Hello everyone,
1- How I can find the minimum eigenvalue ?
2- How I can determine the eigenvectors correspond to the minimum eigenvalue ?
3 -How I can plot the eigenvectors ?
Thank you for your time and consideration.
Cordially
Hello everyone,
Cordially
Consider the following example:
# Set up some simple variational form for illustration:
mesh = UnitIntervalMesh(100)
V = FunctionSpace(mesh,"CG",1)
a = dot(grad(u),grad(v))*dx + u*v*dx
# Must assemble form to a PETScMatrix:
A = PETScMatrix()
assemble(a,tensor=A)
# Create eigenvalue solver:
eigenSolver = SLEPcEigenSolver(A)
# Configure solver to get the smallest eigenvalues first:
eigenSolver.parameters["spectrum"]="smallest magnitude"
# Solve for the N smallest eigenvalues:
N = 5
eigenSolver.solve(N)
for i in range(0,N):
# The smallest eigenpair is the first (0-th) one:
r, c, rx, cx = eigenSolver.get_eigenpair(i)
# Turn the eigenvector into a Function:
rx_func = Function(V)
rx_func.vector()[:] = rx
# Function can be plotted as usual:
plot(rx_func)
plt.autoscale()
Thank you for helping me with your detailed answer.
