I’m trying to create virtual probes to get the value of the solution at a given coordinate (not necesseraly on a node).
So far I was just looking at the value of the closest node but I want to be more precise by using the restrict function. But I get this error and can’t figure out how to solve it:
TypeError: restrict(): incompatible function arguments. The following argument types are supported:
- (self: dolfin.cpp.function.Function, arg0: float, arg1: dolfin::FiniteElement, arg2: dolfin::Cell, arg3: float, arg4: dolfin.cpp.function.ufc_cell) → None
Invoked with: <dolfin.cpp.function.Function object at 0x7fcd0fd372d0>, array([0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0.]), <dolfin.cpp.fem.FiniteElement object at 0x7fcd0fd37228>, <dolfin.cpp.mesh.Cell object at 0x7fcd0fd375e0>, [0.625000000001214, -1.0, 0.5833333333348364, -1.0, 0.6032837911524445, -0.9588620043877216], <dolfin.cpp.mesh.Cell object at 0x7fcd0fd375e0>
Here is my function call:
w.restrict(coefficients, element, cell, vertex_coords, cell)
With:
element = w.function_space().dolfin_element()
coefficients = np.zeros(element.space_dimension())
cell = Cell(mesh, cell_id)
vertex_coords = cell.get_vertex_coordinates()
Here is the full code of the class init:
def __init__(self, w, locations): mesh = w.function_space().mesh() limit = mesh.num_entities(mesh.topology().dim()) bbox_tree = mesh.bounding_box_tree() cells_for_x = [None]*len(locations) for i, x in enumerate(locations): cell = bbox_tree.compute_first_entity_collision(Point(*x)) if -1 < cell < limit: cells_for_x[i] = cell V = w.function_space() element = V.dolfin_element() size = V.ufl_element().value_size() evals = [] for x, cell in zip(locations, cells_for_x): if cell is not None: basis_matrix = np.zeros(size*element.space_dimension()) coefficients = np.zeros(element.space_dimension()) cell = Cell(mesh, cell) vertex_coords, orientation = cell.get_vertex_coordinates(), cell.orientation() basis_matrix = element.evaluate_basis_all(x, vertex_coords, orientation) basis_matrix = basis_matrix.reshape((element.space_dimension(), size)).T def val(w, c = coefficients, ele = element, A = basis_matrix, cell = cell, vc = vertex_coords): w.restrict(c, ele, cell, vc, cell) return np.dot(A, c) else: val = lambda w, size=size: (np.finfo(float).max)*np.ones(size) evals.append(val)
