I need to use real elements from scifem libary and I would appreciate if someone could answer a few questions I have. The relevant solved example is this:
I noticed that in defining the weak form, simply replacing ufl.dx with dx = ufl.Measure('dx', domain=mesh, subdomain_data=cell_tags) leads to a long cryptic error in the bilinear form compilation (and perhaps in linear too). Is it really prevented to use ufl.Measure('dx') when formulating the problem this way or there is a correct way to do it?
How the code should be modified when the problem is non-linear? Any examples I could study?
I thought I had closely adapted the example model so an MWE was redundant. But it is embarrassing to acknowledge how I still terribly underestimate the significance of this step
While turning an MWE, I realized that I can indeed ufl.Measure('dx'). At least in my specific case, I had a sum of multiple terms in one expression and I was using ufl.dx with some and ufl.Measure(βdxβ) with others. Uniformly using ufl.Measure('dx') with all terms in that line has solved the problem and I will happily take it for now
I am taking your word that real function space is like any other and trying to solve it how I would ordinarily solve a mixed function space problem. The motivation is to use ufl.lhs and ufl.rhs to automatically extract the bilinear and linear forms. I am expecting to have an array of real elements which will make it terrible to manually construct the block matrix.
However, I am getting an error with ufl.lhs and ufl.rhs operations that I do not understand. I would really appreciate if you could fix the adaptation below of the example model
Thanks a lot!
EDIT: I am using dolfinx 0.9 through conda
from packaging.version import Version
from dolfinx.cpp.la.petsc import scatter_local_vectors, get_local_vectors
import dolfinx.fem.petsc
from scifem import create_real_functionspace, assemble_scalar
M = 20
mesh = dolfinx.mesh.create_unit_square(
MPI.COMM_WORLD, M, M, dolfinx.mesh.CellType.triangle, dtype=np.float64
def u_exact(x):
return 0.3 * x[1] ** 2 + ufl.sin(2 * ufl.pi * x[0])
n = ufl.FacetNormal(mesh)
g = ufl.dot(ufl.grad(u_exact(x)), n)
f = -ufl.div(ufl.grad(u_exact(x)))
h = assemble_scalar(u_exact(x) * ufl.dx)
# We then create the Lagrange multiplier space
R = create_real_functionspace(mesh)
# Next, we can create a mixed-function space for our problem
if dolfinx.__version__ == "0.8.0":
u = ufl.TrialFunction(V)
lmbda = ufl.TrialFunction(R)
du = ufl.TestFunction(V)
dl = ufl.TestFunction(R)
elif Version(dolfinx.__version__) >= Version("0.9.0.0"):
W = ufl.MixedFunctionSpace(V, R)
u, lmbda = ufl.TrialFunctions(W)
du, dl = ufl.TestFunctions(W)
raise RuntimeError("Unsupported version of dolfinx")
# We can now define the variational problem
zero = dolfinx.fem.Constant(mesh, dolfinx.default_scalar_type(0.0))
dx = ufl.Measure('dx', mesh)
F = ufl.inner(ufl.grad(u), ufl.grad(du)) * ufl.dx
F += ufl.inner(lmbda, du) * ufl.dx
F += ufl.inner(u, dl) * ufl.dx
F += -ufl.inner(f, du) * ufl.dx + ufl.inner(g, du) * ufl.ds
F += -ufl.inner(zero, dl) * ufl.dx
a = ufl.lhs(F)
L = ufl.rhs(F)
petsc_options = {"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type": "mumps"}
problem = LinearProblem(a, L, bcs=[], petsc_options=petsc_options)
uh = problem.solve()
