Residual Mismatch with Custom Newton Solver
Update:
With the help of this post, the problem has been partially resolved.
However, there are still some discrepancies:
The residual values do not match exactly, but the final calculated force is correct. So it is not a concern anymore.
When using iterative convergence based on the dx-norm, the solution converges successfully. However, when using residual-based convergence with the rhs-norm, the solution fails to converge.
Could you please help identify any potential issues in the implementation? Below is the updated code snippet for reference:
import os
import dolfinx.fem.petsc
import dolfinx.nls.petsc
from dolfinx import fem, io, log, mesh
import basix
from petsc4py.PETSc import ScalarType
from myfunctionstrial import  mtrl_parameters, fracture_parameters, degradation_fn, \
    bracket_operator_plus, bracket_operator_minus, log_info, log_setup
meshfilename = "senp.msh"
if meshfilename.endswith(".msh"):
    # dmesh -> DOLFINxmesh, ct -> cell_tags, ft -> facet_tags
    dmesh, ct, ft = io.gmshio.read_from_msh(meshfilename, MPI.COMM_WORLD, 0, gdim=2)
    raise ValueError("Only .msh or .xdmf file formats for meshes are supported!")
# function elements P->mechanics field (vector), S->fracture field (scalar), R-> history field (scalars)
P = basix.ufl.element("CG", dmesh.basix_cell(), 1, shape=(dmesh.geometry.dim,))
S = basix.ufl.element("CG", dmesh.basix_cell(), 1)
R = basix.ufl.element("DG", dmesh.basix_cell(), 0)
# mixed element
mix = basix.ufl.mixed_element([P,S])
# create a function space consisting of a mixed element at each node
V = fem.functionspace(dmesh,mix)
# create a separate function space for history variable
W = fem.functionspace(dmesh,R)
# test functions du->mechanics field, dd->fracture field
du , dd = ufl.TestFunctions(V)
# mixed solution vector creation, sol-> n+1 th load increment step, solold-> n th time step (previous)
sol = fem.Function(V)
solold = fem.Function(V)
# history variable vector creation
H = fem.Function(W)
Hold = fem.Function(W) # history field at the previous time step
# individual solution vectors at n+1 step, u-> mechanics field, d-> fracture field
u, d = ufl.split(sol)
# individual solution vectors at n th step, uold-> mechanics field, dold-> fracture field
uold, dold = ufl.split(solold)
lmda, mu, K = mtrl_parameters()
G_cr, l, total_u, delta_u, k =fracture_parameters()
# function for returning facets in the top edge
def top(x):
    return np.isclose(x[1],1)
# function for returning facets in the bottom edge
def bot(x):
    return np.isclose(x[1],0)
# function for returning facets in the crack face
def crack(x):
	#crack is at (0,0.5) to (0.5,0.5)
    return np.logical_and(abs(x[1]-0.5) <= 0.001, x[0] <= 0.5)
# subspace of mechanics field, accessing all components of u
V0,_ = V.sub(0).collapse()
# subspace of mechanics field, accessing u along x-direction
V01, _ = V.sub(0).sub(0).collapse()
# subspace of mechanics field, accessing u along y-direction
V02, _ = V.sub(0).sub(1).collapse()
# subspace of fracture field, accessing d
V1,_ = V.sub(1).collapse()
# obtain corresponding facets as per the requirement
bot_facets = mesh.locate_entities_boundary(dmesh, 1, bot)
top_facets = mesh.locate_entities_boundary(dmesh, 1, top)
crack_facets = mesh.locate_entities_boundary(dmesh, 1, crack)
# obtain dofs on the corresponding facets using the subspaces
# on bottom face all components of u are chosen
bot_dofs = fem.locate_dofs_topological((V.sub(0),V0), 1, bot_facets)
# on top face only x-component of u is chosen
top_dofs = fem.locate_dofs_topological((V.sub(0).sub(0),V01), 1, top_facets)
# on top face only y-component of u is chosen
top_dofs_y = fem.locate_dofs_topological((V.sub(0).sub(1),V02), 1, top_facets)
# the phase field parameter d dofs is chosen on the crack facets
crack_dofs = fem.locate_dofs_topological((V.sub(1),V1), 1, crack_facets)
# expression for defining values to the corresponding boundary conditions
# boundary values values needed for bottom face
u_bot = fem.Function(V0)
u_botval = fem.Constant(dmesh,ScalarType([0.0,0.0]))
u_botexpr = fem.Expression(u_botval,V0.element.interpolation_points())
u_bot.interpolate(u_botexpr)
# boundary values values needed for top face
u_top = fem.Function(V01)
u_topval = fem.Constant(dmesh,ScalarType(0.001))
u_topexpr = fem.Expression(u_topval,V01.element.interpolation_points())
u_top.interpolate(u_topexpr)
u_topy = fem.Function(V02)
u_topyval = fem.Constant(dmesh,ScalarType(0))
u_topyexpr = fem.Expression(u_topyval,V02.element.interpolation_points())
u_topy.interpolate(u_topyexpr)
# expression for defining the value of d at crack facets
d_crack = fem.Function(V1)
d_crack.x.array[:] = 1
# defining dirichlet boundary condition on the bottom face, all components of u=0 (fixed)
bc_ubot = fem.dirichletbc(u_bot,bot_dofs,V.sub(0))
# defining dirichlet boundary condition on the top face, for applying load increments along x
bc_utop = fem.dirichletbc(u_top, top_dofs, V.sub(0).sub(0))
# defining dirichlet boundary condition on the top face, for applying uy=0
bc_utopy = fem.dirichletbc(u_topy, top_dofs_y, V.sub(0).sub(1))
# defining dirichlet boundary condition on the pre-crack face to be d=1
bc_dcrack = fem.dirichletbc(d_crack, crack_dofs, V.sub(1))
# defining tractions - (Neumann Boundary Conditions) - zero tractions on the boundary
t_bar = fem.Constant(dmesh,np.array([0.0,0.0],dtype=ScalarType))
# defining body forces - zero body forces
b = fem.Constant(dmesh,np.array([0.0,0.0],dtype=ScalarType))
# facet normal (will be required for computation of forces)
n = ufl.FacetNormal(dmesh)
ds_top = ufl.Measure(integral_type='ds', domain=dmesh, subdomain_data=ft, subdomain_id=2)
# defining constitutive and kinematical relations
def To2D(A):
    return ufl.as_tensor([[ A[0,0], A[0,1]],
                          [ A[1,0], A[1,1]] ])
def To3D(A):
    return ufl.as_tensor([[ A[0,0], A[0,1],  0],
                       [ A[1,0], A[1,1],  0],
                       [  0,       0,     0]])
# infinitesimal strain tensor
def epsilon(x_u):
    return ufl.sym(ufl.grad(x_u))
# stress tensor
def sigma(x_u, x_d):
    eps = epsilon(x_u)
    eps=To3D(eps)
    dev_epsilon = eps - ( (1/3)*ufl.tr(eps)*To3D(ufl.Identity(len(x_u))) )
    stress3d= (degradation_fn(x_d)+ k) * ( (lmda+mu)*bracket_operator_plus(ufl.tr(epsilon(x_u)))*To3D(ufl.Identity(len(x_u))) + 2*mu*dev_epsilon ) +\
            (lmda+mu)* bracket_operator_minus(ufl.tr(epsilon(x_u))) *To3D(ufl.Identity(len(x_u)))  # Deviator split
    return To2D(stress3d)
    #return  (degradation_fn(x_d)+ k)*(2.0*mu*epsilon(x_u)+lmda*ufl.tr(epsilon(x_u))*ufl.Identity(len(x_u)))   # alternative - for hybrid implementation (ref. thesis)
# defining fracture related expressions
# tensile part of elastic strain energy density
def psi_e(x_u):
    eps = epsilon(x_u)
    eps=To3D(eps)
    return 0.5*(lmda+mu)*(bracket_operator_plus(ufl.tr(epsilon(x_u))))**2 + mu*ufl.inner(dev_epsilon,dev_epsilon)
# History field variable
def H(x_uold,x_u,x_Hold):
    return ufl.conditional(ufl.operators.gt(psi_e(x_u),x_Hold),psi_e(x_u),x_Hold)
# mechanics field variational form
#mech = ufl.inner(sigma(u, dold),epsilon(du))*ufl.dx - ufl.dot(b,du)*ufl.dx - ufl.dot(t_bar,du)*ds_top
mech = ufl.inner(sigma(u, d),epsilon(du))*ufl.dx - ufl.dot(b,du)*ufl.dx - ufl.dot(t_bar,du)*ds_top
# fracture field variational form
frac = G_cr*l*ufl.dot(ufl.grad(d),ufl.grad(dd)) *ufl.dx + ((G_cr/l) + 2*H(uold,u,Hold))*ufl.inner(d,dd) * ufl.dx - 2*dd*H(uold,u,Hold) *ufl.dx
# combined variational form
F = mech + frac
# uncomment below lines to know about the residual and convergence status at each solution step
# visible only in console (will not be logged in log file)
#if (MPI.COMM_WORLD.rank ==0):
#    log.set_log_level(log.LogLevel.INFO)
# general initializations
residual = dolfinx.fem.form(F)
dsol = ufl.TrialFunction(V)
J = ufl.derivative(F, sol, dsol)
jacobian = dolfinx.fem.form(J)
# Next, we define the matrix `A`, right hand side vector `L` and the correction function `du`
delsol = fem.Function(V)
delu, deld = ufl.split(delsol)
delu = delsol.sub(0)
deld = delsol.sub(1)
A = dolfinx.fem.petsc.create_matrix(jacobian)
L = dolfinx.fem.petsc.create_vector(residual)
solver = PETSc.KSP().create(dmesh.comm)
solver.setType(PETSc.KSP.Type.PREONLY)
solver.getPC().setType(PETSc.PC.Type.LU)
opts = PETSc.Options()
prefix = f"solver_{id(solver)}"
solver.setOptionsPrefix(prefix)
option_prefix = solver.getOptionsPrefix()
opts[f"{option_prefix}ksp_type"] = "preonly"
opts[f"{option_prefix}pc_type"] = "lu"
opts[f"{option_prefix}pc_factor_mat_solver_type"] = "mumps"
solver.setFromOptions()
solver.setOperators(A)
load = 0
# initializing u, d, uold, dold, aold, vold for problem solving and results saving
u = sol.sub(0)
d = sol.sub(1)
uold = solold.sub(0)
dold = solold.sub(1)
while load <= 1:
    # incrementing displacement
    u_topval.value = load*total_u
    #solver:
    i = 0
    max_iterations=10
    converged = False
    while i < max_iterations:
        # Assemble Jacobian and residual
        with L.localForm() as loc_L:
            loc_L.set(0)
        A.zeroEntries()
        dolfinx.fem.petsc.assemble_matrix(A, jacobian, bcs=[bc_ubot, bc_utop, bc_dcrack, bc_utopy])
        A.assemble()
        dolfinx.fem.petsc.assemble_vector(L, residual)
        L.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
        L.scale(-1)
        # Compute b - J(u_D-u_(i-1))
        dolfinx.fem.petsc.apply_lifting(L, [jacobian], [[bc_ubot, bc_utop, bc_dcrack, bc_utopy]], x0=[sol.x.petsc_vec],scale=1)
        # Set du|_bc = u_{i-1}-u_D
        dolfinx.fem.petsc.set_bc(L, [bc_ubot, bc_utop, bc_dcrack, bc_utopy], sol.x.petsc_vec, 1.0)
        L.ghostUpdate(addv=PETSc.InsertMode.INSERT_VALUES, mode=PETSc.ScatterMode.FORWARD)
        # Solve linear problem
        solver.solve(L, delsol.x.petsc_vec)
        delsol.x.scatter_forward()
        # Update u_{i+1} = u_i + delta u_i
        sol.x.array[:] += delsol.x.array
        i += 1
        residual_norm=L.norm(1)
        correction_norm = delsol.x.petsc_vec.norm(0)
        MPI.COMM_WORLD.Barrier()
        if(MPI.COMM_WORLD.rank ==0):
            print(f"Iteration {i-1}: residual norm {residual_norm}")
            print(f"Iteration {i-1}: Correction norm {correction_norm}")
        if correction_norm < 1e-6:
            converged=True
            break
    if not converged:
        if MPI.COMM_WORLD.rank == 0:
            print("Nonlinear solver did not converge.")
        break
    # bounding d value to be between 0 and 1 # not necessary given the problem formulation ?????
    interimp = sol.sub(1).collapse()
    interimp.x.array [interimp.x.array < 0] = 0
    interimp.x.array [interimp.x.array > 1] = 1
    sol.sub(1).interpolate(interimp)
    # updating u, d for next iteration
    solold.x.array[:] = sol.x.array
    solold.x.scatter_forward()
    # incrementing load step
    load += delta_u
log_info("Simulation completed.",my_logger)
