Hello, I am facing an error while implementing this tutorial in 3D by modifying the degree of u and stress and boundary conditions, when I increase my mesh density say 10 or more, it runs out of memory, and when I keep mesh density too low to make it work, it returns Residual: nan.
I have tries “umfpack” which gives same result which is Residual: nan and on finer mesh, runs out of memory. When I use “mumps” there is this error:
/tmp/ipykernel_4680/2031601198.py in <module>
12 niter = 0
13 while nRes/nRes0 > tol and niter < Nitermax:
---> 14 solve(A, du.vector(), Res, "mumps")
15 Du.assign(Du+du)
16 deps = eps(Du)
/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/solving.py in solve(*args, **kwargs)
238 raise RuntimeError("Not expecting keyword arguments when solving linear algebra problem.")
239
--> 240 return dolfin.la.solver.solve(*args)
241
242
/usr/lib/petsc/lib/python3/dist-packages/dolfin/la/solver.py in solve(A, x, b, method, preconditioner)
70 """
71
---> 72 return cpp.la.solve(A, x, b, method, preconditioner)
RuntimeError:
*** Reason: Solution failed to converge in 0 iterations (PETSc reason DIVERGED_PC_FAILED, residual norm ||r|| = 0.000000e+00).
*** Where: This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 0
*** Git changeset: ubuntu
I looked upon the web and found out in this post that at first iteration the solution has been found. I have no clue what should I use to get this code working.
Here is minimum working example -
parameters["form_compiler"]["representation"] = 'quadrature'
import warnings
from ffc.quadrature.deprecation import QuadratureRepresentationDeprecationWarning
warnings.simplefilter("once", QuadratureRepresentationDeprecationWarning)
E = Constant(70e3)
nu = Constant(0.3)
lmbda = E*nu/(1+nu)/(1-2*nu)
mu = E/2./(1+nu)
sig0 = Constant(250.)
Et = E/100.
H = E*Et/(E-Et)
cube = Box(Point(0, 0, 0),Point(1, 1, 1))
domain = cube
mesh = generate_mesh(domain, 5)
plot(mesh);
deg_u = 3
deg_stress = 3
V = VectorFunctionSpace(mesh, "CG", deg_u)
We = VectorElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, dim=4, quad_scheme='default')
W = FunctionSpace(mesh, We)
W0e = FiniteElement("Quadrature", mesh.ufl_cell(), degree=deg_stress, quad_scheme='default')
W0 = FunctionSpace(mesh, W0e)
sig = Function(W)
sig_old = Function(W)
n_elas = Function(W)
beta = Function(W0)
p = Function(W0, name="Cumulative plastic strain")
u = Function(V, name="Total displacement")
du = Function(V, name="Iteration correction")
Du = Function(V, name="Current increment")
v = TrialFunction(V)
u_ = TestFunction(V)
P0 = FunctionSpace(mesh, "DG", 0)
p_avg = Function(P0, name="Plastic strain")
class bottom(SubDomain):
return on_boundary and near(x[1], 0., 0.01)
class top(SubDomain):
return on_boundary and near(x[1], 1., 0.01)
boundaries = MeshFunction("size_t", mesh, mesh.geometry().dim() - 1)
bottom().mark(boundaries, 1)
top().mark(boundaries, 2)
q_lim = float(sig0)
loading = Expression("q*t", q=q_lim, t=0, degree=2)
bc_bottom = DirichletBC(V, Constant((0., 0., 0.)), boundaries, 1)
bc_u = [bc_bottom]
def F_ext(v):
return loading*dot(n, v)*ds(2)
def eps(v):
e = sym(grad(v))
return as_tensor([[e[0, 0], e[0, 1], 0],
[e[0, 1], e[1, 1], 0],
[0, 0, 0]])
def sigma(eps_el):
return lmbda*tr(eps_el)*Identity(3) + 2*mu*eps_el
def as_3D_tensor(X):
return as_tensor([[X[0], X[3], 0],
[X[3], X[1], 0],
[0, 0, X[2]]])
ppos = lambda x: (x+abs(x))/2.
def proj_sig(deps, old_sig, old_p):
sig_n = as_3D_tensor(old_sig)
sig_elas = sig_n + sigma(deps)
s = dev(sig_elas)
sig_eq = sqrt(3/2.*inner(s, s))
f_elas = sig_eq - sig0 - H*old_p
dp = ppos(f_elas)/(3*mu+H)
n_elas = s/sig_eq*ppos(f_elas)/f_elas
beta = 3*mu*dp/sig_eq
new_sig = sig_elas-beta*s
return as_vector([new_sig[0, 0], new_sig[1, 1], new_sig[2, 2], new_sig[0, 1]]), \
as_vector([n_elas[0, 0], n_elas[1, 1], n_elas[2, 2], n_elas[0, 1]]), \
beta, dp
def sigma_tang(e):
N_elas = as_3D_tensor(n_elas)
return sigma(e) - 3*mu*(3*mu/(3*mu+H)-beta)*inner(N_elas, e)*N_elas-2*mu*beta*dev(e)
metadata = {"quadrature_degree": deg_stress, "quadrature_scheme": "default"}
dxm = dx(metadata=metadata)
a_Newton = inner(eps(v), sigma_tang(eps(u_)))*dxm
res = -inner(eps(u_), as_3D_tensor(sig))*dxm + F_ext(u_)
dv = TrialFunction(V)
v_ = TestFunction(V)
a_proj = inner(dv, v_)*dxm
b_proj = inner(v, v_)*dxm
solver.factorize()
if u is None:
solver.solve_local_rhs(u)
return u
return
Nitermax, tol = 200, 1e-8
Nincr = 20
load_steps = np.linspace(0, 1.1, Nincr+1)[1:]**0.5
results = np.zeros((Nincr+1, 2))
for (i, t) in enumerate(load_steps):
loading.t = t
A, Res = assemble_system(a_Newton, res, bc_u)
nRes0 = Res.norm("l2")
nRes = nRes0
Du.interpolate(Constant((0, 0, 0)))
print("Increment:", str(i+1))
niter = 0
solve(A, du.vector(), Res, "lu")
Du.assign(Du+du)
deps = eps(Du)
sig_, n_elas_, beta_, dp_ = proj_sig(deps, sig_old, p)
local_project(sig_, W, sig)
local_project(n_elas_, W, n_elas)
local_project(beta_, W0, beta)
nRes = Res.norm("l2")
print(" Residual:", nRes)
niter += 1
u.assign(u+Du)
p.assign(p+local_project(dp_, W0))
sig_old.assign(sig)
p_avg.assign(project(p, P0))
results[i+1, :] = (u(0.5, 1., 0.)[1], t)
It works fine on 2d mesh but I don’t know how to make it work in 3d.
Kindly give some suggestions on the same.
Thank You.
