Reformulating mixed poisson problem
Hi I am trying to reformulate the mixed poisson equation. The original formulation imposed \sigma \cdot n = g as an essential boundary condition. I wanted to do the opposite, imposing u = u_0 on \Gamma_D as the essential boundary condition. But I couldn’t get the same result. I didn’t know what went wrong. Can you help me on this?
I use DOLFINx 0.6.0 and grabbed some pieces from tutorial to set the boundary conditions.
I am also curious why in the original formulation, we have
Q_el = element("BDMCF", domain.basix_cell(), k)
P_el = element("DG", domain.basix_cell(), k - 1).
The order in Q space should always be higher than that in P space. Otherwise no result returned, say not working for k=2 for both.
Here is my code for my formulation:
import pyvista
from ufl import FiniteElement, MixedElement
from ufl import(Measure, SpatialCoordinate, FacetNormal, TestFunctions, TrialFunctions,
                div, grad, exp, inner, sin)
domain = mesh.create_unit_square(MPI.COMM_WORLD, 12, 12, mesh.CellType.triangle)
k = 3
Q_el = FiniteElement("BDM", domain.ufl_cell(), k-1)
P_el = FiniteElement("DG", domain.ufl_cell(), k)
V_el = MixedElement([Q_el, P_el])
V = fem.FunctionSpace(domain, V_el)
(sigma, u) = TrialFunctions(V)
(tau, v) = TestFunctions(V)
x = SpatialCoordinate(domain)
f = 10.0 * exp(-((x[0] - 0.5)**2 + (x[1] - 0.5)**2) / 0.02)
g = sin(5 * x[0])
dx = Measure("dx", domain)
boundaries = [(1, lambda x: np.isclose(x[1], 0.0)),
              (2, lambda x: np.isclose(x[0], 1.0)),
              (3, lambda x: np.isclose(x[1], 1.0)),
              (4, lambda x: np.isclose(x[0], 0.0))]
    facets = mesh.locate_entities(domain, fdim, locator)
    facet_indices.append(facets)
facet_tag = mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
ds = Measure("ds", domain=domain, subdomain_data=facet_tag)
a = (inner(sigma, tau) - inner(grad(u), tau) - inner(sigma, grad(v))) * dx
L = - f * v * dx - v * g * ds(1) - v * g * ds(3)
def on_left_or_right(x):
    return np.isclose(x[0], 0) | np.isclose(x[0], 1)
P, _ = V.sub(1).collapse()
u_zero = fem.Function(P)
u_zero.x.array[:] = 0.0
boundary_facets = mesh.locate_entities_boundary(domain, domain.topology.dim-1,
                                                on_left_or_right)
boundary_dofs = fem.locate_dofs_topological((V.sub(1), P), domain.topology.dim-1,
                                            boundary_facets)
bc = fem.dirichletbc(u_zero, boundary_dofs, V.sub(1))
problem = LinearProblem(a, L, [bc], petsc_options={"ksp_type": "preonly",
                                                  "pc_type": "lu",
                                                  "pc_factor_mat_solver_type": "umfpack"})
w_h = problem.solve()
w_h.x.array
Hi I am answering my own question since I was so helpless. In the previous code, only change the line to create finite element to below:
Q_el = VectorElement("Lagrange", domain.ufl_cell(), 1)
P_el = FiniteElement("Lagrange", domain.ufl_cell(), 1)
and this problem is resolved. But I still don’t understand why in the original demo, the author chose to write it that way. This revised version seems to be more straightforward. Hopefully someone can take a look and leave some words. Many thanks.
This finite element formulation for the mixed Poisson problem is covered in e.g. Brenner and Scott’s book on the Finite Element Method.
In this mixed formulation \sigma \cdot n = g must be enforced strongly in the space (DirichletBC), and the boundary condition u = g ends up in the variational form (L).
I would recommend deriving the weak mixed form for this problem using pen and paper before returning to the DOLFINx implementation.
Your solution is not correct as the spaces Q (flux) and P (potential) are not an inf-sup stable pair. In short, the correct solution to your problem is to remove the terms - v * g * ds(1) - v * g * ds(3) from L (i.e. set g = 0).
Edit: I removed the essential/natural terminology from my original reply, I always feel its more confusing than helpful.
I just add another small note:
Setting multiple Dirichlet, Neumann, and Robin conditions — FEniCSx tutorial is using the primal (potential) formulation of the Poisson problem, whereas Mixed formulation for the Poisson equation — DOLFINx 0.8.0.0 documentation is using the mixed formulation (potential and flux) formulation of the Poisson problem.
Hi thank you for your professional reply. While I am doing in layman’s view, I may miss something. Forecast: this is going to be a lengthy reply.
For the mixed Poisson problem, we have two set of boundary condition, which are both Dirichlet, in a sense that the unknown functions, instead of their derivatives, are specified on the boundary. When I was reformulating, I chose different ways to impose the boundary condition:
  1. Strongly imposing u=u_0 on \Gamma_D, thus v=0 on \Gamma_D, and weakly imposing \vec{\sigma}\cdot\vec{n}=g on \Gamma_N, leading to
    \int_{\Omega}(\vec{\sigma}\cdot\vec{\tau}-\vec{\tau}\cdot\vec{\nabla}u-\vec{\sigma}\cdot\vec{\nabla}v)dx=-\int_{\Omega}fvdx-\int_{\Gamma_N}vgds.
    For this imposition, I can have the same answer as the original one, as answered by myself.
  2. Strongly imposing both boundary conditions, where we can even leave the original form without doing integration by part. Or we can integrate by part for both derivatives,
    \int_{\Omega}(\vec{\sigma}\cdot\vec{\tau}+u\vec{\nabla}\cdot\vec{\tau}-\vec{\sigma}\cdot\vec{\nabla}v)dx-\int_{\Gamma_D}u\vec{\tau}\cdot\vec{n}ds+\int_{\Gamma_N}v\vec{\sigma}\cdot\vec{n}=-\int_{\Omega}fvdx.
    In these two method, I can have the same answer but they are a little different from the original answer.
  3. Weakly imposing both boundary conditions.
    \int_{\Omega}(\vec{\sigma}\cdot\vec{\tau}+u\vec{\nabla}\cdot\vec{\tau}-\vec{\sigma}\cdot\vec{\nabla}v)dx-\int_{\Gamma_N}u\vec{\tau}\cdot\vec{n}ds+\int_{\Gamma_D}v\vec{\sigma}\cdot\vec{n}=-\int_{\Omega}fvdx-\int_{\Gamma_N}gvds.
    In this way I have the same answer as the original one.
But you are saying one has to impose the boundary condition as described in the demo. I don’t understand this. I checked Brenner and Scott’s. In the heading of Chapter 12 they said
“one characteristic of mixed methods is that not all choices of finite element spaces will lead to convergent approximations”.
Maybe this is what you were saying or the reason I got a different answer when I impose two bc strongly? BTW their mixed element was for static stokes equation if I recognized that.
I am perfectly fine with the word strongly imposing and weakly imposing. By stating the bc specifically in the input, one determines the bc term directly. While the other is solved through the algraic equations, where numerical error may occur.
I am doing mixed element because I wanted to solve a coupled equation for research purpose. So I am studying this.
I attach the code (dolfinx 0.6.0) here.
For part 2, the bilinear form for integration by part goes with boundary terms. The NO-integration-by-part goes WITHOUT boundary terms.
import pyvista
from ufl import FiniteElement, MixedElement, VectorElement
                div, grad, exp, inner)
k = 1
Q_el = VectorElement("Lagrange", domain.ufl_cell(), k)
P_el = FiniteElement("Lagrange", domain.ufl_cell(), k)
# bilinear and linear form for integration by part for both
a = (inner(sigma, tau) + u * div(tau) - inner(sigma, grad(v))) * dx
L = -f * v * dx
# bilinear and linear form for: leave the original form, do not perform integration by part
a = (inner(sigma, tau) - inner(grad(u), tau) + div(sigma) * v) * dx
L = - f * v * dx
with io.XDMFFile(domain.comm, "t1mixed_poisson_alt1/facet_tags.xdmf","w") as xdmf:
    xdmf.write_mesh(domain)
    xdmf.write_meshtags(facet_tag)
n = FacetNormal(domain)
# boundary terms for integration by part for both
a += + v * inner(sigma, n) * ds(1) + v * inner(sigma, n) * ds(3) - u * inner(tau, n) * ds(2) - u * inner(tau, n) * ds(4)
facet_top = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[1], 1.0))
Q, _ = V.sub(0).collapse()
dofs_top = fem.locate_dofs_topological((V.sub(0), Q), fdim, facet_top)
def f1(x):
    values = np.zeros((2, x.shape[1]))
    values[1, :] = np.sin(5 * x[0])
    return values
f_h1 = fem.Function(Q)
f_h1.interpolate(f1)
bc_top = fem.dirichletbc(f_h1, dofs_top, V.sub(0))
facet_bottom = mesh.locate_entities_boundary(domain, fdim, lambda x: np.isclose(x[1], 0.0))
dofs_bottom = fem.locate_dofs_topological((V.sub(0), Q), fdim, facet_bottom)
def f2(x):
    values[1, :] = -np.sin(5 * x[0])
    return values
f_h2 = fem.Function(Q)
f_h2.interpolate(f2)
bc_bottom = fem.dirichletbc(f_h2, dofs_bottom, V.sub(0))
facet_left_or_right = mesh.locate_entities_boundary(domain, fdim, lambda x: np.logical_or(np.isclose(x[0], 0.0), np.isclose(x[0], 1.0)))
dofs_left_or_right = fem.locate_dofs_topological((V.sub(1), P), fdim, facet_left_or_right)
u_left_or_right = fem.Function(P)
u_left_or_right.x.array[:] = 0.0
bc_left_or_right = fem.dirichletbc(u_left_or_right, dofs_left_or_right, V.sub(1))
bc = [bc_top, bc_bottom, bc_left_or_right]
problem = LinearProblem(a, L, bc, petsc_options={"ksp_type": "preonly",
                                                  "pc_type": "lu",
                                                  "pc_factor_mat_solver_type": "mumps"})
sigma_h, u_h = w_h.sub(0).collapse(), w_h.sub(1).collapse()
grid = pyvista.UnstructuredGrid(*plot.create_vtk_mesh(P))
grid.point_data["u"] = u_h.x.array.real
grid.set_active_scalars("u")
plotter = pyvista.Plotter()
plotter.add_mesh(grid, show_edges=True, show_scalar_bar=True)
plotter.view_xy()
plotter.show()
For the weak imposition for both bc (part 3):
import pyvista
k = 1
g = sin(5 * x[0])
L = - f * v * dx
a += - u * inner(tau, n) * ds(1) - u * inner(tau, n) * ds(3)\
    + v * inner(sigma, n) * ds(2) + v * inner(sigma, n) * ds(4)
L += - g * v * ds(1) - g * v * ds(3)
problem = LinearProblem(a, L, petsc_options={"ksp_type": "preonly",
                                                  "pc_type": "lu",
plotter.view_xy()
plotter.show()
I can well believe that some of your answers look ok or are close.
However, what I’m trying to get across is that unless you are doing the numerical analysis of your proposed formulations, and showing that you have stability and convergence in the discrete setting, then you are treading on dangerous ground.
The Hdiv x L^2 formulation using the finite element spaces in the example has rigorous proofs associated with it that guarantee good behavior in specific conditions.
Thank you so much! You pointed out the very thing that I have been worried about and actually not familiar with at all! Thank you so much!!!
