Hey, I am trying to solve a problem in a mixed space where one of the elements is a tensor-valued Raviart–Thomas element and requires the integral of its trace over the domain to be zero. Following the recent discussions on implementing a Lagrange multiplier (Lagrange Multiplier for the NS equation with additional constrain · Issue #3341 · FEniCS/dolfinx · GitHub and Lagrange Multiplier for the Poisson equation with pure Neumann boundary conditions · Issue #3121 · FEniCS/dolfinx · GitHub) I have tried to create a custom Newton solver. I am facing two issues:
- The residual norm computed in parallel (>1) execution differs by many orders of magnitude from serial.
- In serial, the solver converges well (~1e-7 residual norm) within the first few iterations, remains constant, and then diverges.
Could there be a fundamental problem in my implementation? I’ve tried quite a few things now and haven’t been able to narrow down the problem. Any help would be appreciated! Also, Dirichlet conditions are manifested in the variational form, so I don’t need to account for them in the solver.
import dolfinx as dfx
import dolfinx.fem.petsc
import logging
logging.basicConfig(level=logging.DEBUG)
logger = logging.getLogger()
PETSc.Log.begin()
class DirectNewtonRLMSolver():
def __init__(self, solution: dfx.fem.Function, a: dfx.fem.Form, L: dfx.fem.form, lm: dfx.fem.form, solver, comm=None, verbose=True):
self.comm = comm
self.verbose = verbose
self.sol = solution
self.a = a
self.L = L
self.F = self.a - self.L
self.residual = dfx.fem.form(self.F)
self.J = ufl.derivative(self.F, self.sol)
self.jacobian = dfx.fem.form(self.J)
self.lm_form = dfx.fem.form(lm)
self._base_setup()
self.solver = self.config_solver(solver)
def _base_setup(self):
self.bt = self.make_extension_vector(self.lm_form)
local_size = self.bt.getLocalSize()
self.A_aug = PETSc.Mat().createAIJ(((local_size + (1 if self.comm.rank == self.comm.size - 1 else 0), PETSc.DECIDE), (local_size + (1 if self.comm.rank == self.comm.size - 1 else 0), PETSc.DECIDE)), comm=self.comm)
self.b_aug = PETSc.Vec().createMPI((local_size + (1 if self.comm.rank == self.comm.size - 1 else 0), PETSc.DECIDE), comm=self.comm)
self._obj_vec = PETSc.Vec().createMPI((local_size + (1 if self.comm.rank == self.comm.size - 1 else 0), PETSc.DECIDE), comm=self.comm)
self.x = self.b_aug.duplicate()
self.update_solution(self.x)
self.A = dfx.fem.petsc.create_matrix(self.jacobian)
self.b = dfx.fem.petsc.create_vector(self.residual)
self._last_rank_debug(f"matrix A global size {self.A.getSize()}")
def _last_rank_debug(self, message):
if self.verbose:
if self.comm.rank == self.comm.size - 1:
logger.info(f"Rank {self.comm.rank}: {message}")
def make_extension_vector(self, lm_form):
bt = dfx.fem.petsc.create_vector(lm_form)
dfx.fem.petsc.assemble_vector(bt, self.lm_form)
bt.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
bt.assemble()
return bt
def residual_norm(self, x: PETSc.Vec, obj: PETSc.Vec) -> np.float64:
self._last_rank_debug(f"assembling objective vector")
lam_l = x.getValue(x.getOwnershipRange()[1] - 1)
lam_l = 0
lam = self.comm.allreduce(lam_l, op=MPI.SUM)
self._last_rank_debug(f"lam = {lam}")
self.b.axpy(lam, self.bt)
self.b.assemble()
obj.setValues(range(*(self.b.getOwnershipRange())), self.b)
cx = self.bt.dot(self.sol.vector)
self._last_rank_debug(f"cx = {cx}")
obj.setValue(self.b.getSize(), -cx)
obj.assemble()
self._last_rank_debug(f"assembly of objective vector complete!")
return self._obj_vec.norm()
def assemble_b_aug(self, x: PETSc.Vec, b_aug: PETSc.Vec):
self._last_rank_debug(f"assembling nested b")
with self.b.localForm() as b_loc:
b_loc.set(0)
dfx.fem.petsc.assemble_vector(self.b, self.residual)
self.b.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
self.b.scale(-1)
self.b.ghostUpdate(addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD)
lam_l = 0
self.b.assemble()
b_aug.setValues(range(*(self.b.getOwnershipRange())), self.b)
b_aug.setValue(self.b.getSize(), -cx)
b_aug.assemble()
self._last_rank_debug(f"assembly of nested b complete!")
def assemble_A_aug(self, A_aug: PETSc.Mat):
A_aug.zeroEntries()
dfx.fem.petsc.assemble_matrix(self.A, self.jacobian)
self.A.assemble()
self._last_rank_debug("assembling nested A")
global_size = self.bt.getSize()
local_range = range(*(self.bt.getOwnershipRange()))
global_range = range(global_size)
global_is = PETSc.IS().createGeneral(global_range, comm=PETSc.COMM_WORLD)
local_is = PETSc.IS().createGeneral(local_range, comm=PETSc.COMM_WORLD)
A_aug.setValues(local_is, global_size, self.bt.getArray(), addv=PETSc.InsertMode.INSERT_VALUES)
y = self.gather_to_the_last_process(self.bt)
A_aug.setValues(global_size, global_is, y.getArray(), addv=PETSc.InsertMode.INSERT_VALUES)
A_aug.setValues(global_size, global_size, 0, addv=PETSc.InsertMode.INSERT_VALUES)
values = self.A.getValuesCSR()
values = (np.append(values[0], values[0][-1]), ) + values[1:]
A_aug.setValuesCSR(*values, addv=PETSc.InsertMode.INSERT_VALUES)
A_aug.assemble()
self._last_rank_debug("assembly of nested A complete!")
def gather_to_the_last_process(self, b: PETSc.Vec):
# b -> y
global_rows = b.getSize()
y = PETSc.Vec().createSeq(global_rows, comm=PETSc.COMM_SELF)
send_index_set = PETSc.IS().createStride(global_rows, first=0, step=1, comm=PETSc.COMM_SELF)
recv_index_set = PETSc.IS().createStride(global_rows, first=0, step=1, comm=PETSc.COMM_SELF)
y = PETSc.Vec().createSeq(0, comm=PETSc.COMM_SELF)
send_index_set = PETSc.IS().createStride(0, first=0, step=1, comm=PETSc.COMM_SELF)
recv_index_set = PETSc.IS().createStride(0, first=0, step=1, comm=PETSc.COMM_SELF)
scatter = PETSc.Scatter().create(b, send_index_set, y, recv_index_set)
scatter.scatter(b, y, mode=PETSc.ScatterMode.FORWARD, addv=PETSc.InsertMode.INSERT_VALUES)
return y
def update_solution(self, x: PETSc.Vec) -> None:
is_xt = PETSc.IS().createGeneral(range(*(self.sol.vector.getOwnershipRange())), comm=PETSc.COMM_WORLD)
self.xt = x.getSubVector(is_xt)
vals = self.sol.vector.getValues(is_xt)
self.sol.vector.setValues(is_xt, vals + self.xt.getArray())
self.sol.vector.assemble()
self.sol.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
def solve(self, max_iterations=25, atol=1e-8):
for i in range(max_iterations):
self.assemble_b_aug(self.x, self.b_aug)
self.assemble_A_aug(self.A_aug)
self.solver.solve(self.b_aug, self.x)
reason = self.solver.getConvergedReason()
self._last_rank_debug(f"iteration {i}: converged with status {reason}")
resid_norm = self.residual_norm(self.x, self._obj_vec)
self._last_rank_debug(f"iteration {i}: residual norm = {resid_norm}")
self._test_get_serial_norm()
global_resid_norm = self.comm.allreduce(resid_norm, op=MPI.MAX)
self._last_rank_debug(f"iteration {i}: global residual norm = {global_resid_norm}")
if global_resid_norm < atol:
break
return self.sol, global_resid_norm
def config_solver(self, solver):
solver.setOperators(self.A_aug)
solver.setType("preonly")
solver.setTolerances(
atol=1e-10,
rtol=1e-8
pc = solver.getPC()
pc.setType("lu")
F = pc.getFactorMatrix()
F.setMumpsIcntl(14, 100)
F.setMumpsIcntl(24, 1)
F.setMumpsIcntl(25, 0)
solver.setFromOptions()
return solver
def _test_get_serial_norm(self):
self.comm.Barrier()
global_xt_array = self.comm.gather(self.xt.getArray(), root=0)
if self.comm.rank == 0:
logger.debug(f"Rank {self.comm.rank}: global xt: {np.concatenate(global_xt_array).shape}")
logger.debug(f"Rank {self.comm.rank}: global xt norm = {np.linalg.norm(np.concatenate(global_xt_array), 1)}")
