Using the mumps solver when calling solve
Howdy, so I had two questions. I had a 2-d code running now I’m trying to make it work for 3-d. Everything is the same, I just changed the mesh from 2-d box to 3-d box - my code is over 4,000 lines, so I won’t post but the important part is here
state=inner(grad(u_r),grad(v_r))*dx + inner(grad(u_i),grad(v_i))*dx +ko*u_i*v_r*ds -ko*u_r*v_i*ds -v_r*(kosquared*(1+q*w)*u_r +kosquared*q*w*cos_f)*dx -v_i*(kosquared*(1+q*w)*u_i +kosquared*q*w*sin_f)*dx
				Jac = derivative(state, u, TrialFunction(V))
				solve(state == 0, u,  J=Jac)
When I run this I get out of memory issue :
UMFPACK V5.7.6 (May 4, 2016): ERROR: out of memory
  File "fullprog.py", line 1299, in <module>
    out = prog(256,.75,d,angles_array,prob_list,grid_size,w,nz,True,True)
  File "fullprog.py", line 671, in prog
    solve(state == 0, u)
  File "/anaconda3/envs/py35/lib/python3.5/site-packages/fenics_adjoint/solving.py", line 31, in solve
    output = backend.solve(*args, **kwargs)
  File "/anaconda3/envs/py35/lib/python3.5/site-packages/dolfin/fem/solving.py", line 220, in solve
  File "/anaconda3/envs/py35/lib/python3.5/site-packages/dolfin/fem/solving.py", line 266, in _solve_varproblem
    solver.solve()
RuntimeError:
*** Error:   Unable to successfully call PETSc function 'KSPSolve'.
*** Reason:  PETSc error code is: 76 (Error in external library).
*** Where:   This error was encountered inside /Users/travis/miniconda3/conda-bld/fenics_1535552255351/work/dolfin/la/PETScKrylovSolver.cpp.
*** Process: 0
*** DOLFIN version: 2018.1.0
*** Git changeset:
I saw people also complaining about this - I saw people using mumps as the solver as a fix i.e
				#Jac = derivative(state, u, TrialFunction(V))
				solve(state == 0, u,solver_parameters={'linear_solver': 'mumps'})
but when I run this I get
File “fullprog.py”, line 1299, in
File “fullprog.py”, line 671, in prog
solve(state == 0, u,solver_parameters={‘linear_solver’: ‘mumps’})
File “/anaconda3/envs/py35/lib/python3.5/site-packages/fenics_adjoint/solving.py”, line 31, in solve
File “/anaconda3/envs/py35/lib/python3.5/site-packages/dolfin/fem/solving.py”, line 220, in solve
File “/anaconda3/envs/py35/lib/python3.5/site-packages/dolfin/fem/solving.py”, line 265, in _solve_varproblem
solver.parameters.update(solver_parameters)
File “/anaconda3/envs/py35/lib/python3.5/site-packages/dolfin/parameter/init.py”, line 40, in update
self[key] = params[key]
RuntimeError: Parameter not found in Parameters object
The underlying equation I’m solving is a poisson type equation - so this should be computationally feasible in my mind. Help?
Thank you.
Did you check if mumps is available in your installation?
dolfin.list_linear_solver_methods()
@Lukas_O Looks like I do have mumps, am I not passing the parameter correctly to solve? -
import dolfin
Solver method  |  Description
bicgstab       |  Biconjugate gradient stabilized method
cg             |  Conjugate gradient method
default        |  default linear solver
gmres          |  Generalized minimal residual method
minres         |  Minimal residual method
mumps          |  MUMPS (MUltifrontal Massively Parallel Sparse direct Solver)
petsc          |  PETSc built in LU solver
richardson     |  Richardson method
tfqmr          |  Transpose-free quasi-minimal residual method
umfpack        |  UMFPACK (Unsymmetric MultiFrontal sparse LU factorization)
I think your problem is non-linear so you should either formulate it as
problem = NonlinearVariationalProblem(F, u, bcs, J)
prm = solver.parameters
prm[“nonlinear_solver”]=“newton”
prm[“newton_solver”][“linear_solver”] = “mumps”
or maybe try something like (no tested):
solve(state == 0, u,solver_parameters={'newton_solver': {'linear_solver': 'mumps'}})
