DOLFINX VERSION .
Hello, I need these same condition models, y>= int2-tol, I have a mesh, divided into hydrogels and elastomers, where I need to define the concentrations of cations and anions, which are different in each region, could anyone help me?
"""Concentrações iniciais"""
DOlfin_Eps= 0.3e-17
tol = 1e-12
scaleX = 2.0e4 # 2 cm
scaleY = 900.e0 # 0.9 mm
# N number of elements in y-direction
int1 = 200.e0 #
int2 = scaleY/2.-int1
int3 = int1/2.0 + int2
class InitOmg():
def __init__(self):
self.t= 0.0
self.Tramp =T2_tot
self.scalex = scaleX
self.cPos0= cPos0
self.cNeg0= cNeg0
self.cNum= DOlfin_Eps
def eval(self,x):
if abs(x[1])>= int2-tol:
return ufl.ln((self.cNeg0))
return ufl.ln((self.cNum))
Init_POS= InitOmg()
POs= fem.Function(spaces[1])
POs.interpolate(Init_POS.eval)
w_old.sub(1).interpolate(POs)
I have already tried different ways, including using this format, however, the concentrations found do not satisfy the desired solution.
domain, cell_tags, facet_tags = gmshio.read_from_msh("malhas/capacitor_geometria_pronta_g.msh", MPI.COMM_WORLD,0, gdim=2)
"""Function Space"""
# Define function space, scalar
U2 = ufl.VectorElement("Lagrange", domain.ufl_cell(), 1) # Displacent
P1 = ufl.FiniteElement("Lagrange", domain.ufl_cell(), 1) # concentrações + - , electric potential
D0 = ufl.FiniteElement("DG", domain.ufl_cell(), 0)
D1 = ufl.FiniteElement("DG", domain.ufl_cell(), 1)
# DOFs
TH = ufl.MixedElement([U2, P1, P1, P1])
ME = fem.FunctionSpace(domain, TH) # Total space for all DOFs
W = fem.FunctionSpace(domain,P1) # Scalar space for visualization later
"""Extraindo os sub espaços do elemento misto e os mapas contendo os graus de liberdade """
num_subs = ME.num_sub_spaces
spaces = []
maps = []
for i in range(num_subs):
space_i, map_i = ME.sub(i).collapse()
spaces.append(space_i)
maps.append(map_i)
"""Aplicando as propriedades dos materiais"""
1 28 "Voltagem"
1 27 "Aterramento"
1 22 "Engaste_esquerda"
1 23 "Engaste_direita"
2 24 "Hidrogel_superior"
2 25 "Hidrogel_inferior"
2 26 "elastomero"
2 27 "dominio"
"""Extrair as tags da malha"""
def tag(n_tag):
return cell_tags.find(n_tag)
"Determinação das propriedades de um material "
def mat_features(function_descontinuo, material, constanste):
space_Mat = fem.Function(function_descontinuo)
for i in range(len(material)):
space_Mat.x.array[material[i]] = np.full_like(material[i], constanste[i], dtype=ScalarType)
return space_Mat
""" Implementação das propriedades em cada regiao"""
Q = fem.FunctionSpace(domain, D0)
hidrogel_sup = tag(24)
hidrogel_inf = tag(25)
elastomero = tag(26)
DOlfin_Eps= 0.3e-17
# A ordem de entrada das propriedades na lista deve ser equivalente ao espaço no qual o material ocupa dentro do dominio
material_ = [elastomero, hidrogel_inf, hidrogel_sup]
# Initial electro-chemical potentials
Init_CPos= fem.Function(Q)
Init_CPos.x.array[material_[0]]= ufl.ln(DOlfin_Eps)
Init_CPos.x.array[material_[1]]= ufl.ln(cPos0)
Init_CPos.x.array[material_[2]]= ufl.ln(cPos0)
w_old.sub(1).interpolate(Init_CPos)
Init_CNeg= fem.Function(Q)
Init_CNeg.x.array[material_[0]]= ufl.ln(DOlfin_Eps)
Init_CNeg.x.array[material_[1]]= ufl.ln(cNeg0)
Init_CNeg.x.array[material_[2]]= ufl.ln(cNeg0)
w_old.sub(3).interpolate(Init_CNeg)
here is the model that implemented it correctly, however it is in the version where the Expression argument is obsolete
DOLFIN VERSION
init_omgPos = Expression('abs(x[1])>=int2-tol?std::log((cPos0)):std::log((cNum))', int2=int2, tol = tol, cPos0 = cPos0, cNum=DOLFIN_EPS, degree=0)
omgPos_init = interpolate(init_omgPos,ME.sub(1).collapse())
assign(w_old.sub(1),omgPos_init)
below we have the expected behavior.
and subsequently the incorrect one, it is worth highlighting that the division is hydrogel, elastomer, hydrogel
I can open another call and make the complete code available if necessary for better interpretation, thank you in advance for any effort to help me
