I need to update a scalar value used within the variational problem for each iteration (since it is a dynamic simulation).
Is there any way to do that employing the assign function (or other similar) in the For loop?
I need to avoid compiling the weak formulation within the For loop, for some reason, it does not converge inside the loop but outside of it.
Regards,
Santiago
Consider the following:
import time
mesh = UnitSquareMesh(10,10)
alpha = Constant(1)
a = alpha*inner(u, v)*dx
for i in range(4):
alpha.assign(i)
start = time.time()
A = assemble(a)
end = time.time()
print(end-start, A.norm("frobenius"))
This produces
3.021070957183838 0.0
0.0009584426879882812 0.05157249482255294
0.0006306171417236328 0.10314498964510588
0.0006115436553955078 0.15471748446765718
As you can see, the form is only compiled once.
Dear Jorgen,
Thank you for the MWE! I will check it out!
Cheers, Santiago
