Results obtained by FEniCS mismatches Abaqus
I performed the following code:
domain = Rectangle(Point(0, 0), Point(3, 3))
mesh = generate_mesh(domain, number_of_element)
Vu = VectorFunctionSpace(mesh, "CG", 1)
u = Function(Vu, name="Displacement")
# Solve displacement u-problem
        problem_u.solve(u.vector())
###define functionspace
V=FunctionSpace(mesh,'P',1)
W=TensorFunctionSpace(mesh,"DG",0)
###get displacement###
u_magnitude = sqrt(dot(u,u))
u_magnitude = project(u_magnitude,V)
u_x, u_y = u.split(deepcopy=True)
u_x=project(u_x,V)
###get stress component
epsilo=0.5*(nabla_grad(u)+nabla_grad(u).T)    #strain
sigma=E*nu/((1+nu)*(1-2*nu))*tr(epsilo)*Identity(2)+2*(E/(2*(1+nu)))*epsilo
sigma=project(sigma,W)
s11,s12,s21,s22=sigma.split(deepcopy=True)
###get von-mises
s = sigma_ - (1. / 3) * tr(sigma_) * Identity(2)
von_Mises = sqrt(3. / 2 * inner(s, s))
von_Mises = project(von_Mises, V)
the von-mises obtained by FEniCS have 1.3% error Abaqus, but strange, the displacement u_magnitude and stress component s11 both have large error (about 30%) compared with Abaqus. Why this could happen? (I guess the problem could be split command? )
this is a plane strain problem and choose linear triangle element in Abaqus.
the similar number of element is applied in Abaqus and FEniCS
Thanks in advance
The code you supplied is not complete, and therefore there is not much one can do to investigate this.
Note that the von Mises stresses should be projected into W (the discontinuous space).
Hi dokken, thanks for your note. von_mises should be projected into DG. but interestingly, when i project it into V=FunctionSpace(mesh,'P',1) ,i can still get the same answer with W=FunctionSpace(mesh,"DG",0) . why this can happen?
for whole code, you can download at here. In this code, I want to extract the stress and displacement. then I insert the following code after original code-print("force=",results[i + 1, 0])
u_x=project(u_x,V)
###get von-mises
but i can not get the correct u_x results compared with Abaqus. then i want to check the code,for simplicity, i eliminate phase field by inserting the following code:
Vd = FunctionSpace(mesh, "CG", 1)
d = Function(Vd, name="Damage")
dold = Function(Vd, name="Previous damage")
bcd1 = DirichletBC(Vd, Constant(0.),top)
bcd2 = DirichletBC(Vd, Constant(0.), bottom)
bcd=[bcd1,bcd2]
d_=Expression('0.0',degree=1)
d=interpolate(d_,Vd)
then the whole domain will have no damage. problem is elastic. but i can not still get the correct u_x displacement.
How do you compare your solution with abaqus? Do you use paraview, or integrate some reference quantities. If you are using paraview, you Need to use XDMFFile.write_checkpoint to save the solution as something other than a CG-1 interpolation. See: Loading xdmf data back in .
I guess that @bleyerj might be able to give you some more pointers given that he is on of the authors of the code.
thanks dokken, i will read it late.
HI,
sorry but it’s hard to help you like that, the problem could well be from your Abaqus input or outputs. I suggest you check with an independent FEniCS standard elasticity implementation to see if the problem comes from the use of MFront.
hello again jeremy, I have double check the results and code have no problem. the reason for the error happening is I wrongly write a parameter.
Additionally, regarding to “phase field approach to brittle fracture” code, i have changed it to suit fgm-analysis. but i don’t know how to add a newton-load on boundary like the following picture show:
many thanks
Hello, jeremy, sorry for asking for help too fast, i have got the answer from your demo “Small-strain von Mises elastoplasticity” .thanks a lot
