Hello!
I’m trying to switch to dolfinx from dolfin 2019. In dolfin 2019, one could remove reorder dofs serial and allow extrapolation using the following code
parameters["reorder_dofs_serial"] = False
parameters["allow_extrapolation"] = True
But when I try to do the same thing in dolfinx
from dolfinx import *
I get the following error
File "/home/projects/test/fenicsx/parameters/parameters.py", line 3, in <module>
NameError: name 'parameters' is not defined
Could you please tell me how to do this in dolfinx? I used this functionality to make the indices of dofs and vertices coincide in the case of linear scalar function space.
