplotter.screenshot(
"2D_markers.png", transparent_background=transparent, window_size=[2 * figsize, figsize]
subplotter.show()
p.s. this is the first time ever I post on one of these forums so If I didn’t properly paste the code please tell me how to do it.
