Hi all,
I have a slightly unusual goal of exactly replicating a firedrake simulation using dolfin 2019.1 with custom SNES problem and solver classes inspired primarily by this post. I will demonstrate my question with a minimal working example of a lid driven cavity Navier Stokes simulation. The following code excerpt is written with dolfin, and writing the analogous firedrake code is simply a matter of replacing dl. with fe., except in the lines with comments that specify otherwise. I am running firedrake version 0.13.0+5443.g76237bef.dirty.
import dolfin as dl
from petsc_utils import *
inner, dot, grad, div, sym, split = \
ufl.inner, ufl.dot, ufl.grad, ufl.div, ufl.sym, ufl.split
# initialize the simulation
reynolds_number=dl.Constant(10)
solver_parameters = {
"snes_monitor": None,
"ksp_monitor": None,
"ksp_norm_type":-1,
"snes_converged_reason": None,
"snes_type": "newtonls",
"snes_linesearch_type": "basic",
"ksp_type": "preonly",
"pc_type": "lu",
"mat_type": "aij",
# initialize the mesh, element, solution space
mesh_dimensions=(50,50)
mesh = dl.UnitSquareMesh(*mesh_dimensions, diagonal="left")
taylor_hood_pressure_degree = 1
element = dl.MixedElement(
dl.FiniteElement("P", mesh.ufl_cell(), taylor_hood_pressure_degree),
dl.VectorElement("P", mesh.ufl_cell(), taylor_hood_pressure_degree + 1))
# solution is initialized trivally by default - u and p are both zero vectors
solution = dl.Function(dl.FunctionSpace(mesh, element))
solution_space = solution.function_space()
# pressure nullspace: this applies the constant 1 to pressure dofs, 0 to velocity dofs
# pressure = sub(0) = (1d) scalar field
# velocity = sub(1) = (2d) vector field
w=dl.interpolate(dl.Constant((1.0,0.0,0.0)),solution_space)
nullspace=dl.VectorSpaceBasis([w.vector().copy()])
nullspace.orthonormalize()
# in firedrake, we can simply use:
# nullspace=fe.MixedVectorSpaceBasis(solution_space,(fe.VectorSpaceBasis(constant=True),solution_space.sub(1)))
# dirichlet bc
left = 'near(x[0], 0)'
right = 'near(x[0], 1)'
bottom = 'near(x[1], 0)'
top = 'near(x[1], 1)'
# in firedrake, we have
# left = 1
# right = 2
# bottom = 3
# top = 4
noslip = dl.Constant((0.,)*mesh.geometric_dimension())
veltop=dl.Constant((1.0,0.0))
dirichlet_boundary_conditions=[dl.DirichletBC(solution_space.sub(1), noslip, left),
dl.DirichletBC(solution_space.sub(1), noslip, right),
dl.DirichletBC(solution_space.sub(1), noslip, bottom),
dl.DirichletBC(solution_space.sub(1), veltop, top),
# weak form residual
quadrature_degree=None
dx = ufl.dx(degree = quadrature_degree)
p,u=dl.split(solution)
psi_p,psi_u=dl.TestFunctions(solution_space)
weak_form_residual=psi_p*div(u)*dx + (dot(psi_u, grad(u)*u) - div(psi_u)*p + 2./reynolds_number*inner(sym(grad(psi_u)), sym(grad(u))))*dx
# set up nonlinear problem
problem = SNESProblem(weak_form_residual,
solution,
dirichlet_boundary_conditions,
nullspace=nullspace)
# set up SNES solver and solve
snes=CustomSNESSolver(problem, solver_parameters, nullspace, dl.MPI.comm_world)
snes.solve()
# In firedrake, we'd instead use
# # set up nonlinear problem
# problem = fe.NonlinearVariationalProblem(
# F = weak_form_residual,
# u = solution,
# bcs = dirichlet_boundary_conditions,
# J = fe.derivative(weak_form_residual, solution))
# # set up SNES solver and solve
# solver = fe.NonlinearVariationalSolver(
# problem = problem,
# nullspace = nullspace,
# solver_parameters = solver_parameters)
# solver.solve()
the imported file petsc_utils.py contains the custom SNES Problem and Solver classes:
from dolfin import PETScVector, PETScMatrix, TestFunction, TestFunctions, TrialFunctions, TrialFunction, derivative, assemble_system, assemble, PETScOptions, inner
from dolfin import as_backend_type, MPI
class SNESProblem():
def __init__(self, F, u, bcs, nullspace=None):
V = u.function_space()
self.V=V
du = TrialFunction(V)
self.u_test = TestFunction(V)
self.L = F
self.a = derivative(F, u, du)
self.p = derivative(F, u, du)
if len(V.ufl_element().sub_elements())==2:
ptest,_=TestFunctions(V)
ptrial,_=TrialFunctions(V)
elif len(V.ufl_element().sub_elements())==3:
ptest,_,_=TestFunctions(V)
ptrial,_,_=TrialFunctions(V)
self.bcs = bcs
self.u = u
self.nullspace=nullspace
def F(self, snes, x, F):
x = PETScVector(x)
F = PETScVector(F)
x.vec().copy(self.u.vector().vec())
self.u.vector().apply("")
assemble(self.L, tensor=F)
for bc in self.bcs:
bc.apply(F, x)
def J(self, snes, x, J, P):
J = PETScMatrix(J)
P = PETScMatrix(P)
x.copy(self.u.vector().vec())
dummy = ufl.inner(self.u, self.u_test)*ufl.dx
# index set for pressure components, i.e. V.sub(0)
pc=snes.ksp.pc
fields=[]
subdofs=self.V.sub(0).dofmap().dofs()
IS=PETSc.IS().createGeneral(subdofs)
fields.append((str(0), IS))
pc.setFieldSplitIS(*fields)
# assemble
assemble_system(self.a, dummy, self.bcs, A_tensor = J)
assemble_system(self.p, dummy, self.bcs, A_tensor = P)
# attach nullspace
if self.nullspace is not None:
as_backend_type(J).set_nullspace(self.nullspace)
self.attach_nullspace(J, P)
# seems like I shouldnt have to do this bc loop given assemble_system takes bcs, yet solver gets stuck if you comment it out
for bc in self.bcs:
bc.apply(J)
bc.apply(P)
def attach_nullspace(self, J, P):
# attach nullspace for pressure dofs
self.comm=MPI.comm_world
nsp=PETSc.NullSpace().create(comm=self.comm)
J.mat().setNullSpace(nsp)
P.mat().setNullSpace(nsp)
is_=PETSc.IS().createGeneral(self.u.sub(0).function_space().dofmap().dofs(),comm=self.comm)
is_.compose('nullspace',nsp)
class CustomSNESSolver():
def __init__(self, problem, solver_parameters, nullspace, comm):
self.problem=problem
self.solver_parameters=solver_parameters
self.comm=comm
# create SNES solver
self.snes = PETSc.SNES().create(self.comm)
# set PETSc options from solver_parameters dict
self.set_petsc_options_from_dict(self.solver_parameters)
self.snes.setFromOptions()
# set function, jacobian
b = PETScVector()
J_mat = PETScMatrix()
P_mat = PETScMatrix()
self.snes.setFunction(self.problem.F, b.vec())
self.snes.setJacobian(self.problem.J, J_mat.mat(), P_mat.mat())
# save matrices for debugging when SNES.Problem is called during solve()
self.b=b
self.J_mat=J_mat
self.P_mat=P_mat
def solve(self):
# apply bcs
for bc in self.problem.bcs:
bc.apply(self.problem.u.vector())
self.snes.solve(None, self.problem.u.vector().vec())
def set_petsc_options_from_dict(self,solver_parameters_dict):
for key, value in solver_parameters_dict.items():
if value is None:
PETScOptions.set(key)
PETScOptions.set(key,value)
In dolfin, I get the following output:
0 SNES Function norm 1.347013156745e+00
0 KSP Residual norm 1.347013156745e+00
1 KSP Residual norm 6.598859834202e-14
1 SNES Function norm 5.785669420919e-03
0 KSP Residual norm 5.785669420919e-03
1 KSP Residual norm 1.378854855395e-13
2 SNES Function norm 9.341656752388e-06
0 KSP Residual norm 9.341656752388e-06
1 KSP Residual norm 2.353857907220e-13
3 SNES Function norm 8.756520653743e-12
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 3
whereas in firedrake, I get
1 KSP Residual norm 1.571543510327e-12
1 SNES Function norm 5.785669420917e-03
0 KSP Residual norm 5.785669420917e-03
1 KSP Residual norm 2.467259171461e-13
2 SNES Function norm 9.341656753825e-06
0 KSP Residual norm 9.341656753825e-06
1 KSP Residual norm 8.956712819439e-13
3 SNES Function norm 8.070849898795e-12
Nonlinear firedrake_0_ solve converged due to CONVERGED_FNORM_RELATIVE iterations 3
In both cases, we have convergence, but I am wondering why the SNES function norms differ slightly by the third iteration between firedrake and dolfin. This has consequences for me later on when running a more complex Navier Stokes based simulation, so I am wondering if someone can offer tips to help get these two to be identical. My guess is I need to change something in my SNESProblem.J function. Note that I use dl.assemble_system instead of dl.assemble, because both firedrake and dl.assemble_system perform symmetric elimination of Dirichlet boundary conditions. I have gone in with a debugger and poked around inside SNESProblem.J and in the firedrake source code. When I assemble my Jacobians and convert them to dense matrices (numpy arrays), they look to match up to permutation of columns/rows (presumably because dolfin orders dofs differently than firedrake). Also, running snes.view() looks to show that the solver parameters are getting set the same in both codes.
Thank you for your time and assistance!
