Ratio of two solutions (cell wise) containing zeros
I have a problem while defining ratio of two solution functions. I am not getting the expected answer as seen in the pictures below. I would like to know whether I am understanding the issue properly or not. I fear, I won’t be able to post the exact code because it is too long but I am posting below a MWE which to my understanding is working perfectly fine(because there aren’t any zero values involved). I am also posting pictures below which are calculated in DG-0 space, to my understanding I expect zero values to the left and right of the non-zero layer of values(I am adding a tolerance value to actual denominator array to avoid issue of dividing by zero) , but that’s not what I get. I want to know whether the division is happening cell-wise for both solutions or not.
MWE
#calculating f expression
msh = create_unit_square(MPI.COMM_WORLD,1,1)
f = x[0] + x[1]
V = dolfinx.fem.functionspace(msh, ("DG", 0))
f_vl = fem.Function(V)
f_exp = dolfinx.fem.Expression(f,V.element.interpolation_points())
f_vl.interpolate(f_exp)
# calculating g expression
g = 2*(x[0])
g_vl = fem.Function(V)
g_exp = dolfinx.fem.Expression(g,V.element.interpolation_points())
g_vl.interpolate(g_exp)
# calculate ratio
ratio = fem.Function(V)
ratio.x.array[:] = f_vl.x.array/g_vl.x.array
solution pics
solution1
solution 2
ratio
The pictures clearly do not correspond to the code, as there are several cells, while in the snippet there is only one.
The ratio happens between values at each DOF. In your case (DG 0) there is a DOF at each cell, so in particular it is also the cell wise ratio.
dr @francesco-ballarin I appreciate your response, yes, these pictures don’t correspond to the code, but I am using similar approach to compute these. The issue is first solution is result of a very long code for which MWE is not reproducible, but that part is correct. I know I am calculating pic 1 and pic 2 correclty, my issue is only with ratio part. Please allow me to put the code how pic 2 is computed and for the ratio part.
# calculate pic2 i.e f- a.grad(u_h)
# compute gradient and interpolate into DG-0 space
mesh_coarse = u_H1_projection.function_space.mesh
gdim = mesh_coarse.geometry.dim
dg_space = dolfinx.fem.functionspace(mesh_coarse,('DG',0,(gdim,)))
grad_u_H1 = dolfinx.fem.Function(dg_space)
grad_uh = dolfinx.fem.Expression(grad(u_H1_projection),dg_space.element.interpolation_points())
grad_u_H1.interpolate(grad_uh)
# compute c_T as interpolation in DG-0 space
vec_f = Constant(mesh_coarse,ScalarType((np.cos(np.pi/3),np.sin(np.pi/3))))
f = Constant(mesh_coarse, ScalarType(0))
c_space = dolfinx.fem.functionspace(mesh_coarse,('DG',0))
c_T = dolfinx.fem.Function(c_space)
c_T_expr = dolfinx.fem.Expression(f - inner(vec_f,grad_u_H1),c_space.element.interpolation_points())
c_T.interpolate(c_T_expr)
# compute the ratio a_T/c_T approx tau
tol = 1e-8
c_T_new = dolfinx.fem.Function(c_space)
c_T_new.x.array[:] = c_T.x.array + tol
a_T_c_T = dolfinx.fem.Function(c_space)
a_T_c_T.x.array[:] = u_prime_avg.x.array/c_T_new.x.array
here in the ratio part u_prime_avg is calculated correctly which corresponds to pic 1.
I still don’t understand what your issue is.
However, let me note that adding 1e-8 isn’t a foolproof way of guaranteeing that the denominator is non-zero. Your pic2 shows that the solution can have negative values, so if by chance the Function you put at the denominator had value -1e-8 at one DOF you would still end up with a zero denominator.
dr @francesco-ballarin thank you for your feedback, my only issue is the ratio picture i,e the third pic, I want zero values on the left and right hand side of the layer(non-zero value layer) . I wonder whether code is doing corresponding cell-wise division of pic1 and pic2 or not. As, I can see non-zero values in the left bottom corner of pic3, seems division is not happening corresponding cell-wise( I might be wrong). Can you please provide insight on how can I guarantee here my denominator is not zero. I hope that might resolve my issue.
Here is an almost trivial way of verifying the ratio:
msh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD,10,10)
f = x[0] + x[1]
f_vl = dolfinx.fem.Function(V)
g = 2*(x[0])
g_vl = dolfinx.fem.Function(V)
# calculate ratio
ratio = dolfinx.fem.Function(V)
ratio_exact = dolfinx.fem.Function(V)
ratio_expr = dolfinx.fem.Expression(f/g, V.element.interpolation_points())
ratio_exact.interpolate(ratio_expr)
np.testing.assert_allclose(ratio.x.array, ratio_exact.x.array)
dr. @dokken Thank you for that, I used it to test the values. I am not getting any error so far. I am not sure what’s going wrong with the pic 3.
I’m not sure anything is actually wrong. You are potentially dividing two small values by each-other, and thus ratios can blow up (imagine two entries being of magnitude 1e-15, but one is 9e-15, the other one 9e-16).
