So I am trying to port this notebook Topology Optmisation to Fenicsx.
The code I managed to put together so far is below, for your convenience I place the old, commented out Fenics lines as well as the Fenicsx “translation”.
######### DOLFIN ##########
#%matplotlib notebook
#from dolfin import *
#import matplotlib.pyplot as plt
#import numpy as np
########## DOLFIN ##########
########## DOLFINX ##############
from dolfinx import *
from dolfinx.fem import FunctionSpace
from dolfinx.fem import VectorFunctionSpace
from dolfinx import fem
from dolfinx import mesh
# Algorithmic parameters
niternp = 20 # number of non-penalized iterations
niter = 80 # total number of iterations
pmax = 4 # maximum SIMP exponent
exponent_update_frequency = 4 # minimum number of steps between exponent update
tol_mass = 1e-4 # tolerance on mass when finding Lagrange multiplier
thetamin = 0.001 # minimum density modeling void
# Problem parameters
#thetamoy = 0.4 # target average material density
#E = Constant(1)
#nu = Constant(0.3)
#lamda = E*nu/(1+nu)/(1-2*nu)
#mu = E/(2*(1+nu))
#f = Constant((0, -1)) # vertical downwards force
E = fem.Constant(domain, ScalarType(1))
nu = fem.Constant(domain, ScalarType(0.3))
mu = E/(2*(1+nu))
f = fem.Constant(domain, ScalarType([0,-1])) # vertical downwards force
# Mesh
#mesh = RectangleMesh(Point(-2, 0), Point(2, 1), 50, 30, "crossed")
# Boundaries
#def left(x, on_boundary):
# return near(x[0], -2) and on_boundary
#def load(x, on_boundary):
# return near(x[0], 2) and near(x[1], 0.5, 0.05)
#facets = MeshFunction("size_t", mesh, 1)
#AutoSubDomain(load).mark(facets, 1)
#ds = Measure("ds", subdomain_data=facets)
L = 5
domain = mesh.create_box(MPI.COMM_WORLD,[[0.0,0.0,0.0], [L, 1, 1]], [20, 5, 5], mesh.CellType.hexahedron)
tdim = domain.topology.dim
fdim = tdim - 1
# Boundaries
# Function space for density field
#V0 = FunctionSpace(mesh, "DG", 0)
# Function space for displacement
#V2 = VectorFunctionSpace(mesh, "CG", 2)
# Fixed boundary condtions
#bc = DirichletBC(V2, Constant((0, 0)), left)
V0 = FunctionSpace(domain, ("DG", 0))
V2 = VectorFunctionSpace(domain, ("CG", 1))
#bc = fem.Constant(domain, ScalarType([0,0]), left)
p = Constant(1) # SIMP penalty exponent
exponent_counter = 0 # exponent update counter
lagrange = Constant(1) # Lagrange multiplier for volume constraint
thetaold = Function(V0, name="Density")
thetaold.interpolate(Constant(thetamoy))
coeff = thetaold**p
theta = Function(V0)
volume = assemble(Constant(1.)*dx(domain=mesh))
avg_density_0 = assemble(thetaold*dx)/volume # initial average density
avg_density = 0.
#p = Constant(1) # SIMP penalty exponent
#exponent_counter = 0 # exponent update counter
#lagrange = Constant(1) # Lagrange multiplier for volume constraint
#thetaold = Function(V0, name="Density")
#thetaold.interpolate(Constant(thetamoy))
#coeff = thetaold**p
#theta = Function(V0)
p = fem.Constant(domain, ScalarType(1)) # SIMP penalty exponent
lagrange = fem.Constant(domain, ScalarType(1))# Lagrange multiplier for volume constraint
thetaold = fem.Function(V0, name="Density")
thetaold.interpolate(fem.Constant(domain, ScalarType(thetamoy)))
coeff = thetaold**p
The problem lies in
I get an error message
Couldn't map 'c_5' to a float, returning ufl object without evaluation.
like in this post, couldnt-map-float-returning-object-without-evaluation/
I tried the suggested solution
thetaold.x.set(thetamoy)
but I am not so sure it is correct, what does for example .x stand for?
The next step where I have issues is the Fenics lines
avg_density = 0.
I tried to rewrite in Fenicsx as
################# DOLFINX#############
volume = fem.assemble(fem.Constant(domain, ScalarType(1))*dx(domain=domain))
avg_density_0 = fem.assemble(thetaold*dx)/volume # initial average density
avg_density = 0.
but I get the error message
name 'dx' is not defined
and I am at a loss. In the legacy code ds = Measure("ds", subdomain_data=facets) is defined, but not dx
Also in the Fenicsx Poisson tutorial,
Implementation — FEniCSx tutorialFenicsx Poisson tutorial
dx is not defined.
Any hint would be most appreciated, I am really keen to port this example to Fenicsx, thanks
